Question about Kenmore Kitchen Ranges
Range door will not seal properly.
Kenmore Elite Electric range mod# 790.9912 door will not close all the way and must have something propped against it to use the convection oven or baking. Interior light is always on.
  • Kenmore Master
  • 3,361 Answers
Place a hammer handle between the door and the frame at the hinges..
Push on the door, carefully.
This usually works to re-seat the door hinges.
Posted on Mar 08, 2009
  • 1 more comment
  • halcott6_198 Oct 06, 2010
    Thanks, i was about to buy hinges,s what happens when your teens lean on door.....
  • adixon68 Jan 19, 2011
    Thanks- that did it- saved me a service call!
  • LA Pitman
    LA Pitman Mar 23, 2014
    Worked like a charm!
How can I get a user manual for my Kenmore Elite 30 inch Electric slide in range with ribbon radiant elements model number 46804
Kenmore Elite Electric Slide In Range 30 in. 41053 - Sears
www.kenmore.com/kenmore-elite-30inch-slide...electric-range...
Kenmore
Rating: 3 - ‎30 votes
The slide-in Kenmore Elite range 41053 has a true convection oven for faster pre. ...Kenmore Elite 30" Slide-In Electric Range w/ Convection - Stainless Steel ... Owners manual - English (Warranty) .... I called SEARS repair to look at my range and the repairman told me that this range has flaws with the oven fan and there is ...
Kenmore Elite 30" Double-Oven Slide-In Electric Range w
www.kenmore.com/kenmore-elite-30inch...slide...electric/p-02...
Kenmore
Rating: 3.5 - ‎30 votes
The exciting Kenmore Elite double-oven slide-in range 4111 offers all the feature. ... Versatile cooktop options include a 12-inch triple-ring element, a 9-inch Turbo Boil Flex™ element, and a ... Owners manual - English (Warranty) .... Ovens are both conventional or can be set to convection, my first bake was a cheese cake.
Nov 28, 2015 | Kenmore Kitchen Ranges
The dryer door will not stay closed. It will actually close but it will not stay closed therefore it stops during the cycle. It we prop something against the door it will stay closed and a full drying...
Go to www.appliancepartspros.com do a search using the model number and you will find the schematics for the dryer. Look for the cabinet parts diagram and locate the latch assembly. Look for the door latch and the door catch both parts will probably cost less than $10. There may be some minor disassembly required but not a big ordeal.
Nov 22, 2009 | Dryers
Amana range model 770M door won't fully close
Is the door hitting the door lock hook. Or a strike pin hitting the inside door panel. If this is a self cleaning range the door seal is a metal mesh and does hold the door slightly away, this is normal. More info ?
Sep 01, 2009 | Amana ACF4215 Electric Kitchen Range
Kenmore Elite Freestanding Electric Range - Cooktop not working
Your stove probably requires a separate 20A circuit with 12 ga. wire.
May 19, 2017 | Frigidaire 30" Self-Cleaning Freestanding...
Oven has been cleaning for hours and won't turn off
You will find that the cleaning cycle takes more than 3 hours. Leave it for at least twice that long before you get concerned. When the cleaning is done and the oven is cool it will unlock
Jun 19, 2009 | Kenmore 46123 Stainless Steel Electric...
Ovendoor not closing for tight seal...
You should feel the door pull closed when you as you lift it and get near the closed position.
There is some spring linkage associated with the hinge pins at the bottom sides of the oven.
I cannot find the oven you indicated, but I did find exploded views and parts list of the topic post oven on the SearsPartsDirect website.
Jan 28, 2009 | Kenmore 99123 Electric Kitchen Range
Kenmore oven model# 790.79383401 door not closing
Do the hinges come out with the door or does the door slip off the hinges? If the hinges are on the door then there is no adjustment if not there should be an adjustment but you may have to pull the range out to properly adjust if it is a built in range. Also check the door lock.
Jan 15, 2008 | Ovens
Oven door just barely closes- light stays on
put a tea towel on both sides of the door [folded] down by the hinges then close door. gently push the door close try a few times with a little pressure.
Nov 12, 2007 | Kenmore 96422 / 96424 / 96429 Electric...
Kitchen Ranges Logo
251 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
