Question about Home
Whirlpool tub has three holes one on left two on right doihave to drill another hole to install faucett or do i install faucett on left and hot and cold on right
  • 39 Answers
Depends if you have a single handle faucet or double or spray attachment
Posted on Jun 29, 2009
Moen Model CA87888 4-hole 2 handle and sprayer kitchen faucet. I just installed it and it only works with the sprayer. When I turn on the faucet (hot or cold), I am only getting a very small trickle. ...
Pull the screen off the faucett, from the new install you probably clogged the screen. If you get good flow without the screen, clean your screen out and re-install. You will need to twist off the piece and the end of the faucett to get at screen. Pay attention to how it comes out so you can put it back in the same way.
May 02, 2011 | Moen Home
There is a spot almost in the middle of the tub that is softer than the area around it. I am very concerned that there is water damage that we are unaware of. Are soft spots common?
With some manufactures yes. If you can get to the area from under the tub drill some small holes through the flooring and use a stop collar on the drill bit so you don't drill into the tub the put some expanding foam in the holes so it fills the area between the tub bottom and the floor to give the tub bottom some support.
The tub should have been set in cement mortar to prevent this from happening but that
Feb 07, 2011 | Home
We are concernened about screwing the tub into the floor for stability. We have to go through tile and into wood. There are no instructions included for this. Included were 5/16 lag bolt and feet but we do...
The main reason to screw the feet to the floor is to keep the tub from moving which could cause the pipes to leak (either the supply or the drain) Authentic old clawfoot cast iron tubs were usually bolted to the floor because they were so heavy that it took a significant effort to move them, especially on a wood floor. If your tub is light enough that you could move it without a pretty significant push, then you had best bolt it to the floor in at least two places. Drilling holes through tile can be intimidating, but it's not as hard as you might think using an inexpensive masonry drill bit and a carbide tipped scratch awl. I will leave it to you to figure out how to assemble the claw feet to the tub, but here are a couple of important tips for drilling the holes through tile: Mark the hole locations with a felt-tip marker. Then use the carbide tipped scratch awl to gouge a starter divot in the tile. This divot can be pretty small, but it's essential for being able to drill a hole in tile in the right place. Use a variable-speed drill at fairly low speed to drill the hole - don't use a hammer-drill. Also keep a puddle of water where you are drilling to prevent the tile from heating up in one spot and causing the tile to crack. Once you get the hole through to the wood below, switch to a regular drill bit of a smaller size. Good luck, Al K
Aug 24, 2010 | American Standard Reminiscence...
How do i install an jacuzzi that has no faucet its a bathroom jacuzzi has no place for faucet it just has a hole for drain handle
either mount on wall or need to drill holes through jacuzzi 99 % of tubs dont come with faucets
Apr 24, 2010 | Jacuzzi Home
Faucet placement on Jacuzzi 6036
If there is room most definitely you can place the faucets on the tub itself. You can mount them on the left rear. However be very careful drilling the holes and make sure you have it aligned correctly before drilling. Check underneath to make sure there is enough room for clearance and hook up. Here is what it will look like. a1da3ad.png
Jan 08, 2010 | Jacuzzi Signa 6 Whirlpool JAC-B540...
No drain cut out in maax opera
It is very easy to cut the hole. It is also very easy to lose control of the drill and brutally gouge the tub. You need a strong drill and the correct size hole saw. Measure it carefully. You will only get 1 shot at this. Don't try to go too small thinking you can just make it bigger. That will not work as well as you think.
The hole saw needs to be a full circle of teeth with a center drill bit that sticks out further than the ring. You use a marker to put a dot on the tub where you want the drain to be centered. Then, you place the drill bit on the dot and slowly drill your pilot hole. When the ring of teeth make contact with the tub, they may want to skip and bounce. This will combine with your downward force to gouge big ugly chunks out of your tub.
I have scrapped many a tub by this exact procedure. You must control any and all bounce by firmly flexing your arms. You cannot allow any sudden upward or downward movements with the hole saw. You can give yourself a little more control by making the center drill bit as long as you can, but still firmly secured.
If all goes well, you will have the right size hole in the correct location. Sand or grind down the underside of your drain hole just a little. This will give your drain a flat surface to hug when you screw it together. A lumpy bottom may cause a leak. A thin bottom may crack during installation.
Take your time and you should do well. Good luck
Dec 04, 2009 | Maax Opera Whirlpool 101026-050
Unbalance load, shakes badly on spin
Unit has water in top of inner tub housing. I haven't figure out if they did this on purpose or there is a defect in the sealing between the tub and this large plastic housing. I put 4 holes in the ring inside the tub. It is double layered and both layers need to have been drilled through. The agitator is in the way but it can be done. Suggest that you use a battery pack drill as water comes out of the holes as you drill them. OR you can buy a new inner tub and have someone install it.
Oct 10, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
How to convert old tub to hot tub motor
what kind of tub? what material is it? if its porcelain and iron forget it unless you just want to buy portable over the side hanger type unit to drill the holes would be far too expensive
Aug 22, 2009 | Vintage Tub & Bath Home
LG LMV1680BB top mount not usable
They simply need to drill new holes, I'd say.
The installation instructions will have a template.
Jun 05, 2009 | Microwave Ovens
Refilling a dell 948 color ink cart #11
Alright, I gave in and busted open my Series 11 KX703 color cartridge to figure out how to refill it. As Inksaver pointed out there are six columns which ultimately lead into three ink wells the bottom two (next to the cartridge head) are magenta, the upper right two are yellow and upper left two are cyan. Each well has one sponge in it that soaks up the ink. Each of the six columns has a hole predrilled in the center of it just below the top layer of plastic (about 5/16" from the left and right edge and 1/4" from the top and bottom and 1 3/16" (midway) from the top and bottom for the center two holes).
When I do it again (with a new cartridge since this one is busted), I'd drill three holes, one lower right and the two center holes, push the metal syringe down into the foam about midway and inject each of the foams with new blood. If someone else tries let me know how it goes. Hope this helps.
Mar 21, 2009 | Dell 948 All-In-One InkJet Printer
Home Logo
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
