Question about Jenn-Air Kitchen Ranges
I have a Jenn-Air slide in electric range, model no. S136W; Serial no. 16746253KW. How do I set the clock. When I turn the dial in the direction of the arrow for the clock, it does nothing
SOURCE: Jenn Air slide in range JES9750AAB - Touch Pad
put on tree belt . having the same problems replaced ERC $200.00 now they are telling me touch pad touch pad is $240.00 .the stove cost $1300.00. $1740.00 how much more will i have to put in this stove
Posted on Jan 06, 2009
alandc
  • 25 Answers
SOURCE: Don't know if the oven part of range is gas or electric
The model number can usually be found just inside the door or drawer (on the range itself).
All the Jenn-Air convection ovens I'm familiar with are electric even if the cook top is gas.
Posted on Jan 31, 2009
SOURCE: jenn air 88370
I have a similar Jenn Air oven approximate date 1982. It has a catalytic liner (colored a kind of dark charcoal  with paler flecks), so it is a continuous clean oven during normal cooking.  However, it also has the Accel Clean setting on the control knob. This increases the oven temperature to maximum and also runs the convection fan to burn off cooking residues. This allows the catalytic lining work at high efficiency, and burn off stubborn residues that are not removed at normal cooking temperature. The oven may emit smoke through the top door vents as the food residues burn off, so watch that you do not set off your smoke detector. I switch on the cooker hood fan and also put a fan in the kitchen window (blowing air out of the kitchen), to avoid setting off my kitchen smoke detector if I use Accel Clean.
Posted on Feb 28, 2009
erpaalai
  • 999 Answers
SOURCE: jenn-air electric range model JES9800AAB some kypad # not working
Unless they start working again after it has a chance to dry out the touch panel will have to be replaced. This happens when excess moisture gets between the very thin layers of the membrane.
eric
Posted on Jul 03, 2009
SOURCE: I have a jenn-air 30 inch downdraft electric slide
I have 30 inch slide in Jenn air and the black top is blistering and peeling. Jenn air replaced it one but the same thing is happening again. What can I replace this with.
Posted on Sep 22, 2009
We have a Jenn-Air electric slide in oven, model W131. It appears to work fine in all respects except that it doesn't come up to the set temp even though it tells you it has. Set at 350, it notifies...
if you changed the sensor most likely it will be the clock assy.it's not just a clock it also has a computer board built into it.you're missing a few letters off of the model number so when you call your parts store give them the full model number so they will sell you the right clock assy. i believe your board is around 150 dollars.if the elements are good and a new sensor all that's left is the board or clock assy. good luck with your stove.
May 23, 2011 | Jenn-Air SVE47100 Slide-In Electric...
I have a jenn-air 30 inch downdraft electric slide in range jes 9800- I have lost the owners manual. How can I get a new one? The power was off for several hours and I need to reset the clock/day. thanks...
Jul 13, 2009 | Jenn-Air JES9800BA Electric Range
Older jenn-air stove
on the front panel does it have a button that says CLOCK if so press that then with + button see if setting changes if so when it gets to the correct time stop and press clock again .
Oct 25, 2017 | Jenn-Air SVE47100 Slide-In Electric...
Kitchen range random chatter noise
could be clock motor or fan motor keeps running.
Jan 24, 2009 | Jenn-Air SCE30600 Slide-In Electric...
Clock assembly
my automatic cleaning setting in my oven will not heat up. I set "clean" on both dials and put the lock on, the fan comes on but no heat. Is there a certain system to turning it all on and the timer so it will work?
Mar 21, 2008 | Jenn-Air SVE47100 Slide-In Electric...
Jenn-Air Wall Oven up controls don't work
you have a touch pad issue, whats the model and serial ill look up the part for you, sometimes you can just get the key pad, sometimes comes sa a whole console or as part of the electronic control itself.
Mar 17, 2008 | Jenn-Air SCE30600 Slide-In Electric...
Clock on Model F120 stove Serial 53031577
just set the clock as if to clean , just remember to turn oven off in 2- 3 hrs wait 30 min then before trying to open dr.
Dec 17, 2007 | Jenn-Air SVE47100 Slide-In Electric...
Jenn-air range
have you set the clock for cleaning
Nov 19, 2007 | Jenn-Air SVE47100 Slide-In Electric...
Jenn air s136 stove won,t self clean
You've probably already read pages 34 through 37 of the owners manual for this oven. We had this stove in the house we bought and the owner wrote in his own directions, which seem to work fine:
1. Turn knob selector to clean.
2. Turn temp knob to clean.
3. Close and lock door.
4. Push enter button and turn dial clockwise to desired time.
5. Push enter button again.
You've probably already tried this, but just in case I figured I'd pass it along.
Nov 18, 2007 | Jenn-Air SVE47100 Slide-In Electric...
Kitchen Ranges Logo
101 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Craig Butler
Craig Butler
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
