Question about KitchenAid K45SS Classic Stand Mixer
Kitchen aid mixer
I am leaking oil at the front of mixer and gear seem to be making noise the motor runs good the oil seems to run out where you hook the beaters
  • 125 Answers
Take off the chrome ring around the rotator. remove the screws that were hiding under it. pull off the rotator and replace the "O" ring on the shaft.
Posted on Mar 09, 2009
60 qt Hobart mixer H600T makes buzzing noise and won't spin. The hook seems blocked, can't spin it manually. Opened the top part and everything seems fine. What can it be and how to fix it? Thank you
call in an electrician as it may be the start/run capacitor for the motor ( indicated by motor humming but not running)
the gearing will make it very difficult to turn the blades by hand as the motor will be spinning at either 1400 rpms or 2400 rpms down to around 50 rpms for the blades
Jun 30, 2016 | Hobart Food Mixers
My Kitchen Aid Pro5 squeals when it's running. I may have overheated it when mixing bread dough. It seems to be running okay. It just makes a very high-pitched noise now. What can I do to fix this?
Get a Copy of the Repair Part List of your model from Kitchenaid.com.
Most likely it is the Worm Gear (17) grinding at low speed the Worm Gear Follower.(19)
You don't have to replace it now, but it is best to open the Transmission Housing and
inspect all the gears conditions. Clear all the grease to expose them. The Bevel
Gear (21) sits right on top of the Worm Gear Follower. (See Repair Part List)
If its teeth look sharp and all metal shiny, then that is the source of your noises.
Eventually, all the teeth will be chewed away and the planetary assembly will stop turning.
Jul 01, 2011 | KitchenAid 450 Watts KM25G0XWH Stand Mixer
I have a KSM90 that is about 8 years old. It started leaking oil and the top of the mixer goes down into the bowl too far and it 'drags' the attachment along the bottom of the bowl and makes a generally...
It sounds like the Planetary Gear assy. has gear lubricant leaking into it from the gear case above it. This may not be that unusual so there may be 2 possibilities or a combination of both. The Gear Case is directly above the Planetary Gear assy. It is filled (sort of) with a food grade (assuming...I hope) grease that is necessary to keep things lubed. There are fiber washers and possibly an o-ring in the shaft assembly which should keep the grease from migrating toward your food. The Planetary Gear assy. is the part that rotates around on the business end of the mixer. It has a bronze bearing that is intended to run without lubrication. However it is a wear point and if worn sufficiently, could allow escape lubricant from the gear case above to drip into your mix. The Kitchen Aid Service Manual is a good source of info. You can get it as well as complete diagrams of the internal parts at:
http://www.goodmans.net/get_item_ka-4162075_kitchenaid-mixer-4162075-planetary.htm
You can also get parts and the KitchenAid Service Manual.pdf at:
http://www.mendingshed.com/kitaidparts.html
I know if it was my mixer, I'd give it a look. They're good tools and worth the effort!
Good luck.
DZII
Jan 02, 2010 | KitchenAid KSM90 Ultra Power Series Stand...
Leaking fluid, oil I think around the kitchen aid ring
Bucksmom, Sorry to hear you mixer is 'leaking'... I hate it when that happens. You don't mention how old or what model your KA mixer is? I assume you mean the band around your mixer with the Kitchenaid logo, when you say 'kitchen aid ring.
Your mixer does have an internal gear mechanism (transmission if you will) which converts the electric motors rotation into the mixer rotation and those gears are located within the mixer. The gears were lubricated at the factory, but depending on the age of your mixer and how it is used, it is possible that the grease has leaked beyond the gasket and that is what you are seeing now.
It is possible to disassemble the mixer to determine where the grease is coming from and troubleshoot if anything else might be wrong within the transmission.
Hopefully the leakage is not getting into your food being mixed. Kitchenaid Grease should be 'food grade' grease, but you still don't want to ingest it.
I hope this helps... Howard, Burke, VA
Nov 01, 2009 | KitchenAid Food Mixers
My kitchen aid mixer is leaking what seems to be a brown liq. maybe oil where the paddle inserts into the mixer.
This is another complaint about a Kitchenaid Standmixer, model K45SS. It leaks oil, out of the 1 year warranty period. Called the company. Got the standard line: Mixer must be run 2-3 minutes a week to avoid leaks. Nothing appears in writing about it in their manual. Oil leaks into food are dangerous. Please report these to the Consumer Products Safety Commission. After calling their service center a second time, after seeing all the complaints on this board, I informed them of my report to the CSSC. They said they would send a "return repair kit". I could send it in for repairs and if it was determined to be "defective" they would pay for the repair. The representative would not state that this is, in fact a "defect" and that I would be charged to have it inspected and repaired if it was not. Cost, anywhere from 50 to 150. I would be charged to ship it back if it wasn't defective and I decide not to have it repaired.
Read more: http://www.consumeraffairs.com/homeowners/kitchenaid_mixers.html#ixzz0TkgnvHLP
Sep 24, 2009 | KitchenAid KITCHEN AID 5 Quart Artisan...
Leaking oil from the main part. Kitchen aid mixer, only used a few times a year
Leaking of oil in a stand mixer is not necessarily indicative of a large problem.
Kitchenaid stand mixers are overpacked with oil to last the lifetime of the motor. If the motor sits idle for some time (is not used), the oil may begin to drip from the gears and settle. Oil leakage may primarily be seen from around the beater shaft or planetary action.
A stand mixer can lose up to a 1/4 cup of oil before it needs to be serviced.
It is recommended to run the mixer on speed 10 for 2 minutes in order to redistribute oil back into the motor. In order to prevent future occurences, this is recommended to be done every 3 weeks if mixer is not being used.
Jul 09, 2009 | Food Mixers
Kitchen Aid Mixer leaking grease around beater shaf
yes there are still pars avalible. the model will change but the internal parts are the same for the most part. there are screws on the back of the mixer. two on the metal band and one on the top of the motor houseing. open the mixer up you may want to disconect it from the base of the stand. to do this. see where greese is comming from. i dont think that it has a gasket you will see the gears and lots of grease you can take you finger and re smear the grease on the gears. but unfortunatly you may never get rid of the new noise. mine has been grinding for years. i use it 2 to 3 time a week. it works fine except for the noise which to me is not a big deal. if you need any parts you can get them from kitchen aid I hade to replace a gear once. (making to much pasta)
but they are easy to replace.
Jun 23, 2009 | Food Mixers
K45SS leaks lubricant
I went to Kitchen Aid'sKitchen Aid's web site and had an on line chat with a tect support person name Jessica. She told me that if the mixer is not used a small of oil will leak out. to fix the problem you must run the mixer for a few minutes every month or so. This seems to work.
Rick
Jul 28, 2008 | KitchenAid K45SS Classic Stand Mixer
Mixer motor shut down
Mine did almost the exact same thing one day. I have the Artisian Model, It would do it on any of the lowest speeds. Dont know if this will help you or not but I just ran mine the next day on all the way high with the spash guard on for making whipped cream for about 6 minutes full throttle and for some reason it hasnt went slow and shut itself off since then. Mine is about 7 months old. I called Kitchen Aid but their customer service all of a sudden seems to not know english worth a poo...
Try running yours on full blast for 5 minutes with something simple in the bowl. If its a 250 watt or higher make whipped water out of 2 cups of water and a tablespoon of cornstarch. Run it till you get what looks like whipped cream. Oh yea. Use the Balloon whip. The lubrication in the motor is supposed to last for at least 5 years but I have seen on numerous post's that if you run them on all the way for at least 5 minutes the oil will even out in the motor. Running the mixers at low speed alot will cause the oil inside not to move as freely since the motor doesnt heat up the oil in the gears.
Good luck.
Nov 15, 2007 | KitchenAid KITCHEN AID 5 Quart Artisan...
Kitchen Aid Classic Mixer
I have this problem too -it is rather common if you search the web. There was a suggestion posted on this site about what to do. See http://www.fixya.com/support/t125253-mixer_leaking_oil I have also read about other people taking it to a Kitchen Aid repair place where they repacked the grease for about $45. I took mine apart and there is gobs of grease around the gears. Right now I am still trying to figure out what to do. I am going to have my father look at it to see what he thinks since he is good with motors. The Kitchen Aid web site says that the grease is FDA approved, so at least it's not going to kill you if a little gets in your food. Their suggestion is to take it out and run it for about 5 minutes at least once a week. They say it leaks if it is not used often enough. That logic doesn't make much sense to me, but you could try it. Mine seems to leak more when I run it because the grease heats up and liquifies more. I hope that helps. I'll let you know what happens with mine, once it's fixed. Lisa
Dec 24, 2006 | KitchenAid K45SS Classic Stand Mixer
KitchenAid K45SS Classic Stand Mixer Logo
255 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
jack arons
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
