Question about Fellowes P600C-2 Shredder
Missing wastebasket to Fellowes Shredder
I am missing the wastebasket that came with my Fellowes P600-2 Shredder. I am unable to use the shredder because it has a switch that makes the unit work while it is seated over the basket. I have tried inserting something in the slot to hold the piece of metal switch & sometimes it works & sometimes it doesn't (and I am also concerned as to the safety of doing this. Any assistance would be greatly appreciated. The company was of no help as where the local office supply stores I approached for help in locating a replacement.
Sincerely,
Ms. Davis
  • maltamary Mar 14, 2009
    Can you please take a photo of the inside of the waste basket? Thanks in advance
  • 3 Answers
I threw the Piece of Junk MIC-part away a few days ago due to the broken and non-available nylon gear. I still have the wastebasket part- the most reliable section of the entire assembly!
I'll mail it to you if you pay postage. (unless you live where I do).
Buy American!
+Bill+
Posted on Aug 30, 2009
I have a P600C-2 wastebasket - and the unit only runs in reverse. We need to put our two pieces together!
Posted on Mar 10, 2009
How do I oil the shredder
Found this that should help:
Oiling Instructions for Fellowes Shredders
Why and How Often: Regular oiling of cross-cut and micro-cut shredders is a necessary maintenance step to help keep your shredder functioning properly and prolong its life. Several factors determine how often you should oil your shredder-such as the type of paper being shred, the amount of paper being shred, and whether you shred only occasionally or continuously for long periods of time without stopping.
  • As a general rule, it is a good practice to oil your shredder each time you empty the wastebasket, or once a month.
  • Micro-cut shredders need to be oiled more frequently-ideally after every 15 minutes of use.
How To: Press and hold down the reverse button on your shredder. Put the tip of the oil bottle in the paper entry and make one or two sweeps across the cutters while gently squeezing the oil bottle. Continue to run the shredder in
reverse for another 10-15 seconds.
What to use: It is recommended that you use Fellowes Oil to oil your shredder. You may also use other oil designated for shredder use.
Do not use any oil or lubricant that is dispensed from an aerosol container.
Do not use any petroleum-based oils or lubricants. Use of such oils or lubricants will void the warranty on your shredder and could cause serious injury, as they are fire hazards when used with electronic devices.
http://shop.fellowes.com/oiling-instructions.aspx
Jul 04, 2014 | Fellowes Office Equipment & Supplies
How do I get top off to clear Paper Jam on Fellowes PS-12Cs
FELLOWES SHREDDER
In case of a paper jam , which may occur if the shredder is pushed beyond its specified capabilities, press the control switch to the off [O] position and empty the basket if full. Then:
1) Press and hold control switch in reverse [R] position and attempt to back paper out of shredder.
2) If shredder jams in reverse mode, press control switch to automatic [I] position and attempt to continue shredding operation.
3) If shredder jams again, alternate control switch slowly between reverse [R] and automatic [I] positions to attempt to move jammed paper completely through shredder.
If you are unable to clear the jam using this method, turn off and unplug the shredder; remove the wastebasket from cabinet and carefully remove any paper extending below the cutting cylinders; empty the wastebasket; insert wastebasket and repeat jam clearing procedure.
May 23, 2014 | Fellowes Powershred PS-12Cs, 12 Sheet...
Can you take apart a fellowes PS-12C
FELLOWES SHREDDER
May 23, 2014 | Fellowes Office Equipment & Supplies
SAFESENSE ISN'T WORKING ON C-480C FELLOWES
Use a cotton bud dipped in alcohol and clean sensors
Run shredder once a day in reverse for 15 seconds to clear cutters
Empty wastebasket when bin full indicator light is illuminated using b0
If this does not solve the problem goto
www.fellowes.com for an extensive on-line support section
Feb 27, 2014 | Fellowes Manufacturing Powershred C-480C...
Runs reverse auto
From your manual!
If you are unable to clear the jam using this method, turn off and unplug the shredder; remove the wastebasket from cabinet and carefully remove any paper extending below the cutting cylinders; empty the waste basket; insert waste basket and repeat jam clearing procedure.
Feb 01, 2014 | Fellowes DM12C Shredder
There seems to be a power ise when switch ingages breaker shuts off
I own a Fellowes PS 60 shredder.
I DO NOT THINK THE LINK WILL HELP YOU, BUT AT LEAST YOU WILL HAVE IT.
I advise you NOT to use your shredder if it is causing the cicuit to shut off_it may start a fire!
Here is a link to the manual for a Fellowes PS60 Shredder.
Maybe it will help you in resolving some of your problems.
https://app.box.com/s/q3r8jlatlfskvgyh5ne6
Fellowes Shredder PS60
Jan 11, 2014 | Fellowes Powershred PS-60 Shredder
My fellows jbo1 jamed and then stopped running is there a reset buton?
Chances are it's over heated.
Ensure the wastebasket is empty then move power switch to the REVERSE position. This will reverse the jammed paper out of the shredder. If shredder jams again, alternate control switch slowly between REVERSE and AUTO (l) positions to attempt to move jammed paper completely through the shredder. If the shredder jams in reverse mode, move the switch to AUTO (l), depress the manual forward button located on the center of the shredder head and allow to run for five seconds. If jam does not clear, move switch to REVERSE again and allow to run for five seconds. Repeat this process until jam is cleared. If necessary, turn off shredder and use care to grasp the paper and carefully pull out to clear jam. Once cleared, move switch to AUTO (l) to continue shredding. The jamming may be happening because the cutting cylinder needs to be oiled. See oiling instructions below.
From fellow's website: http://www.fellowes.com/fellowes/site/support/support_troubleshooting.aspx#jammed
Dec 15, 2010 | Fellowes Office Equipment & Supplies
Shredder stopped suddenly and won't work
If you are unable to clear the jam, turn off and unplug the shredder;
remove shredder head from the wastebasket and carefully remove any paper extending
below the cutting cylinders; empty the wastebasket; reassemble the shredder and repeat
if still do not run follow the next steps:
1. Make sure shredder is plugged in and
switch is in automatic [I] position.
2.Wait 15 minutes for shredder to cool
down before trying again.
3.make sure that the shredder head is in the correct position, if is not it will not run
please rate the post for i to know do this is helpful if not i will know by your rate that i should post some more information
Jan 11, 2010 | Fellowes P70CM Shredder
Fellowes P600C-2 Shredder Logo
263 people viewed this question
Top Fellowes Office Equipment & Supplies Experts
Jim Keysor
Are you a Fellowes Office Equipment and Supply Expert? Answer questions, earn points and help others
