Question about Honeywell Power Humidifier: Furnace Humidifier/ Humidifier
Furnace blower blows cold air
Hi All,
Thanks in advance for any guidance! I have a Trane model# AUD140R960J1, Serial# R152N3X2G. A few days ago the units blower motor went out (four flashes on the board's IFC codes). The gas had been igniting and burning until the board shut off because the motor was not turning on.
So, I removed the motor and got a new one in its place. When I first fired it up it, it cycled through the ignition, burn and blower phases correctly. All seemed great. I went to run some erands, returned a few hours later and the gas was no longer burning and the blower was just blowing cold air through the house? I've tried restarting, killing power and restarting several times and all I get is the blower starts running with no gas flow or igntion attempting to fire. Also, the board gives me the four flashes again? Any suggestions? Thanks again!
Regards, Thane Schaffer
  • thaneschaffe Mar 09, 2009
    Well, I went ahead and cleaned everything out and re-checked the sensor and ignitor (both need minor cleaning, no cracks and looking like new now)...but same problem persits.
    The new motor wasn't an identical match..but the motor guy said it should be close enough for my unit. The wires-to-board in the old motor mapped as Red->Lo Heat, Blue->Hi Heat, Black->Cool, Yellow->Hot Park, and White->CIRC.
    The new motor didn't do a Hi Heat (4th speed?). So, my motor guy said to use the wiring a little differently and that it shouldn't matter with my older (80% 10 year old Trane) as follows: Red->Lo Heat, Blue->Hi Heat, Black->Cool, and Yellow->CIRC.
    Thanks again for any other thoughts on this problem?
    Novelist:
  • 189 Answers
It is possible that you did not set the new blower on the proper speed. Black wire is high. Blue is medium. Red is low. If the fan is operating to slow it can run to hot and trip the high limit control. Make sure the filters are clean. When the old motor went bad, the problem might not have been discovered rite away your high limit control might need to be changed.
Also anytime you work on a furnace you can kick up some dust. Always clean the flame sensor.
Good Luck
HVAC Teacher
Posted on Mar 08, 2009
My lennox furnace works just fine except that 25% of the time the fan keeps running when it shouldn't and blows cold air
You are using too restrictive of an air filter. If the codes you are getting off the lights says anything about a high limit this is the cause of your blower running all the time. Use a less restrictive filter or have your contractor install a media filter in the system. if you reset the furnace and it does not stop running the blower you have a stuck limit switch and may have to get another or call a service tech to reset it or replace.
Oct 27, 2013 | Honeywell Power Humidifier: Furnace...
Honeywell HE260 leaks somewhere
Neither, even if the solenoid or humidistat stick, it should always drain properly. Is the unit mounted on the cold air return duct or the supply plenum? If it's mounted on the supply plenum, the water panel might be getting blown forward and spilling the water. High efficient furnaces also can leak water on the floor if its drain is restricted. If hum. is mounted on return duct make sure drain is clear by blowing through it. On Honeywell hum's I've seen the rubber hose from the solenoid valve to the distributor tray leak too, check the rubber 1/4" hose.
Dec 28, 2009 | Honeywell HE260A1010 Whole House...
Dry house, albeit have two april aire humidifiers
The reason you can not run your humidifier while the blower is off, is because all the humidity would condense almost immediately and rot out your duct work. If you find that the humidity provided during the cycle of your furnace is inadequate, I would suggest purchasing a table top unit, and keep it in the room where you spend the most time. So, the answer to your question is no, you can not run a humidifier while your blower motor is off. Hope this helps.
Dec 13, 2009 | Aprilaire 700 Humidifier
Cold air and smell
replace the humidifier pad every season you may also want to install UV lights
Apr 02, 2009 | Aprilaire 550 Humidifier
Hooking up a used 550 to a new 80% trane UD-R9V,
In this situatioin you'll eed a second transformer 110volt to 24 volt to relay from w to common to operate only when furnace being called for.
Feb 07, 2009 | Aprilaire 550 Humidifier
Ruud 90 deluxe plus, in the last week blower motor noiser
George, make sure the belt is not loose flapping around making all that noise.
Not hard to change if you can get one from an hvac friend, they won"t sell to homeowners normally.
Jan 18, 2009 | Honeywell Power Humidifier: Furnace...
Runs without the furnace blower blowing
sounds like wired incorrectly. always do this? not wired into blower circuit correctly
Dec 11, 2008 | Aprilaire 700 Humidifier
Blower won't stay lit
If the fan motor is blowing out the burner then is there a hole in the heat exchanger
Jul 18, 2017 | Honeywell Power Humidifier: Furnace...
Humidifier won't turn on with furnace fan set to Auto.
There is a devise called a current sensing relay (a little black box that hangs on a blower motor wire that senses current from that wire) If you have such a devise it should hang from the white (common) wire. Loop the wire through twice.
Nov 23, 2008 | Aprilaire 600 Humidifier
IFC on Trane furnace
If the manufacture says it is the IFC then you should have the IFC checked by the company who installed it if it is under warranty still
Jun 06, 2008 | Honeywell Power Humidifier: Furnace...
Humidifiers Logo
455 people viewed this question
Top Honeywell Humidifiers Experts
Dennis
Simon Benzekri
Level 1 Expert
jdthefixer
Are you a Honeywell Humidifier Expert? Answer questions, earn points and help others
