Replaced the secondary guides and threw a vvt sensor code. I took everything back of and the sprocket marks aren't lined up with the chain marks
SOURCE: timing chain wear
That is correct. If your engine is whinning at about 2000 rpm's and its a high pitch whine, you need upper timing chains and chain tensioners. aka plastic gizmo as you called it. The timing chains ride off the plastic portion of the tensioner causing the noise, basically the chain is riding on steal stub from within the tensioner, that's where the noise is coming from. Waranree on this is 5years or 60000 miles which ever comes first. And the new tensioners are updated parts.
SOURCE: 2002 nissan maxima gle timing chain or sprockets
Ok, first off you need to take your vehicle to a Nissan dealer for a second opinion. Its not at all common to need a T-chain @ 58,000 miles unless you dont take care of your car and or you beating the snot out of it like it was stolen. What is the symptom? What caused it? When did it start? Second, this is not something an amature could/should do as it is very involved and there are alot of things you could potentially mess up. Third a new engine(long block), parts alone would run approx. 6-8 thousand dollars. A used engine could be an option and could run approx.1500-2500 dollars depending on mileage. Hope this helps and good luck.
SOURCE: how to set the timing chain
line the marks on the chain to the sprokets and it should be ok, is that what we call a qx, a32 chassis seires?
SOURCE: Where to put the timing marks on a 96' nissan 2.4 liter
the timing chain tensioner is hydraulic and either out of adjustment or defective. You need to remove the timing chain cover and reset the mechanical correlation between the crankshaft and the camshafts. also the other ignition time marks are on the crankshaft harmonic balancer and the cam cover. Do not crank the engine with the timing out of sequence or you'll destroy the engine.
SOURCE: timing chain on 2006 Nissan Pathfinder
same thing, get a used engine, ill sell u mine with 135K miles..
first it was my transmission at 87K, the whining came at 60K miles, but it costs 2K to install, just dump it or bring back for trade in, those dicks..
