Question about American Standard "Ceramix" Single Handle Faucet--Polished Brass Finish
How to put single handle Am. Stand. kitchen faucet back together
My father took apart my American Standard kitchen faucet to replace the O ring.  However, he didn't watch the order and there is one plastic split ring that we are not sure where it goes. It seemed to be on the base, but when we put it where we thought it went we can't get the sleeve over the inner parts.  It is causing a bigger problem than when we began.  I would like to know specifically how to put this faucet back together so that it works and doesn't leak.  I would appreciate your instructions.
    Problem Solver:
  • 6 Answers
Check out this webpage:
http://www.americanstandard-us.com/assets/documents/amstd/parts/Parts_599.pdf
Posted on Mar 09, 2009
Double faucets cartridge replaced still drips
My best advice
is to believe everything you just experienced...
(Perhaps an UNSEEN flaw in the "MONOBLOCK")
Buy the replacement faucet... shop around:
I spotted it on eBay... (number not close...)
((but still reasonably priced)).
AMAZON
American Standard 1480 101 002 Seva Single Control Lavatory Faucet with...
Also went to eFaucets (but their site was stunned
(normally GOOD resource... ))
http://efaucets.com/
eBay (concierge... buyer protected... FREE ship'n)
American Standard 1480 150 002 Seva Monoblock Single Lever Handle Lavatory...
Save the old one (parts)and DIAGNOSE
it in your SPARE TIME...
Hope this helps
Carnac the Magnificent
Oct 19, 2017 | American Standard - Lavatory Faucet -...
How to fix leaky American Standard single faucet kitchen sink
The A-S single lever kitch faucet is terrible. If it is the one I think it is, then it has three screws that mount the cartridge down into the faucet body.If these are not torqued perfectly evenly, the faucet leaks. I suggest getting a Moen to replace it.
Apr 18, 2017 | American Standard Plumbing
Our American Standard kitchen faucet has become hard to swing from one side of the sink to the other. What could be causing this? Is there a bad part?
Hi! If there are no leaks from around the spout, you can remove the spout and apply silicone lube to the spout o-rings and resemble. If it is still hard to move ,replace the o-rings.
Jul 15, 2011 | American Standard 4205.001.021 Reliant+...
I have an american standard kitchen faucet, when the handle is half open I get a leak, at home depot where I bought it two years ago, they told me I need to take it apart to see which kit will repair...
The single handled faucets have a valve cartridge which needs to be replaced when it leaks. Disassemble the handle to find the valve inside. Take the valve to the hardware store to be sure you get the right one and reassemble. To disassemble, pop the cap off the lever, unscrew the single screw, then use slip-joint pliers to loosen the retainer nut. lift the cartridge out with pliers taking note of the direction of the notch at the top of the stem. Be sure to reassemble with the notch facing in the same direction. You should replace and lubricate the O-rings when you change the valve cartridge.
Since you have the numbers for that particular faucet, you might want to call around to find the cartridge first. Different models have different valves, so be sure yours is correct.
Oct 08, 2010 | American Standard Kitchen Faucet 6310 020...
Faucet is leaking from just under the handle when you put water on
"O" ring seal probably need replacement water off disconnect handle and remove valve remove "o" ring and replace
Jan 26, 2010 | American Standard 2021.600.295 Ceramix...
Kitchen faucet single handle pull-out. The base of
I have the same problem with an American Standard Reliant Kitchen Faucet that wont swivel anymore. I called American Standard and they are sending me the replacement parts to fix it free of charge, I have had mine 6-7 years and they said it was under warranty. Call 800-442-1902. Good Luck
Jan 09, 2010 | American Standard Kitchen Faucet 6310 020...
I have an American standard center spigot one handle, it is dripping, how do i get apart to repair
first turn the water off,then pull the handle off unscrew the top plastic piece pull neck off replace 0-rings,or cartridge what ever is needed.
Jun 06, 2009 | American Standard Kitchen Faucet Ceramix...
How to replace sprout seal kit?
After you remove the handle, the chrome cap should either snap or spin off.It also may come out with the cartridge... There are 3 screws that hold the cartidge in the faucet...take them out and you should be able carefully work the faucet are off of the core of the faucet. Put a little cooking oil on the o-rings after you install the new ones... just to allow the faucet arm to slide on without damage... Hope this gets you dripless!! Let me know if you have a question. K
Jun 05, 2009 | American Standard 4175.200.002 Colony...
How to replace sprout seal kit in american standard faucet ?
just pull straight up,wiggle back and forth,the o-rings are holding it on .
Jun 05, 2009 | American Standard 4275.550.002 ColonySoft...
Replace the seal on the 470 DST single handle pull out faucet
Turn the water off at the faucet, remove the handle and the retaining nut that is apart of the trim. You will see where you can use a wrench to remove it. The ball assembly will come right out and you can replace the washers right below it. Put it back together and if needed, tighten the tension ring that is on the retaining nut (usually grey or white in color) so it won't leak water around the ball stem. Good luck.
Apr 02, 2009 | Delta Faucet Delta 470-BL-DST Signature...
American Standard "Ceramix" Single Handle Faucet--Polished Brass Finish Logo
768 people viewed this question
Top American Standard Plumbing Experts
john h
Steve Wood Plumbing...
Level 1 Expert
TED
Level 1 Expert
Are you an American Standard Plumbing Expert? Answer questions, earn points and help others
