Question about Creative Labs Sound Blaster Live! 5.1 Sound Card
Hey need help got desktop with i think onboard audio. in sounds and audio device properties it says no audio device i have tried everything. can you help?
  • oconjr3 Mar 20, 2009
    it's windows xp. I think it was used as an office computer i think so they propably turned it off somehow so they wouldn't be messing around.
  • Shakeel Muradali
    Shakeel Muradali May 11, 2010
    I would be glad to assist you in this. First off, Please if you could advise what version of Windows you are running as the steps involved in resolving this would be different for each type of problem...
    Sergeant:
    Champion:
  • 224 Answers
Yes it is possible. Now i need you to click on start /control panel
Here make sure you are in classic mode, you should be able to find an icon called "system". to change to classic mode, click on the classic mode option on the top left.
In the system window, click on the tab for hardware and then click on device manager
Check to see under "sounds and other hardware" if you can see your sound card installed.
Also, check to see oif there is anything listed under "other devices"
Now, another information i would need is the make and model of you PC
Posted on Mar 20, 2009
My computer can play audios and videos but cannot produce any sound and i have tried to play both CDs, Flash and some music saved inside still the same problem occurs. what can i do? thanks.
THIS WILL HAPPEN IF:
-if your speakers are plugged in the wrong hole
-if the power adapter from the wall to the speaker fails
-if the speakers are muted in windows sounds properties (double click speaker icon by clock on desktop to check-making sure the MUTE box is NOT checked)
-if the sound card drivers are corrupt or not installed
(right click "right click "my computer" left click "properties"- click the "hardware" tab at the top- click on the "device manager" button
scroll down to where it says "sound and audio" with a + next to it. if there is a yellow ! or ? it means that your software drivers for the sound are corupt or missing and will need to be reinstalled using the install disk or downloaded drivers from the dell website which are free.
Regards.
May 25, 2010 | Dell OptiPlex 170L PC Desktop
IBM Desktop no sound after i tried to connect it to Television
check the connectiion cable and tv setting faults, if their is non then know your audio jack pin port is faulty. in case of the jack pin port fault you need to acquire pci audio card that you insert at the extesion slots or a usb audio card.
Nov 19, 2009 | IBM ThinkCentre S50 8183 - P4 3 GHz...
My unboard sound card is not working. In the sound and audio devices properties window it shows no audion device. How do I get this to work?
One option that you have is to re-install the drivers. Because this hardware is onboard, you will have to specify what model computer you have before anyone can provide you with help on how to find those drivers.
Once you download and install the drivers for your motherboard, you can go back to device manager to check the status of you audio. If it still doesn't work after re-installing the audio drivers, I would suggest that you totally disable the onboard audio and install an expansion card with audio ports in one of your open PCI slots.
If you will post a comment providing information about the model computer and/or motherboard you're using, it will be much easier for someone to help you find the appropriate audio drivers. From that point, you can figure out whether or not the onboard audio is still functioning.
Thanks for using Fixya!
Apr 10, 2009 | HP Computers & Internet
How do I disable the onboard sound in an Aspire m5621 desktop
there is normally an option in bios to turn off. Are you sure there is no option? Its normally under onboard controller/etc. When you go into bios try holding CTRL+F1 as for some bios's this enables an advanced menu.
If this does not apply then can you go into device manager and sounds/audio controllers? It should be listed there, generically its ac97 audio, or something like this. Right click, properties, uninstall/remove device.
I hope this helps.
Feb 01, 2009 | Computers & Internet
Soundcard
Hey there, the HP bios is pretty smart - it should automatically detect a new sound card and switch off the internal one when installed - alternatively you can go to the 'system devices' panel and disable it in the software as well.
hope this helps
cheers
Nov 19, 2008 | HP Compaq dc7600 Convertible Minitower PC...
NO SOUND AT ALL
First check if the onboard sound is enable on your computer's BIOS, so restart your pc and press the DEL key on your keboard so you can access it then make sure the audio is enable if its disbale enable it then try now if it will working.
If the audio is enable on BIOS and still no sound check if the audio is installed properly under device manager Right click on Mycomputer>properties>hardware>device manager>then look for the audio device that should be enable and working properly if not you need to reinstall the driver for it.
Jun 06, 2008 | Gateway 500GR PC Desktop
Audio issues
remove the sound card from the board and put it back in. Enter the mixer, by clicking on the speaker icon at the buttom of the screen or going ito axcessories / entertainment / volume control
Click device and put your sound card as the default device..
If that dont work you might want to try remove the sound card and using your onboard audio or getting a new card..
just rememer to set what ever device you are using as your default device..
Jan 14, 2008 | Gateway 5200X PC Desktop
Audio Devices
Onboard Audigy Drivers
Onboard Sigmatel Drivers
try the audigy drivers first, all install instructions are provided on the download page, if it doesn't work, try the sigmatel drivers.
hope this helps,
trin
Nov 19, 2007 | Dell Inspiron™ E1505 PC Notebook
Sound card not detected
The yello esclamation mark signifys you need up dated drivers then it will go again.
Sep 14, 2007 | Ensoniq (6000708) Sound Card
NO Audio even after putting in own sound card
Difficult to diagnose from afar but go to Start>Run, then type 'dxdiag' without quotes and see if; when it does a sound and video test anything shows up.
Nov 13, 2006 | Gigabyte GA-8IG1000 Motherboard
Creative Labs Sound Blaster Live! 5.1 Sound Card Logo
41 people viewed this question
Top Creative Labs Computers & Internet Experts
micky dee
kevinmacleod
Level 1 Expert
Are you a Creative Labs Computer and Internet Expert? Answer questions, earn points and help others
