Question about Maytag MZD2766GES Side by Side Refrigerator
Maytag MZD2766GE side by side, fridge not getting cold.
Fridge not getting cold, freezer not freezing good either, ice in back of freezer, thermostat set at 8 now, issue just happen all of a sudden. Checked back, motor clean, can’t see any visible leaking.
  • 6 more comments
  • sexyl976 Mar 09, 2009
    Thanks for your suggestion, it was the evaporator coil, it was packed with ice. I unplugged the fridge, removed the coil cover on the freezer side, took my blow dryer, (I read where someone else did that) melted the ice, freezer and fridge works fine now. Thanks for your help. Now I don't have to pay a repair man.
    SexyL of Lansing, Illinois
    Thanks again, I will print this info an keep it handy.
    SexyL of Lansing, IL
  • sexyl976 Mar 11, 2009
    Thanks bobby, did you know that there is now a recall on these fridge's, Maytag MZ (a list of models), get your model number and serial number handy, recall for side by side models only. 866-231-1478, get ready to be on hold for a long time. Did you replace the timer yourself? if so was it hard?
    SexyL Lansing IL
  • sexyl976 Mar 12, 2009
    Thanks Bobby for that tip, I really appreciate it. Have a wonderful day.
    SexyL from Lansing, IL
  • Anonymous Mar 13, 2009
    same problem. forst buildup kept fridge from getting cold. tried bridging l1 and test on ADC board with screwdriver but could not get a manual defrost to start. ohm'd thermostat and heater ok so assuming its the ADC board.
  • Ice-less Mar 24, 2009
    Neither freezer or refrigerator is cooling properly. Ice maker not making ice. I pulled away from the wall and immediately noticed the electrical connection to the fan motor was disconnected. I plugged it in and the fan began blowing. I had assumed that the problem was solved, although this morning the 'frozen' foods were less frozen than last night.
    Any ideas?
  • russellgh Apr 10, 2009
    Any suggestions on what I should replace?  I have read about "timer for the automatic defrost" going out.   I also experianced the weird noise coming from the cool side then after about a month the refeidg side would not get cold...54 degrees was about all it will do.
    Any ideas?
  • Anonymous May 13, 2009
    coils frosting up low temp in frig
Your timer for the automatic defrost is defective. Replace it. If you thawed out the back of the freezer, this could be good for 3-7 days and it will freeze up again. I had the same trouble.
Bobby Johnson
Posted on Mar 10, 2009
  • bigbob1941 Mar 11, 2009
    I had it replaced by some idiot around our house and it didn't work. I ordered me one on line and when it came in, I replaced it and found out that the first one wasn't plugged in properly. I went ahead and plugged it in properly and it's been working ever since. It's real easy to replace. It's in the refer side at the very top behind that plastic housing where the light is. It just pops out and I think there are a couple of screws holding it somehow.
    Maytag people will tell you part number for the defroster timer and you go on line or e-bay and find one cheap.
    Thanks for the info about the recall.
    Bobby
  • 400 Answers
Freezer cabinet evaporator coil frozen preventing airflow and therefore cooling to happen. This can be because of the fanmotor not working, or the defrost system being faulty
Posted on Mar 09, 2009
  • Shane Seaman Mar 09, 2009
    Just be careful, you may have just delayed the problem. Still make sure that the fanmotor is working and secondly, that it is defrosting properly. If the fanmotor is working and it ices up again in a short period you can safely say that the defrost system needs attention
Maytag performa fridge model# ptb1753grw freezer freezing up and the fridge not getting cool. i defrost freezer remove the ice then the bottom fridge gets cold again. but it keeps freezing up again.
You have one or more of your defrost components that are bad. Defrost heater, defrost thermostat, and defrost timer or board depending on model are the 3 components.
Nov 02, 2017 | Maytag Refrigerators
Fridge warm, freezer has frost on back panel & is defrosting, fans work, just changed defrost thermostat, no air is moving from freezer side to fridge side, drain pan under fridge is dry
this fan needs to run when the compressor runs,check fan blade for being jammed by ice if you have this much ice on back wall as ice will stall motor,if no fan there will be no cool air to refrige compartment also the defrost drain tray will fill with water then freeze over which in turn floods the freezer floor and refrige compartments cause it cannot drain to the pan in the bottom
May 11, 2012 | Kenmore Side by Side Refrigerator
Hello, Problem with Maytag plus Side by Side refrigerator model MZD2766GE.The Freezer part is working fine but the fridge part is not cold at all even after I adjusted the temperature to number 8. I do not...
You most likely have a defrost heater and/or defrost term switch. (switch is built into heater on your fridge).that needs replaced causing your coil to completely freeze up and blocking cool air flow to fridge side. Here is the part you need to order.
http://www.appliancepartspros.com/part_details.aspx?part_id=4069923
Thanks, Randy
Feb 07, 2011 | Maytag MZD2766G Side by Side Refrigerator
Freezer works fine on my Maytag side-by-side refrigerator, but refrigerator is not cold enough, there is is ice accumulated inside the vent between the freezer and the frig., specially on humid days.
Defrost your fridge with a blowdryer in the freezer after you remove the freezer back panel. Get the ice out of your exhaust pipe going to fridge. Your evaporator fan should be running, either your defrost heater is bad or your defrost thermostat is bad. I ussually replace both. Good luck rate me if I am correct.
Aug 26, 2010 | Maytag MSD2756G Side by Side Refrigerator
I have a side by side refrigerataor. The refrigerator side is not cold enough. It is a Maytag model MZD2766GE.
the most common problem is restricted or no air flow from the freezer compartment.
when the unit is in the cooling mode then open the freezer door and listen for the evaporator fan if it not running then you need to replace it.
If you here it running look for and excess ice build up on the back wall the evaporator may be frozen over indicating a defrost issue. the thermastat control for the fridge side only may need to be change or the defrost timer or sensor may need to be change.you can use a blow dryer and defrost the freezer compartment thourghly and see if the fridge gets cold.you may also need to check the damper motor in the fridge to see if it is opening or closing properly.this is usually located in the top left side of the fridge and the way to check it is to turn the unit off then back on and listen for the motor to open or close the damper.
Feb 24, 2010 | Maytag MZD2766GES Side by Side...
Freezer is very cold, refrigerator not cooling on Maytag side-by-
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
s
Nov 25, 2009 | Maytag MZD2766GES Side by Side...
Amana BR18 Doesn't get cold
Mine is doing the same thing
Jul 05, 2009 | Amana Freezers
Maytag Widey Side not cooling enough
Check to see if you have frost on the back panel of your freezer in your fridge. If you do your coil is frozen over and you'll have to defrost your freezer. I just did mine cause mine wasn't cooling properly on my fridge side. If it is that it's going to fill the pan under your fridge and overflow.
Apr 19, 2009 | Maytag 25.6 cu. ft. Wide-By-Side...
Coil freeze up.
sounds like you have a problem with the defrost timer. usually they are at the back on the bottom of the fridge and have a little nob that is supposed to turn as a clock.
mark it and come back later to see if the timer moves, if not then there is your problem
Apr 10, 2008 | Frigidaire PLHS267ZA Side by Side...
Maytag fridge
Without knowing the type of fridge(side by side, freezer on top etc.) all I can offer is this: Somewhere between the freezer and the fridge there's an opening thermostatically controlled to transfer cold air from freezer to the fridge. Most have a fan to move the air. So either the fan (if so equipped) stopped, and need to replace, or opening is stuck closed, or plugged.
If freezer is working fine, this is the only problem I can think of.
Hope this helps
Dec 15, 2007 | Maytag MTB1504A Top Freezer Refrigerator
Maytag MZD2766GES Side by Side Refrigerator Logo
3,055 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
