Question about Kenmore 63942 Dryer
Dryer was working then it just shut off and will not start again. light on inside still comes on so it still has electrical connection.
  • Kenmore Master
  • 3,361 Answers
Check the door switch.
The start switch.
The thermal fuse located on the dryer exhaust vent on the rear. It is 1 and 1/2 inches long and 1/2 inch wide and white in color.
Posted on Mar 11, 2009
Electric dryer runs shuts off then starts again on its own
This could be a bunch of different things. #1 detach dryer vent and clean out. Try running dryer with vent not attached for 10 seconds. (Warning, lint and sand will likely come blasting out the back. Reattach and try. #2 Likely is that you have lint buildup inside. Unplug dryer. Remove back cover. Clean air path from exhaust through lint trap. Look inside or remove heater as well. You are likely overheating the dryer and the sensor is shutting it down. #3. Unplug the heating element and then run dryer. Does it shut off still? No Then the sensor on the heating element is bad. Yes then the timer is bad.
Jan 13, 2014 | KitchenAid KEYS750LQ Electric Dryer
Frigidair galaxy electric dryer comes on for a few seconds and shuts right back off error code reads PF
PF means Power Failure,try unplugging the unit for 20 minutes to possibly clear the computer control inside the unit,then try starting it again,if this doesnt help try unplugging and replugging in all connections in case theres a bad connection,lastly if this doesnt solve it,replace the control board
Feb 12, 2012 | Frigidaire Dryers
Kenmore 80 series electric dryer Model - 110-60882990 The dryer won't turn on. Once the start button is pushed it makes a single clicking noise. If I open/shut the door and push the start button...
check the actual door switch,, you can jumper it to see if this is the problem, Just connect the 2 wires together , if this cures the problem replace the switch
May 25, 2011 | Dryers
We have a Kenmore dryer series 90 model #11066904690 that we started spelling a burny smell. We took off front panel and vacumed out we tryed to use it again and same thing happed and then shut off...
This could be a couple of things. But more than likely the motor has burned out. It could be a wire has burned off, or even the timer has burned. Since you say it "shut off completely", I would have the power cord checked where it connects inside the dryer. UNPLUG it from the wall first! I have seen one wire burn off there from being a loose connection. There is a cover plate you can take off and look inside.
Jul 29, 2009 | Kenmore 659 Electric Dryer
Kenmore electric dryer shuts off after 5 minutes and won't restar
when you try to start it again do you hear a humming comeing from the motor? can you jump start it by turning the drum while holding the start button? If you say yes to these questions you have a bad motor.
Jun 21, 2009 | Dryers
Whirlpool LER8620 electric dryer, shuts off at random. When it
Whirlpool Dryer Won Start
Sounds to me like a thermal fuse. The link gives you multiple scenarios and you can even order replacement parts. I have used it myself with success on washers and dryers. Good luck!
Sep 13, 2017 | Whirlpool LER7646E Dryer
Kenmore 90 Series Electric Dryer will not run
chech to see if your belt is broken. It may have a belt switch
Oct 28, 2008 | Kenmore 62602 Electric Dryer
Dryer shuts off on own lights blink
Turn off breaker wait an hour turn back on.
Apr 03, 2008 | LG DLE2514 Electric Dryer
Kenmore 63942 Dryer Logo
70 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
