I am trying to find a user manual for a Sears Kenmore model 158.13170. Sears no longer has them.
SOURCE: instructions for theading a Sears Kenmore Sewing machine model 158.14000
all machines thread the same. TTN tension,take up, needle.
Beginning
with the spool, guide the thread through the thread guides to the
tension assembly. Pull the thread through the tension assembly and test
it to make sure the tension is working correctly.
(To do this
test,adjust your tension setting to normal or medium or 5 or something
in the middle. Raise the presser foot and pull the thread through the
tension. It should pull easily!! Lower the presser foot and pull the
thread. It should pull noticeably harder.) If it passes this test,
continue up through the take up lever,then down through the thread
guides to the needle. Make sure your needle is fully inserted and
turned the correct way.( If you load your bobbin case from the left
side,the needle rule is normally FLAT to the RIGHT is RIGHT. There are
some exceptions. If you have a newer style drop in bobbin or your
bobbin case loads in the front then the rule is FLAT to the BACK.
To wind the bobbin, guide the thread around the thread guide on
the left top of your machine, then to the bobbin winder. Wind the thread around the bobbin several times, place the bobbin on top of the bobbin winder, push it against the wheel and press the foot pedal. It should stop winding when the bobbin is full or you take your foot off the control
Sewman7
SOURCE: I need a manual for a Sears Kenmore sewing machine model 148.231
Try www.sewing-machine-manuals.com and click on relics and don't be put off by the word relics
SOURCE: need user Manual download for
Your requested links are as follows:
http://www.thetreadlersvillage.com/Kenmore1650Manual.html
http://www.sewconsult.com/kenmore/158%20manuals/kenmore_158_source_manuals.htm
You can copy and paste them in your browser window. When copying please copy the exact address.
SOURCE: User Manual for Kenmore sewing machine
Here are all the parts you need:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=14813101
The manuals are not available. Unless an another owner has one to share.
SOURCE: Need manual: Kenmore sewing machine 158.9
Those books are long since out of print. Try contacting sewing machine stores who stock old instruction books. Many shops do this. Or try eBay.
http://shop.ebay.com/i.html?_nkw=instruction+book+kenmore+sewing&_sacat=0&_trksid=p3286.m270.l1313&_odkw=instruction+book+sears+kenmore+sewing&_osacat=0
