Question about Toshiba 27AF43 27" TV
We have about 5 inches of white lines down from the top of our TV
Toshiba 27AF43 on Dish network, no problems with other TV's
I had the same problem with horizontal white lines about 4 inches at the top of my 5 year old 27AF43 Toshiba. Solution, I found by google was to replace C407 but no directions. Here is how I did it.
First is to locate a new polarized 100uf 35V capacitor. I was able to buy 5 of these at a local electronic parts store for $2.50.
Next is to open up the TV. Turn off the TV and unplug all wires, place TV screen side down, remove the seven large screws, three on each side and seventh a couple of inches up from the bottom and about nine inches in from side. Then remove the two small screws in the area where the cables plug in. Gently lift off the back cover.
Put a large magazine or newspaper over the bottom part of the picture tube to protect if from scratches.
Next is to pull out the cicuit board at the bottom of the TV, it's the only one. Clip the cable ties holding some of the wires to give more freedom of movement and then gently pull up on the board. It doesn't need any fidling with clips or tabs or such, just pull straight up. You don't need to disconnect any wires.
Then locate capacitor C407. It is black and marked on the cicuit board and is 3 1/2 inches in from the edge and right by the corner of a heat sink. It will have 100uf 35V written on it. Note which side is the negative (this is important). It will be the same side as the other capacitors close to C407.
Next is to replace C407. Take some measurements from the edges of the cicuit board so you can locate C407 (from the bottom) and then flip the board over and locate C407's leads. Draw a circle around its leads with a felt pen. Us a fine tipped soldering iron and a solder ****** to remove the solder. Be careful with this. Might take a couple of goes but eventually you will beable to wiggle C407 and it will come out.
Put the new capacitor in and make sure the negative is on the correct side (this is important). Solder the two leads and be very careful the solder doesn't bridge between the two leads. Let it cool for a few minutes then use a pair of side cutters to cut off the excess leads.
Slide the circuit board back and push gently down until it snaps into position.
Remove the protective magazine or newspaper.
Use a couple of new cable ties to replace the ones you cut.
Replace the back cover being careful that the power cord is positoned correctly into its little notch. Replace the two small screws and the seven large ones.
Reattach the cables. Cross your fingers and turn on the TV. With luck your white lines will be gone.
Good luck
Brian
VE6IMB
Posted on May 05, 2009
Toshiba TV picture has become single horizontal line in middle
this problem is caused by a faulty ir of cap's . First is c408 on the board it is a 100uf @ 35v i replaced with same uf and @ 50v , Second is a 2.2uf @250v and is c410 on the board replace both and your off to the races.
BEWARE OF HIGH VOLTAGE EVEN IF UNPLUGGED
BROUGHT TO YOU BY WWW.JCEWASTE.COM
Jul 22, 2010 | Toshiba 27AF43 27" TV
Toshiba 27WL46 27 in.LCD- Lines top of screen getting worse.
If they are vertical lines, then the LCD panel is going bad, it will get worst with more lines appear as time goes on.
Jan 07, 2010 | Toshiba 27WL46 27 in. LCD Television
White lines on the top 2 inches of screen there
You Probably have some failing Electrolytic Capacitors in the Vertical circuit. it will only get worse and can cause the circuit to fail
all together if not fixed. Unless you are Electronically Savvy and know you way around TV circuits do not attempt to repair. Call a professional.
Jun 16, 2009 | Toshiba 27AF43 27" TV
White lines at top of TV
Good luck
Brian
VE6IMB
Jan 05, 2009 | Toshiba 27AF43 27" TV
Toshiba TV Model 27AF43
You should be able to get into the inputs by going to channel 2 then hit the down button and it should go to the other inputs, keep clicking the down button tell you get to where you want to be...this may not work but about half the time it does.
Nov 17, 2017 | Toshiba 27AF43 27" TV
White lines accross top of screen on our 27 inch Toshiba,
lcd or plasma.
are the lines solid or blurred. do they have sharp edges.
You may have a memory problem with the display which can only be repaired by factory trained technicians, or a brave soul willing to find parts on ebay.
May 02, 2008 | Toshiba MW27FP1 27 in. TV/VCR/DVD Combo
Horizontal line (with about an inch of picture)
check a capacitor on the horizontal section
Oct 28, 2007 | Toshiba 27AF43 27" TV
Screen white line problem.
There are two capacitors in the vertival output circuit that need replaced
Oct 19, 2007 | Toshiba MW27FN1 27 in. TV/VCR/DVD Combo
Horizontal lines
it is due to electrolytic capacitor failure in vertical output section.
just get it replaced.
it very very common & minor problem.
good luck.
Oct 17, 2007 | Toshiba 27AF43 27" TV
Toshiba 27AF43 27" TV Logo
242 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
