Question about Acer TravelMate 2480-2968 Notebook
No power Acer travelmate 2480. Press power button and nothing happens. doesn't matter whether the battery is in or not or if on wall power either way. power supply shows 19.4V on multimeter.
    Master:
  • 404 Answers
Laptops don't powerup either because the battery isn't full, or it isn't plugged to the mains using the lead. if you think the above is fine then it must be because the laptops isn't accepting power in, either because of the motherboard has died, the chips have burned or the power button is faulty. if it's working using the battery but not using the charger then you need a DC socket repair. if it's plugged to the mains but there is no sign of any lights you're likely to have lost your motherboard. if your laptop does start but you see nothing on the screen its usualy the memory ram or the screen or the motherboard, plug it into an external screen and see what happens
this isn't something you can find a solution for in here, the best way is to take it to your repair shop
an independent one will do, or else I recommend a website which collects it and does it for you
cheaptofix.co.uk
I hope this helps. Please rate me.
>> www.laptopquestions.co.uk
Posted on Mar 08, 2009
Power botton flash and no start
check your ram.......via system info...
Jan 29, 2014 | Acer TravelMate 4000 Notebook
Recover acer travelmate 2480 password
Try removing the main battery and unplug the power, then hold the power on button down for 30 seconds, if this does not work, remove the cmos battery for 30 seconds to reset the bios
Dec 24, 2013 | Acer TravelMate 2480 Notebook
Acer 2480 2247 won't power up -no lights no nothing, pwr supply is not the problem,lid close switch isn't stuck ,pwr. on switch seems fine and power supply jack on motherboard is not broken
Remove the main battery and the power supply, allow several minutes to get rid of any residual charge, now plug the power supply adapter back in and press power "leave battery out" is there any change? if not! remove power supply, now! press and hold power for 60 seconds to reset the laptop. Next install main battery back in and the power supply adapter, power up! if no change, the motherboard is the problem.
Mar 07, 2011 | Acer TravelMate 2480-2779 Notebook
Hi I have an Acer Travelmate 6492 first I wanted to reset it to factory settings I could not manage that & now it is not booting it's just flashing on top
Seems like your hard disk is not getting detected.
Press the power button and hold it down for 20 seconds(without the battery or adapter plugged in to it). This process is called POWER DRAIN.
Start tapping the DEL key as soon as you power on the computer.
This will take you to the BIOS screen.
If it doesn't, you will have to check whether your hard disk is faulty with a local technician.
Once you get in to the BIOS screen, press F9 to load the default settings.
Than press F10 to save and exit.
Once you do this, the computer will restart.
Hope this helps.
Dec 21, 2010 | Acer TravelMate C112TCi-SP2 Tablet PC
Not powering up. even when plugged in overnight. no power.
hi there,
try to unplug every thing connected to the laptop, even the power supply. Now disconnect the battery. Now press and hold the power button for 30 seconds.
Reconnect the battery and power to the unit. now try to power on the machine.
You should be good to go.
In case that you still face the issue, i would recomend that you should visit the service center.
Jul 09, 2010 | Acer TravelMate 2480-2968 Notebook
ACER TRAVEL MATE 2480 WILL POWER ON BUT SCREEN REMAINS BLANK.
look close to the screen and see if there is a faint picture. if there is then read below for the issues and solutions that can cause this problem.
Issue 1: Lid button sticking
this is a common issue with this model that the lid button sticks closed. fiddle with it to see if it opens and the light comes on.
issue 2: Inverter for the monitor is bad
this is not to uncommon an issue when this problems shows itself. Laptops monitors light up with a fluorescent bulb. This is powered by an inverter. These can go bad and if they do the light will not turn on. you need to take this to a service station. i don't recommend trying to replace without knowledge of this. They are high powered and you can hurt yourself or damage the screen
issue 3: fluorescent bulb went bad
this is usually the least common but could have happened. usually happens when peopel spray their screen with cleaner and it drips down inside the bottom. This can be fixed by a service center but coudl get costly. best bet is buy a new screen.
Feb 11, 2010 | Acer TravelMate 2480 Notebook
Can you do a cpu upgrade on Acer Travelmate 2480-2968? If so what type of intel CPU will work on this machine?
The following CPUs are supported by the Acer TravelMate 2480:
Intel Celeron M processor 410/420/430/440/450 (1 MB L2 cache, 1.46/1.60/1.73/1.86/2 GHz, 533 MHz FSB) or higher.
So, based upon the speed of the CPU you currently have, you can decide whether you need a CPU upgrade or not.
Nov 04, 2009 | Acer TravelMate 2480-2968 Notebook
No I did not find what I am looking for!I am asking how to install sound drivers and power dvd program in cd rom or stic/flash disk and install it in my computer. Please I need you quick help on this
Goto.... http://www.acer.co.uk/acer/service.do?LanguageISOCtxParam=en&miu10einu24.current.attN2B2F2EEF=3734&sp=page15e&ctx2.c2att1=17&miu10ekcond13.attN2B2F2EEF=3734&CountryISOCtxParam=UK&ctx1.att21k=1&CRC=3713735360 and you can find the drivers, also look on the acer suport under software or maybe in the applications section on ftp site, Give me a email if you still lost mail@gazzanet.com
Jun 01, 2009 | Acer TravelMate 2480 Notebook
Acer TravelMate 2480-2968 Notebook Logo
222 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
