Question about Sony KV-29LS60 29" TV
Sony KV-HR 29" TV GOES ON STANDBY MODE AFTER 10 TIMES BLINKING
  • Sony Master
  • 19,396 Answers
The TV is on protect mode.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Posted on May 22, 2009
Sony KDFA42A-10 standby mode
No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted. Check IC1509, Q1505
If you wish to get more details, check this site. Pull up older posts there. Check the site with patience, as it has over 2200 posts now. All are related to electronic equipment repair help. Blinking codes to Sony TVs are described in detail.
Apr 07, 2013 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony KV- XJ29M50 led flashing 2 time
  1. Two blinks - B+ over current protection (OCP), unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of any of the circuits.
Visit the site named 'Electro-help' for more details. Click this link. View it in 'Flip card' option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. It will make search easy. There are more than 900 posts to different brand TVs now.
Oct 07, 2012 | Sony KV-XJ29M50 29" TV
Sony kv36xbr800 won't turn on -standby blinks 2 times pls help
Apr 22, 2012 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Tv sony stop after 20 min standby led flashes 3 times
HI,
By three blink it means the B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is because there is problem in the power supply circuit. Check for any dry soldering in the power supply side. If the tv is working properly for 20 minutes then its sure that there is some dry soldering joints in the power supply side. You have to resolder suspected soldering contacts using soldering ion and solder. The dry soldering joints will look like on in the picture.
ajin_g_109.jpg ok
Oct 06, 2011 | Sony KV-29FX66 29" TV
I have sony 29'' crt tv . model no KV-DZM61 .when the tv statrs on it shows green led,and after few second the led glows red and it blinked for 2 times .then the tv goes in stand by mode
2 blinks means - over current protection (OCP) , unit goes to the standby
Jun 23, 2011 | Sony KV-XR29M61 TV
I have a sony 29'' crt tv . model no kv 29xr m80.when the tv statrs on it shows green led,and after few second the led glows red and it blinked for 8 times .then the tv goes in stand by mode .which section...
Problem with the audio (AUDIO), unit goes to standby and blinks the self-diagnosis code. Check IC406 audio amp, PS401, and 402. On some projection models of Sony TV sets, this code means that T8005 (flyback transformer), or the associative components in the high voltage circuits are defective on the D board.
Mar 28, 2011 | Sony KV-XR29M61 TV
Hi...I have a problem with my Sony Trinitron 29
the power supply section should be resoldered....must be loose contact..in power section...
Jan 26, 2010 | Sony FD Trinitron WEGA KV-29LS35 29" TV
TV goes into standby and Powerled blinks 2 times
get checked by professional. also heck the manual, local shops should be able to find a solution
Jan 06, 2008 | Sony KV-29LS60 29" TV
Sony WEGA KV 32FS100
No picture. Standby light blinks 5 times. Tried unplugging and restarting. Same problem
Dec 22, 2007 | Sony FD Trinitron WEGA KV-29LS35 29" TV
Standby light flashing
This is possibly a sign that there is a fault condition. Short circuit line output transistor
Jan 23, 2007 | Sony FD Trinitron WEGA KV-29LS35 29" TV
Sony KV-29LS60 29" TV Logo
626 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
