Question about Apple iPod 3rd generation MP3 Player
I can't turn off my ApleIPOD model M9245ll
This is the first time I am going to use it It has been sitting around for a while I charged it but don't know how to turn it off.
Will not charge or turn on tried several methods still will not turn on got it used
If the camera has been sitting around I would suggest that the battery is dead and will not charge because its been not charged in a long time. Sitting without being charged will kill a battery.
Dec 22, 2016 | Cameras
I just bought the eclipse cld and it won't turn on after charging for hours
If the rechargeable battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Sep 30, 2012 | Eclipse Audio Players & Recorders
I bought a 4 pack aa nimh2700 mah brand new sit for a long time without using them now they don't charged what can i to make them work?
  • Rechargeable batteries get old and can loose effectiveness after sitting for a while. You could have a charger problem as well. If you have another charger laying around you can see if the batteries take a charge with a different charger. But, even with rechargeables, they do go stale. If you buy new rechargeables make sure they are "fresh" as buying outdated rechargeable batteries can be a waste of many as many don't work. Buy from a reputable place as well. So many rechargeables from over seas are just not worth a dang.
  • Hope this helps.
Nov 05, 2011 | Cameras
I have an canon a480 camera. I have the problem that even if I charge my 2500mah batteries, when I again turn on the camera I see the low battery sign flashing on the screen? (When I press some of the...
Are the batteries old and been charged many times? Have they ever been allowed to sit around for a long time and completely discharge (which will shorten the life and prevent full recharge). Have you tried cleaning the contacts in the camera with a cotton swab lightly dampened with rubbing alcohol?
Jun 28, 2011 | Canon PowerShot A480 Digital Camera
Drill wont take a charge or operate, drill 9089 10mm type 3, 6 volt
9 times out of 10 problems like this are the result of a bad battery, in other cases it can be a bad charger. Without knowing more information I cannot give you an exact diagnosis. This is the first question I ask when approached with this issue, Has this drill been sitting for a period of time and if so, was the battery charged before it was put away? If Yes, the drill has been sitting and No, it was not charged are your answers than chances are your batteries are dead. This tool has Ni-Cd batteries that self discharge as they sit, eventually these batteries discharge until they have nothing left. In addition, if the battery is stored in a cold garage/shed will speed up this self discharge. I always tell people to think of their power tool batteries just lie a just like a car battery that dies if it sits too long without being started.
If you do not use your power tools on a regular basis it is recommended to fully charge the batteries before storing them or else they will self discharge until completely dead. Another option is the newer Lithium-Ion power tools batteries are not as temperature sensitive, have a much slower self discharge and can sit for 12-18 months before starting to loose their charge.
A replacement battery for this drill runs about $42 plus s/h and can be purchased directly from Black & Decker (1-800-4-DeWalt or www.dewaltservicenet.com) My recommendation is to purchase a new drill. For around $40 - $50 you can buy a newer upgraded model with new battery and charger.
If you think your issue may be something else, please feel free to ask. If you feel I have helped explain or resolve your issue than please rate me. Thank you
Oct 11, 2010 | Black & Decker Drills
Haven't used the chair for about a year and it has rarely been used. Now I want to let someone else use it and the batteries are taking a long time to charge. Is this normal for the description mentioned...
Hi. If the machine has been sitting around for a while mot being used, then your batteries have, what is known as, sulphated up. The plates in the battery have grown a layer of lead sulphate on them.
Sometimes repeated charging and discharging ( going for a ride on the machine ), will help the batteries regain some condition. Batteries do not like sitting around, without being used.
Charging overnight should charge the batteries, if they are able to be charged.
The meter you mentioned, I take it, it is on the charger? I will be measuring the current ( amps ), going into the batteries.
The best answer, but also the most expensive, is to buy new batteries.
Good luck. Neil.
Jun 13, 2010 | Pride Used Mobility Jet 3 Power Wheel...
Have a 1996 Taurus wagon--dead battery--got brand new battery and connected it properly and car barely turns over and wont turn enough to start--car was sitting for about three months
Was the battery checked before it was sold to you? Batteries will lose their charge over a period of time even when not hooked up. If you have a voltmeter it should read 12.8 volts on a fully charged battery.
Have you tried to boost the car with cables?
I suspect if the car was working OK 3 months ago it should start. Which leads me to suggest an undercharged battery.
Oct 30, 2009 | Ford Taurus Cars & Trucks
DSealed Lead Acid Batteries: 12v 7ah; belongs in a Liftmaster LA400 gate control box. Can these batteries be charged using a trickle charger? I'm trying to find out if it's the battery not holding a charge...
Yes you can charge the 12 volt bttery on a trickle charger. You should use a 1 amp or less charger. Check the battery every 1/2 hour or so for heat. If it get's hot you should stop charging. Power packs that have a 12 volt rating will charge your battery safer and better but will take longer (like a cell phone charger) look at the voltage ratings on the charger. You will have to adapt the plug to hook it up and test for correct pos. and negative connections. The 7amp hour batery should be fully charged by a .5 amp (500ma) charger in about 14 hours (multiply the amps times hours of charge and do not go over the 7amp hours of the battery when deciding how long to charge). After charging check voltage, it should be around 12. Let the battery set for a few hours (overnight) and check the voltage again. It should be around 12 still. A fresh charge will usually show a higher reading (called a surface charge) than a battery sitting around. 4.5 v will not operate your device, 9.5 v or higher should.
Aug 05, 2009 | Sears Craftsman LiftMaster Chamberlain...
When i turn on the camera, the zoom lens sounds like its trying to expand, but in only sits there and clicks, then says to turn camera off then back on
This is a common problem for Sony especially on the old DSC models. The gears around the lens are stuck and not engaging. It has to be disassembled and properly seated and lubricated.
Also, make sure your batteries are fresh and fully charged.
Jul 25, 2009 | Sony Cameras
Apple iPod 3rd generation MP3 Player Logo
60 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
