Question about Troy Bilt 5.5hp Self Propelled Mower
I haven't used my s/b in 2 yrs. because it hasn't snowed. I completely ran the gas dry. Now it has snowed and it won't start. I changed the plug,put fresh gas in, took the bowl off and freed the float. I'm gettin spark, I'm getting gas to the bowl,but the top of the cylinder should be wet and it's not. I took a paper clip and stuck it in the small hole and it still won't start. I've put gas into the cylinder replaced the spark plug and it starts but it's not getting gas to keep it running. What am I missing? Tom Stawniak
  • 257 Answers
Hi, You are still not fuel through the carb. Pull your mains screw and your idle/mix screws and spray in some carb cleaner and blow them (seats) out with compressed air and try it again. Note the turns in and then then back them out so you will know the settings to put them back. Good Luck to you, this should Fixya!
Posted on Mar 08, 2009
Procedure to start single stage electic start toro snow thrower
plug in Electric start. Push Choke to 'ON'. press Primer Bulb about 2 times. Turn Key to 'ON' Press Starter.
If you didn't run it completely dry of Gas last season I bet the Ethanol gas messed up your carburetor
Dec 15, 2014 | Toro Power Clear 621 ZE 21 163cc Single...
Backfiring and missing
change the spark plugs.
Jan 06, 2014 | Cars & Trucks
Sears snow blower runs rough like the choke is on
put in injector cleaner in gas
Dec 14, 2013 | Garden
Won start
Depending on set up there's a chance because you ran it out of gas the bowl is dry? Get some old school lighter fluid pull out the plug squirt some into hole , doesn't take much. Reinstall plug quickly and give it a pull and see what happens
May 08, 2017 | Briggs Stratton 020273 Elite Series...
My cub cadet 221 cranks won't start
Clean your carb, if you have not stored it correctly you have a dirty carb now. Carb could be gummed up.
Feb 17, 2013 | Cub Cadet Snow Blowers. 21 in....
I have a Craftsman 22" Auger type snow thrower with electric start thatwill not start. It had gas in it from last winter. I primed it , I set the choke to full, gas open all the way and, at first, it
if you are using ethanol the check the gas lines for a plug because the ethanol leaves a residue behind that can plug your gas line.
Dec 29, 2012 | Garden
Sears Snow blower will not start
Step 1:
Check spark plugs
Step 2:
Check gas lines for plugs
Step 3:
change the oil if old
Step 4:
Next time don't use ethanol because it can clog gas lines and wear down the o-ring faster.
I have a 1985 Yamaha maxim that hasn't been ran
Spray starter into the carb intake with no choke, if she runs for a few seconds then you know its fuel starvation
clean jets & airways & blow through with compressed air
Nov 20, 2011 | 1985 Yamaha XJ 700 S Maxim
Very sluggish, goes nowhere when stepping on gas and now it won't go over 10mph. had a new fuel filter put in dec 05,2010, and all new fuel lines, gas gage hasn't worked in 2 yrs and was ran out of...
the converter is what is restricting power from engine. causes of a bad converter are: decreased engine power, indicated by low rpms on the tach. hesitating or bucking during acceleration, the car will loose power going up a hill. if engine runs hotter then usual and coolant is up to par, it may indicate a bad converter. also black smoke from tail pipe is another indication of a bad converter. good- day!!
Aug 07, 2011 | 2000 GMC Jimmy
2003 chevy malibu LS will not start
where is the fuel pump located on a 2003 chevy malibu ls?
Dec 29, 2008 | 2003 Chevrolet Malibu
Troy Bilt 5.5hp Self Propelled Mower Logo
100 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
Wade Mobley
Wade Mobley
Are you a Troy Garden Expert? Answer questions, earn points and help others
