Question about Sharp Computers & Internet
Backligh problem..... Hello, I was wondering if you could help me with a problem I have with my computer screen. The backlight on my laptop went out - the screen is completly dark. I want to get a replacement but I don't know how to convay the dimensions to the repair staff. Can you please help my with the details. I have a Sharp Actius RD10 laptop, skreen # LQ150X1LGF0 ......... 15'' Thank you, Miroslav Hrin
  • mirec64 Mar 16, 2009
    Thank you for the information. I am absolutely certain that the problem is the CCFL lamp. I know about the site www.lcdparts.net - I went there to order a replacement, but I need to know the specific details of the CCFL lamp, i.e. dimensions, type, etc. Without them I cannot make the order. Can you please send me these? Thanks immensely.
    Miroslav Hrin
  • Sharp Master
  • 32,281 Answers
First thing is to check if the video card is OK.
Connect an external monitor to your laptop, if you get a clear image on this monitor then the video card in the laptop is OK.
A faulty backlight could be caused by a defective inverter that supplies high voltage to the CCFL lamp or a faulty CCFL lamp. Most likely a faulty CCFL lamp.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Posted on Mar 08, 2009
  • Chris Hingee
    Chris Hingee Mar 16, 2009
    The length of the CCFL lamp is measured from the left hand edge to the right hand edge of the screen.
    You can go to LCD Parts page - Selecting CCFL page where you can also select the CCFL lamp by the laptop manufacturer and model.
Scren black.. Very faint outline of the programing can be seen
Hello
The backlight of your TV is OFF. The main reason for this fault is with a defective backligh inverter transformer fitted inside the TV. This inverter supplies sufficant voltage to the back ligh CCFL lamps, and in turn adjust the brightness of your TV. There are mainly two resons for this fault. Either the backlight inverter transformer has damaged or it drive circuit is damaged. You have to check and find the reason. It is dangerous to work with this section, as this backligh inverter generate very high voltage. If you are not familier with this type of repair, get it repaired by any experienced technician. OK.
Jul 12, 2011 | Mintek DTV-323-D TV
Screen is blank when powered up and i cant see anything on the screen
Hello.
Connect an external monitor / display to your laptop to see if your laptop's display is faulty.
If faulty, it is the display's backlight or inverter board.
If you were experiencing discoloration in the screen (pinkish lower light hues) before it failed, that would indicate a CCFL backlight issue. If the screen suddenly went dim rather than a slow degradation, the inverter would be indicated.
In either case, a technician in your area should be able to help. Evaluate to see if the repair is cost-effective.
Hope this helps.
May 24, 2011 | Computers & Internet
Hello, When i turn my computer on the screen clearly turns on however there is nothing on it. It is just black but that sort of off black that is lit up. It makes some sounds as if it is doing something...
Hello !
Connect an external monitor and if it works, your problem is the display's backlight or inverter board.
If you were experiencing discoloration in the screen (pinkish lower light hues) before it failed, that would indicate a CCFL backlight issue. If the screen suddenly went dim on you rather than a slow degradation the inverter would be indicated.
Hope this helps.
Oct 28, 2010 | Toshiba Satellite M35X-S149 Notebook
When i switch on my laptop I see the led lights on but the screen is blank. I do not even see the hp icon that shows up initially
Hello !
It is typically the display's backlight or inverter board.
Hope this helps.
Aug 19, 2010 | Computers & Internet
This lap top has no picture - the screen is black
Hello.
Connected a monitor to the laptop to see if the video card is faulty.
If an external monitor works, it is the display's backlight or inverter board.
Hope this helps.
Jul 03, 2010 | Computers & Internet
T23 Ibm laptop no video
Hello !
Test with an external monitor. If it works, it is the display's backlight or inverter board.
Hope this helps.
May 08, 2010 | IBM ThinkPad T23 2647 Notebook
The screen on my sony cybershot 7.2 megapixel keeps flashing
flex ribbon to LCD or LCD backlight could be not seated properly and backligh going out
Jul 29, 2009 | Sony Cyber-shot DSC-W70 Digital Camera
Hello, my laptop screen went blank, now I cann just see a faint outline of the destop, how do I get it back to normal?
either of 2 things.
1. the backlight went dead
2. the controller of the backlight went dead
or both 1&2.
Jan 24, 2009 | Computers & Internet
No picture Just Sound
Hi
There are different possibilities in your case¸but what happened to me ...
The LCD Backligh is out , I mean the bulbs or neons of the screen BACKLIGH, you have to check either the lights itself or the driver circuit which supply the HV to operate it, usually its a separate small long PCB beside the TV main board .
You can try this trick , Keep all lights off in the room and bring a table lamp, preferred a white neon one and face it lighted on the top of the screen with the TV on , try watch a very dark but exact picture with the sound you are hearing. This is a way to be sure that it is LCD backlights problem when using an external light to illuminate the screen .
It worked for me ,Good luck
Nov 10, 2007 | Polaroid FLM-3201 Television
Computers & Internet Logo
77 people viewed this question
Top Sharp Computers & Internet Experts
Tony
Jason Harris
Jason Harris
Ricky Ostrom
Ricky Ostrom
Are you a Sharp Computer and Internet Expert? Answer questions, earn points and help others
