Question about HP Pavilion zv6005us Notebook
Dead HP zv6000 Won't Start at all
Hi there, Everyone:
I have a dead HP zv6000 notebook. I tried FIXING a noisy CPU fan last night, and when I put it back together it won't boot up.
The power light comes on and the fans start whirring, and the DVD light in the very front comes on for a few seconds, and then goes out.
I don't hear the hard drive seeking / spinning, and there is NOTHING on the screen (completely dark).
I don't hear any beeps when I power on, either.
There is a good chance I screwed up the keyboard ribbon / ziff connection when I tried to put the keyboard ribbon back in.
Any suggestions on how to diagnose / repair this would be greatly appreciated.
Alternatively, since I don't really like this machine all that much, if anyone knows a way to get the data off the hard drive inexpesnively, that would be great too. Is there an external USB case I can buy and plug the hard drive into so that I can use it as an external drive?
Thanks in advance
  • deadzv6000 Mar 08, 2009
    Thank you so much, antiochpc:
    I will try and disassemble - reassemble it again when I get a chance. It took me three hours last night to do it, so it will probably take me just as long this time.
    Let me ask you this: I pulled off the thermal unit to replace the CPU fan. the thermal unit has spring mounted screws. I just tightened it down as much as i could by hand (just using my hand, not my wrists or forearm power). Is there a possiblilty that it is tightened down too hard or to loose?
    Also, I replaced the cpu fan, based onn someone's recommendation, because there was a grinding noise that we suspected was the cpu fan.
    Anyway, after replacing it, I still have the same grinding noise at startup. both fans do spin at start up for about 6 seconds and then they both stop, so I am guessing that gringing noise is NOT from the cpu fan. Is it possible that it is the har drive??? I think my drive would have been dead long ago though, because it was SUCH a loud noise when it would first start up.
    Thanks!
    President:
  • HP Master
  • 1,314 Answers
Okay the first thing you want to do is disassemble it again and make sure all your connectors are connected. Even if you damaged the keyboard cable, the computer should still boot up at least to a keyboard error screen. Make sure the RAM is seated correctly and everything is tight. It is possible that you damaged something (motherboard) as these things are extremely sensitive but hopefully you just have a loose cable somewhere.
If you need the data off the disk, a external USB case would work, or you can just get a USB adapter, without a case it may be cheaper. You can get a multiple one that will connect to IDE or SATA 3.5 or 2.5 drives for around $20 or so.
Thanks and please take a moment to rate as fixya.
Posted on Mar 08, 2009
Hp dv5020us won't boot. upon power up I get some brief hard drive activity and fan noise. No blinking LED error codes. Caps and/or Num lock LED's do not light. Power LED will glow and HD...
step one, big battery out? skipped that?
step 2, a good power pack , that means 19vdc on those 2 pins.
bingo BIOS screen now work ,yes?
step 3, try an external VGA screen at the P15 VGA jack there
screens work now (BIOS first) yes/no?
remove DVD, drive
and all USB devices
there booting with only 1 memory stick. (got more?, try each 1 by 1)
black screens of *****'.
the lack of flash codes, Implies Power pack is dead. or CPU overheated, and selfshuts down. that fan going dead tells
me the power park is dead.
http://pcdied.com/#black-screens
May 01, 2017 | HP Pavilion dv5020us Notebook
HP P4SD, its running good with 4 gb RAM, P4 3.0ghz, and a couple sata hd. The problem is the fan output voltage, i havent been able to read the output chassis and cpu cooler pins voltage cause i can find...
"i can find my dmm?" did you mean CAN'T?
"its clearly off", what is off?
the fans are 3 pins,2 are power, one is RPM tachometer.
"it all works fine", so you can boot and run any OS, ?
"the voltage reads +12vdc", where, at fan or PSU?
the fans run off 12vdc, they are DC motors (from outside fan)
if the fan runs slow at 12vdc the the fan is bad or is a low RPM
fan, as some are, bigger fans run slow, for less noise.!
first is the CPU fan it must run full speed, if not the CPU will overheat in seconds and ALL CPU shut them selves (by there selves) this way. so CPU fan is first. what does it do... there....?
then BIOS screens. GOT BIOS UP? and running? with, ESC key pressed>.
let me guess your symptoms
1: PC dead. will not boot.
2: BIOS dead.
3: all fans DEAD,.
4: power switch works and all PSU voltages read right, (seems not)/?
5: if the PSU power wire reads right(DMM), matching the side sticker voltages, and the CPU is dead, the MOBO is dead, or CPU is toasted.
here is a modern PSU, sticker.
see 5 to 10 power lines, see them. all must read correctly
if a fan is dead, then its dead if 12vdc is present on the fan power pins.
Apr 28, 2017 | HP Asus Motherboard P4SD-LA Socket 478...
HP Pavilion zv6000 power issue. My laptop fan kicks into high gear whenever the adapter is plugged in. Frequently it suddenly shuts off completely to keep itself from overheating. If I use battery-only...
the PC needs to be cleaned,every year or it will overheat.
lint packs up.
what is the ADAPTeR, we cant guess them. ever.
aH the AC power pack is the ADAPTER?
i bet the battery goes dead with no adapter right
so the acid test is this
no battery run on the adapter
if that fails, the adapte is wrong or dead. or weak
1: wrong size 65w or 100w. less never.
2: wrong voltage ,19vdc is correct for HP. not 12,
3: the jack on the mobo for 19v is cracked ,common on some
i never buy PC with this part , I buy Elitebooks that cure that horror.
what happens is you flex cable.
and the jack flexes and then the solder joint crack
all do, its one bad horror. (mine uses a anti crack flex cable inside)
http://www.ebay.com/itm/DC-POWER-JACK-IN-HP-ZD8000-ZV6000-COMPAQ-R4000-X6000-MOTHERBOARD-SOCKET-CHARGE-/271259462380?hash=item3f2852eaec:g:C8MAAOxy9LxSDsly
Aug 04, 2017 | HP Pavilion zv6000 Notebook
Hi, my compaq presario sr2032x wont boot. Power light is ON, PSU light is green. CPU fan runs at full speed. I can hear HD sound too. No display. Keyboard light would blink once and then nothing. It was...
Actually it boots, just that you don't see it. Try using another monitor - even a tv will do: disconnect the present monitor, connect the new one and reboot. If you get an image then the monitor is dead, replace it. If you don't then the onboard video card id dead, get a new one and try again. If even now it.s dead then you need a new motherboard.
Sep 10, 2010 | HP Compaq Presario SR2032X PC Desktop
Screen is black. Hear computer trying to boot up.
cpu fan failure try to put a big fan where the comp vents and air flows! and see if its not shutting down!
Jul 01, 2009 | HP Pavilion dv5-1000us Notebook PC
Hp laptop dv9500 noisy and loud fan ...
The sound you are hearing is probably the fan, This fan has a noisy bearing and will eventually lock up and the fan will stop spinning and therefore the CPU will overheat and shutdown.
The fan needs to be replaced.
Feb 13, 2009 | HP Pavillion ZV6000 Athlon 64 3500+ 15.4in...
HP ZV6000 Fan Making Noise
I had a similar problem on my zv6000, but I've tracked it down to the fan in the middle (not the one above the CPU with the heatsink).
For anyone else that doesn't feel like taking your laptop apart twice (once to get the part number and twice to put the new fan in after you get it online, etc.), the fan is a Sunon Maglev GC 056015VH-A. HP doesn't carry them in the parts store anymore, but I ordered mine online from an independent retailer.
Nov 22, 2008 | HP Pavillion ZV6000 Athlon 64 3500+ 15.4in...
Cpu Fans
your last lined is typed wrong, works, should be worked, (past tense) right?
I guess the screen is 100% dead and PC silent right? no text to the screen ever.
old laptops 15 long years old in fact (can be)
old pentium4 with a square 4:5 screen wow.
some fans are modulated, ever heard of PWM? (this one is)
so did you first remove relic old main battery first, it will be shorted now, and when shorted it overoloads power buses.
then the coin cell is NEXT , never seen one last 15 year, not me.
why wait get the HP RTC cmos coin cell. for 2 bucks and put it in.
dead PC 101, above done, fan dead.
1: power pack 19vdc, it must be at least 18.5vdc,
at the mobo not in hand by it self. the means under load testing.
normal load. we use a thing (20bucks) a voltmeter DMM to test all power packs. or replace it for $10 if you can even find one this old.
there is more lots more, if one component on the mobo shorts.
we can find that but , ill stop here, if you can get this far.
now the book on your PC, page 91 shows how to change the CMOS battery, here is the steps (compaqs are PITA)
this page. (Compaq then thought it lasted 20 years, hahahahaha)
https://www.manualslib.com/manual/273370/Hp-Evo-N1010v.html?page=91#manual
Keyboard cover(page 2-13)
Speaker (page 2-15)
Keyboard (page 2-16)
Switchboard PCA(page 2-19)
CD/DVD (page 2-20
Display (page 2-23)
Top case (page 2-26)
Floppy (page 2-32)
Heat sink (page 2-40)
Motherboard (page 2-50) bingo the coin cell.
the fan is modulated. (it is controlled at all times for speed)
at power on most laps it run real fast first. then slows.
this is by DESIGN to keep noise lower.
id the CD does not eject try on damand there is no power.
if fan is dead, to, power is gone
one guy asked what power means. ok
it means all 3 4 or 5 power regulators on board work
5v
12v
3.3.
1.8 and more, if any power reg shuts down the PC is DEAD.
Jan 18, 2018 | HP ze5560US (DP473U#ABA) PC Notebook
Acer travelmate 4000 laptop Big problem
I guess I can assume that you have it plugged into the ac power, so you know its not a power problem. We also know its not a problem with the power switch since the light turns on. So that leaves, motherboard, cpu, and ram possible problems. Ram would unlikely cause such a hault. Even with no ram, I believe the computer would make horrible beeping noises. So if its a problem with the motherboard or cpu, its pretty much trash, unless you want to waste the money on ebay or some place for another cpu to try to swap.
Aug 23, 2007 | Acer TravelMate 2300 Notebook
HP Pavilion zv6005us Notebook Logo
237 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
