Question about GE 24 in. GSD6660GSS Built-in Dishwasher
Water dripping from the front bottom front panel
I just noticed that my dishwasher has been dripping small amounts of water from a fastner on the lower left hand corner of the machine.
The dishwaser runs through the cycles just fine, as much as I can tell, but I cannot figure out what is causing this leek.
The seals seem to be secure.
  • 170 Answers
It is possible that you may be using to much liquid soap...if that is what you are using ...this tends to foam up...and will leak out around the door....also drying agents will do the same ...if some is spilled into the inside wipe it up before stating the cycle...another issue could be the round float at the front right (usually) of the DW...this can stick sometimes allowing to much water in.....see if it is gunked up and if so clean it out it should move up and down freely...and make a clicking noise also. You could also a piece of food or debris blocking the door from properly sealing.
I hope this helps...good luck and good day...please rate my effort ...The Fang
Posted on Mar 27, 2009
Start light flashing. Dishwasher wont start
I'm guessing as you did not list the model number. Something similar happened on mine. Due to a freeze, there was a small crack in the inlet and water had slowly leaked. As a safety feature, the Asko has a tray under the dishwasher inside the overall dimensions. It has a float. When the float rises, the drain pump starts and the dishwasher will not start. In my case, the drip pan is not connected to the drain which gave me the drain sound, but did nothing to remove the leaky water.
I suggest you take the front bottom panel off the dishwasher and check for water/leaks.
Oct 29, 2014 | Asko 24 in. D3121XL Free-standing...
Should there be water left in the bottom of the dishwasher after a cycle?
Yes - there should be a small amount beneath the filter screen - the pump never gets 100 % of the water out - it cavitates and there is a small residule amount in the bottom - this water is exchanged with each wash
Aug 17, 2014 | Miele Dishwashers
Small amount of water covering bottom dishwasher-won't drain
YES IT IS WATER FROM DRAIN HOSE LEFT AFTER PUMPING OUT THE MAJORITY OF WATER AND IS LEFT IN HOSE.
Mar 10, 2010 | Maytag 24 in. MDB3700 Built-in Dishwasher
Kenmore side by side. Noticed water dripping out
please do not use hot water.........only clean drain hole with copper wire with very small cloth on
end.sounds like you left door open? adjust feet to allow door to close itself..if left ajar.
fully defrost.clean drain hole.adjust feet. switch on ...
this freezer works best full....
Feb 04, 2010 | Refrigerators
Dishwasher not getting water.
  1. open the bottom panel 2-4 screw
  2. take a flashlight and turn the machine on
  3. see where it come from
  4. if you need take the unit out a bit from the counter
  5. check it all around to find the sorce of the leak
  6. good luck its EZ :)
Nov 16, 2009 | GE 24 in. GSD2000Z Built-in Dishwasher
Standing water at drain in dishwasher after using.  Is this normal or should the water drain completely.
Most dishwashers leave a small amount of water in the bottom to keep the seals lubricated. If it is only a small amount of water it should be normal.
Jul 09, 2009 | Dishwashers
Water and odor collecting in our empty dishwasher after 4-5 days
A small amount of water may be normal.  Clean the filter at the bottom of the tub.  Sprinkle some baking soda inside between washes.
Jun 02, 2009 | Dishwashers
Small amount of water remaining in bottom basket
There is a screen in the drain that is plugged.
Apr 15, 2009 | Viking DFUD042 Built-in Dishwasher
Window air conditioner..
It is normal there is a small hole for the water to escape just make sure that when you mounted it you tilted it down a small amount at the back so it can drip out
Jul 22, 2008 | Heating & Cooling
Leaking dishwasher
Sorry about the delay in time in getting back to your problem if not already resolved heres what you can try. Remove the bottom panel and run through a load, to see exactly where leak is coming from, most common place for leak is through the heater hold down brass nuts. They crack and need to be replaced
Feb 27, 2008 | Frigidaire 24 in. PLD2850 Built-in...
GE 24 in. GSD6660GSS Built-in Dishwasher Logo
274 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
