Question about IBM 92P6569 DVD/CD-RW for ThinkPad R50, R50e, R50p, R51, R52, G40, G41, T60, T60p Notebooks
Battry problem !
Hi, i have a problem in laptop related to battry , it's battry has damaged, gets immediate discharge.it's life only 5 to 10 mints, plz solution!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
I went to charge the keyboard. The green light will come on and as soon as I turn the keyboard on the red light turns back on. Can someone help?
Excuse me but your queston is rather confused. It is supposed to be a question bout a laptop and you are talking bout charging a keyboard.
In any case, did you check the level of the charge before you turn toe keyboard on? It discharged immediately? This means that your battery is absolutely dead and you should get a new battry for your device
Apr 29, 2015 | The Computers & Internet
Tip
How To Extend Your Laptop's Battery Life
Hi... This is Vikas Sharma From M/s Computer Solutions, Patiala - Punjab, India
Im Going to give you one good advice that if you want to make your laptops battery life batter and want that your battery should run and give proper backup then use the battery as much as possible and when laptop shown the message that battry low or less than 5% then charge it back full. do it atleast once in a week.
Acctually the purpose is that when you charge and discharge the battery full all the cells used and charged and discharged. when you charge your battery when it is having i.e. 40% or 30% etc. charging to full and then you use the battery upto i.e. 40% and again you charge it then the remaining 40% cells are not charged and discharged then they become useless and again and again this process dead the cells that are not in charging and discharging position. This is the one big reason for battery problem.
so I suggest that charge and discharge the battery for better results.
Thanks Take Care
on Jun 28, 2010 | Computers & Internet
Hey, there any one plz give me idea about my problem with my laptop, last night i shut down my laptop properly and the next day evening it was not getting start,battry is ok and it is showing charging but...
Do you leave it plugged in a lot? I would try another Cord/charger with the EXACT same power specs. Never leave a Computer plugged in when not in use, it's subject to power surges, accidental damage, and shortens the life of the components, Cord/Charger, AC jack, etc.
Apr 13, 2013 | Dell Inspiron Computers & Internet
I was using my laptop in office. i went outside for about 20 mintes, as such, when i got back the laptop had gone into sleep mode. i moved the mouse cursor and pressed the keys to awake it, but of no use....
hi there no not a new laptop just a new inverter...quite simple to fit and not very costly.;....just get the make and model of your laptop then search on ebay..should cost you anywhere between £20-40 for a new 1 and about 30min to 1hr fix depending if you have any experience..
Hope this helps
Mar 31, 2011 | Toshiba Computers & Internet
I have dell vostro 1400 laptop.when my latop charger is plugged in laptop is charged but as suddenly when i unplugged charger laptop is shutdown no battry is charged what is the problem?
You have either a faulty/worn out battery or a faulty charging circuit.
Recharageable battery have a finite number of charge and discharge cycles and over the years the battery life gets shorter and shorter until it is worn out and won't charge any more.
If the battery is more than 2 years old then the battery is most likely worn out and needs to be replaced.
Jul 18, 2009 | Dell Vostro 1400 Notebook
LOCKED
u have remove bios battry form the mother board for few mints your problem will soloves
Aug 24, 2008 | Acer Aspire 5315 Notebook
Battery maintenance
you should charge fully then remove power once it is charged.
use it with battery till battery is discharged.
leaving it plugged in all the time will kill the battery.
thanks for rating.
Jan 15, 2008 | HP Compaq Presario V2000 Notebook
My battery dies soon
hi here is a place for a battry http://store.yahoo.com/priorityelectronics/b5liionbatfo25.html follow the manual! first charge you got to charge it for 24h then let run untill its runs out and then plug it in ordinery let the battry discharge every time before plug it in thats how you keep the battry live as long as possible good luck
Mar 28, 2006 | IBM ThinkPad T22 2647 Notebook
IBM 92P6569 DVD/CD-RW for ThinkPad R50, R50e, R50p, R51, R52, G40, G41, T60, T60p Notebooks Logo
379 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
