Question about Dell Dimension 5100 (D51L1) PC Desktop
Dell Dimension 5100 No Power No lights
I have a Dell Dimension 5100 and it will not power up. None of the lights on the front work either. I am getting the green led on the motherboard to light up. But the fan doesn't come on and the hard drive doesn't power up.
So far I have searched the internet and it appears the main causes of this appear to either a bad power supply, a bad motherboard, or shorted USB ports.
So I started with the USB ports and could not see any contacts that would appear to be shorted.
Next I wanted to check the power supply. So I purchased a power supply tester. Unfortunately even though it said it was a 20 and 24 pin tester, it wouldn't work on the 24pin. So I had to buy a different one. Needless to say I could have bought a new power supply by the time I was done. But the tester is showing the supply as ok. And the fan and hard drive powered up when the tester was plugged in.
So that made me about 95% sure it was the motherboard. So I purchased a new motherboard (J8885).
I just finished installing the new motherboard and unfortunately that did not fix the issue. Still same thing. Green LED on motherboard. No other lights. Neither the fan or hard drive cycles.
So I'm a bit frustrated. I feel like I'm throwing good money after bad. I'm about $140 into this with no fix in sight.
Any suggestions from anyone. The only other things I can think is that either somehow the power supply is still bad even though the tester said it was good. Or the switch on the front panel assembly (X8682) is not working to actually turn the computer on?
Is there some way to jumper the pins on the motherboard to try and turn it on without the using the front panel switch? That would let me know if that switch was the problem somehow?
Otherwise I'm left to just try buying a new power supply and hope that is the issue. Or try buying a new front panel assembly and hope that is the fix.
Thanks for any input.
-Eric
  • 3 more comments
  • ejesme Mar 08, 2009
    Antiochpc -
    Thanks for responding.
    Unfortunately I don't have an alternative power supply to check with. That is the first thing I looked for. I have two other comps but they both have 20pin connectors. So I'll ask around at work tomorrow or might just break down and buy one. I wish I had done that first...
    I did check the switch on the back of the power supply earlier and it is set to115v
    Unfortunately checking the power switch doesn't appear to be as simple as it should. There aren't colored wired running to the motherboard. This is an integrated control panel assembly (x8682) that has a circuit board with 2 USBs and a mic in and an audio out. It connects via an IDE type flat cable like a hard drive. The actual switch is on the circuit board and there is no way for me to trace the leads back through the IDE cable and there are 39 pins on the motherboard where this connects..
    DickCanFixit - Thanks for responding. See above for why I can't trace the wires. I did previously check all of the removeable stuff before. I should have mentioned that. I removed the memory and tried each one individually. I removed the video card and the modem. None of those had any effect.
    APremkumar - Thanks for your response. I did run through the Dell No power troubleshooting guide previously. Unfortunately it didn't help resolve the issue.
    Antiochpc - There are 39 pins so it will take a bit, but I can try. Unless you mean only short out 2 that are across or next to each other. Is it likely that is how the power ones would be? Thats why I was hoping someone knew the power pinouts. No risk to the motherboard if short some of the wrong pins?
    Antiochpc - If it helps here is a chart of the sections of the motherboard. http://www.centrix-intl.com/showpix.asp?...
    In the bottom right corner (Front Panel Input) is where the ribbon cable from the switch on the front of the comp connects.
    Antiochpc - Ok. Thanks well I appreciate your time and effort. I have seen other online info where people did buy a new front control panel and it resolved it. It is a little circuit board and has the USB ports and i guess those can short and cause the whole switch to go bad. Thus power supply is ok, motherboard is ok, bu can't actually turn on the comp. I agree leave it to dell to over complicate the simple on off switch such that I can't even tell if I have a bad power supply or motherboard. Hopefully I can find someone at work who has a spare power supply I can borrow.
  • bsmithjunk Mar 11, 2009
    My 5150 does the following after unplugging:
    If my usb keyboard and mouse are plugged in, the start button light blinks amber indefinitely and when pushed nothing happens.
    If I unplug, wait a minute or so and replug with the usb keyboard and mouse unplugged the start button blinks 5 times, a short green blink and then the start button boots the machine. Then if I plug in the USB mouse and keyboard it seems to continue working.
    Any help would be appreciated.
  • 564 Answers
Hi Eric,
Don't Worry we can fix this this problem.
This seems to be no power issue.
Just mail your email address and number to apremkuma@gmail.com
Thanks, Prem
Posted on Mar 08, 2009
    President:
  • Dell Master
  • 1,314 Answers
First let me commend you on your troubleshooting skills.
Now this is my advice.
First things first, try a different power supply. It is not uncommon for a power supply tester to give a bad power supply a good rating and they can be had for under $25 or, swap one from another computer that you know is working...it doesn't need to be mounted, just plug in the two motherboard connectors and one to the hard drive (to give it a load) and check it out. Even before that, double check to make sure the red switch on the back of the power supply is set to 115v (or whatever voltage you use, I'm assuming you are in the states).
Now to check the switch. If you have a multimeter handy, all you need to do is figure out which color wires are associated with the switch on the front panel. Usually if you remove the front panel, you can see which colors are associated with the switch. Pull the plug off the motherboard header and test the resistance by putting the multimeter leads into the parts identified by the colors of wires you figured out were to the switch. When you depress the switch, it should show 0 and when you don't, it should show 1. Alternatively you can find out which headers those colors go to on the motherboard and short those two pins with a small screwdriver and see if it powers up.
Good luck and let me know if anything here works. Please take a moment to give this solution a rating of fixya.
  • 2 more comments
  • Kevin Shafer
    Kevin Shafer Mar 08, 2009
    Okay then, remove the plug from the motherboard and take the screwdriver and just short out the headers 2 at a time until you've tried all combinations. In my experience though I have *never* had a bad switch that caused no power that wasn't physically broken. Good luck!
  • Kevin Shafer
    No, not the 39 pins from the IDE cable....let me check to see if I can find a diagram of your motherboard.....
  • Kevin Shafer
    Okay, looking at various images of your motherboard, I do not see the normal set of headers I was talking about that most standard motherboards have (leave it to dell!) so no, don't try shorting of the pins since I can't ascertain which pin does what...in normal motherboards, the headers are usually for speaker, power LED, HD LED, Reset, and Switch and shorting any combination of those won't damage the PC, just shorting the switch will turn it on. Hmmmm. But like I've said, I have never seen the switch actually become defective; not saying it couldn't happen its just not a very common issue.
  • Kevin Shafer
    Yes, come to think of it since it goes to another circuit board before going to your motherboard it could be something in that area. Good luck!
    President:
  • 948 Answers
Find where the power switch wires are plugged into the motherboard. Write that location down or take a picture of it. Then unplug that and short those two pins for a moment (power supply connected and turned on). Does your computer come on now? If so, your switch is bad.
Try removing one of the memory modules and then power up. One of them could have gone bad. Onboard video? Have you tried a different or separtate video card?
2 Suggested Answers
LCPLgeek
  • 125 Answers
SOURCE: I have a dell dimension 5100 desktop, I installed
hi there, it may not be the mother board, it may be that the graphics card doesn't have the drivers for your system. Bring it to a computer shop and they will install the drivers for you.
Posted on Jan 31, 2010
Dell dimension 5100 - usb ports on motherboard are broken
Flashing Amber is normally power supply
http://www.fixya.com/support/r4282412-find_no_post_diagnostic_information_dell
The USB ports are part of the motherboard
Jun 08, 2010 | Dell Dimension 5100 (D51L1) PC Desktop
Can't boot up Dell 5100 Dimension, amber light flashes
When you mean the amber light, is that the blinking hard drive access light or the power light? Different cases have different colors on it. Mine has blue and green lights.
If you see the boot screen (bios) and then after it goes to boot, does it blink and hang?
This could be a simple operating system issue, hard drive or hardware/motherboard issue. If you could provide more information, that would help.
Jun 28, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
Dimension 5100 will not turn on
Could be a bad motherboard? If your power supply was really fried it could have also fried your motherboard.
Mar 25, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
Dell 5100 won't come up after memory swap
Did you make sure that the power supply was off and or discontected from power source before opening the case?
It is possible that you have fried something by having a static discharge either from you hands or the vacume cleaner hose. Have you checked the correct installation of the memory make sure you are putting the original memory in dimm1 and dimm2.
Also check that the power button is still connected to the mother board just follow the wire from the back of the button just to be sure. Also check that the power switch on th power supply is on.
Link is to manual
http://support.dell.com/support/edocs/systems/dim5100/en/om/T8144bk2.pdf
Jan 28, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
Unable to get front of dell dimension 5100 to check power switch
They say “a picture is worth a thousand words”.
Follow this link: http://support.dell.com/support/edocs/systems/dim5100/en/sm/parts1.htm#wp1371329
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Oct 30, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
Power problem on Dell Dimension 5100
plz check the ram and powersupply unit and try to reset the bios
Sep 02, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
Power supply ?
I'd recommend purchasing a new power supply.
Your Dell Dimension 5100 comes stock with a 305W power supply. This is a bare-minimum wattage that will only handle what they ship on the system & not much more. You're better off upgrading the power supply with a compatible after-market model.
You can go to a PC parts store in your area and take your chances...but they're usually more expensive then Internet sources (they've got to pay for their brick-n-mortar store overhead).
Here's a link for a very inexpensive replacement 400W power supply for your Dell Dimension 5100:
http://www.affordablesurplus.com/dell-5100-5150-power-supply.asp
This particular site offers $8 Flat-rate shipping & a 1 year warranty. Your power supply is only $49.99 - you might be able to find it cheaper elsewhere, but that's the best I could find with a quick Google search.
If my answer helped you, please provide feedback :-)
May 05, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
Dell Dimension 5100 Won't start up
Hi
First disconnecting the power cord and re-seat all connections (Keyboard, Mouse espercially). Connect up the power cord and try powering the PC.
To help you troubleshoot a problem, Dell Dimension 5100 has four diagnostic lights labeled "1," "2," "3," and "4" on the front panel. When the computer starts normally, the lights flash. After the computer starts, all four lights display solid green. If the computer malfunctions, the color and sequence of the lights identify the problem.
If the computer failed to start up check the diagnostic lights color and sequence and Check the link below for more info (Assuming you have another system that can access internet)
http://support.dell.com/support/edocs/systems/dim5100/en/sm/tshoot1.htm#wp1120147
Alternatively, contact Dell Support with the diagnostic lights color and sequence to raise a service call if the system if under warranty.
Mike
Mar 31, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
Dell Dimension 5100 (D51L1) PC Desktop Logo
2,297 people viewed this question
Alun Cox
