Question about Craftsman Garden
Doesn't run properly
How can I find the proper settings for the carburetor? I rebuilt it and need a starting point to go from. I forgot where the settings were!
Please give suggestions for a Tecumseh CA-632176 . It is on a older Craftsman Tiller # 917.299369 serial # 0710w22284
  • Jim London
    Jim London May 11, 2010
    Hi, I always use 3 turns out as a starting point. I think on that carb you have the mains on the bottom of the fuel bowl and an Idle mix. Use the choke at full plate if you pulled the cable from the fitting. Let me know how it works out for you and I can help you tweak it.
  • 42 Answers
SOURCE: Need diagram for this carburetor #632508 or 632508
below is a copy of the only diagram I could find for you. hope it helps! thanks.
Posted on Mar 25, 2009
  • 69 Answers
SOURCE: does rear tine tiller run 2 belts
Check the Troybuilt website for specific info on your tiller.
www.troybuilt.com
Posted on May 06, 2009
  • 86 Answers
SOURCE: Need new carburetor
I will check to see if I can get you one at a resonable price.
Posted on May 13, 2009
  • 376 Answers
SOURCE: replacement carburetor OHH55 tecumseh 5.5 hp rear
Need the 5 numbers and a letter following the model number to tell you that. :)
Posted on Jun 06, 2009
MNfisherman
  • 11896 Answers
SOURCE: my 6 HP Craftsman tiller will not run without starting fluid
Carberator is gummed up and will need to be removed and dismantled and soaked in solvent for an hour or two.
Posted on Aug 16, 2009
1994 suzuki quadrunner lt f250 wont run
Hey Marty,
An internal combustion engine requires three things to run..(if all the internals are good)..
1. A properly timed spark.
2. Adequate compression (>120psi).
3. Proper air/fuel mixture.
Start by eliminating one of these at a time...(get a professional to clean and set the carb), install a new spark plug. Get a new fuel line.
Oct 04, 2017 | Suzuki 2005 QuadSport Z400
I need initial screw settings for a YFM80 Moto 4 carburetor. I just rebuilt it but can't find initial screw settings.
Hey William,
By rebuilt, do you mean the carburetor?? ..or the engine??.. if you rebuilt the carb and you did not remove these screws ( and count the revolutions out from lightly seated), then you did not do the rebuild the carb correctly.. sorry.. What, exactly did you do to the carburetor?? Please reply on here to me..with details!!
thanks..
I cannot understand why someone that claims to have "rebuilt" a carburetor actually missed the BASCIS of carb rebuilding 090.. the air screw (the one on the angle toward the back of the carb has/is connected to the pilot jet system and the idle system, the passages that use this system must be perfectly clean for the engine to run properly.... the air screw has a spring. a spring seat and a o-ring for sealing on it.. the screw setting starts at 1 & 1/2 turns out from lightly seated.. then set the screw in the very side of the carburetor (its the one that controls the idle speed).. once you get the machine warmed up and cleaned out.. let it idle, turn the air screw in and out SLOWLY about a 1/4 turn at a time..EACH TIME ..waiting until the idle settles and then until you reach the point the machine idles as high as possible, then turn in it 1/8 of a turn.. then set the idle speed with the "side screw" to a speed you like... good luck...thanks!!
Jul 17, 2017 | ATVs
Power stroke 414cc HOV
One of the most common problems with power generators is:
Not having been run often enough.
When that happens ( I have 2), the gasoline will evaporate or thicken and turn gummy, and will clog the carburetor.
Then, the carburetor must be rebuilt, (often it has to be taken off the machine) before it will run properly again.
To prevent this, you must start and run the generator once every two or three months for about 10 minutes.
God bless your efforts.
Jul 14, 2016 | Electrical Supplies
Why does my motor idle great but chokes out when powered up?
Sounds to me like the choke wasn't properly set up when the carb was rebuilt. If the linkage is sticky or bent then this could be a problem too.
May 25, 2015 | Boating
2004 honda sportrx 250ex Won't idle down even though I rebuilt the carburetor
Assuming your question is, "How do I set it up to idle properly?" Just rebuilding the carburetor isn't enough to get your bike to idle properly. If it idles high, there is either too much air or too much fuel going through the carbs. Were the jet needles replaced at a level appropriate to the air intake? If you also replaced the air intake, i.e., replaced the air box with pods, you will need to reset the jets at a different height. (More air needs needles set to let more fuel pass.) Hope that helps.
Nov 10, 2014 | Motorcycles
Adjust carburetor
use the chocke. first full closed then half way. when it started let it idle for about 20sec then open it again.
Mar 30, 2014 | Garden
Honda gx160
Kescorpio56:
Check your throttle and choke settings. Something is causing the throttle plate in the carburetor to remain open or the governor is improperly set. I would reset the air/fuel mixture screws to one and a quarter turns out and back the idle screw all the way out. Make sure that the throttle cable operates the throttle properly and check the governor setting and reset the governor setting if needed. Start the engine and adjust from there. When the engine starts, adjust the idle screw until the engine idles. Adjust the fuel/air mixture screws for the best idle. Then run the RPM up and adjust the fuel/air mixture screws for the best run/idle combination. Don't forget to adjust the governor if the engine runs too fast or too slowly.
May 31, 2013 | Air Tools & Compressors
I bought an Echo PB-250 on E-Bay recently.The decsriptions said that the previous owner did not prepare for winter storage properly, & only runs with the choke on.After receiving it I found that to be...
The carburetor is exhibiting symptoms of flooding. Many different things can cause it, from a bad vent in the gas cap on the machine to bad seats on the L and H mixture screws of the carburetor. I suggest you remove the carburetor and clean it, (use NO harsh chemicals) and have it rebuilt. If it sat over the winter with old fuel in it, the diaphragms inside it are probably ruined. There are NEW ones in a rebuild kit.
Jul 10, 2011 | Echo Garden
1982 Suzuki GS 750 E bogs after 3000 rpm carbs have been rebuilt
Hi, K_huffman engine "BOG" is mainly caused by a rich air and lean fuel condition but it can also be caused by a lean air and rich fuel condition this situation rarely occurs and is only caused by the misinformed weekend warrior that owns a toolbox.
The more you open your throttle the more vacuum you are creating in your carburetor venturi and your intake manifold. When you are operating at higher RPM any unmetered air that leaks into your system can become more obvious.
Unmetered air is air that is getting into your system after the fuel has been delivered. If you have unmetered air getting into your system between the butterfly/slide of the carburetor and the cylinder head this will create a lean condition.
All of the rubber components of the fuel system like vacuum hoses and intake manifold that you mount the carburetor to are made of rubber. If none of these components have been changed they are more than likely highly degraded and probably cracked in places to allow unwanted-unmetered-contaminated air into the combustion chamber. Check all of your vacuum lines and vacuum plugs for carburetor synchronization. The vacuum plugs are in the head just after the rubber intake manifolds. The petcock has a vacuum line as well as part of the emission system.
1. Check the intake manifold for fissures.
2. Ensure the bands used to tighten the manifolds down on the intake are secure and have not bound up the manifold.
3. Make sure air box fittings are not warped and fit completely over the carburetor.
Your airbox is metering air and is the first step in a process of consuming air and fuel. The system requires the resistance of the air filter in order to get the proper vacuum to "SUCK" the fuel out of the float bowl and create the proper venturi effect.
Improper mounting and sealing of the airbox will create a small lean effect. This might seem like no big deal but you are inviting dust and debris in your engine that is doing slow damage by not having proper fitment. Fix it so you know it's not contributing to your issue. Pick the low-hanging fruit first.
Do not go and start adjusting anything at this point. It ran fine before. There is something wrong with the assembly or a component. Do not adjust your floats. Get it back to where it was. The moment you start tweaking everything is the moment you lose OEM settings which are a must-have for fine-tuning and maximum performance.
Fine-tuning your carburetor and multi carb syncing come at the very end following the proper procedure established by the Carburetor Gods.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Thread My GS850 Bogs down when accelerated quickly
77 GS750 Bogs on throttle
http://www.vanluik.eu/Suzuki%20GS750%20Service%20Manual.pdf
OEM parts for Suzuki
http://mybikemanuals.com/suzuki/suzuki-gs-owners-manuals
Sep 22, 2010 | 1978 Suzuki GS 750 E
BEEN RUNNING ROUGH WITH LESS POWER THAN BEFORE. NOW WON'T START AT ALL. NEW PLUG, CHANGED OIL AND FILTER, HAS A GOOD SPARK.
1956 420 john deere new plugs, wires,cap,plugs,rotor,points set on 20.condenser good blue fire on points and plugs carb rebuilt BUT want start you can pull off it will start and run
Sep 28, 2009 | John Deere 420,1020,2010,2020,2510,2520...
Garden Logo
95 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
