Question about Neff Cooktops
Neff T1722SO Ceramic Hob - rings don't heat
The controls all work (on/off, ring settings etc) but none of the rings heat at all. Given the controls all work the power supply seems fine. It did not recover when switched off and on again.
  • 59 Answers
Check the power supply to make sure it is getting 220V, the lights etc might still work if only getting 120V but burner won't without full power supply.
Posted on Mar 11, 2009
My 5 ring induction hob works fine but has stopped showing H or h. Is it possible to turn this feature off accidentally or is it a fault?
do not think there is any OFF switch for the HOT indicator .if it all works why even worry about it .
Aug 08, 2015 | Neff Cooktops
When turning on my 2 year old Neff induction Hob T4543N1 it displays a full set of E errors and cuts out it does after two attempts corect itself and function perfectly
I had flashing Es every time I turned the hob on - got worse and worse until unusable. Neff help line useless - service call cost ridiculous. My problem was the capacitor on the 5 volt power supply had failed. 5 volt supply was at 3.8 volts. Replaced the capacitor and the hob's now perfect - a joy to use. Only helps if you are tech savvy and willing to open the unit, but may give you some hope or point you in the right direction.t
Jul 28, 2010 | Neff Cooktops
I have a neff T1.D20 dual circuit hotplate but although the inner lights up and gets hot the outer part doesnt. Is the outer part supposed to?
I have a T172 model which also has a dual circuit hotplate.
In the control area you should find a dual circuit control pad - this has two concentric circles on it. With the hob switched on, pressing this button will chnage the mode of the dual circuit hot plate bewteen:
1. Just the inner part
2. Both the inner and outer together.
When the hob is switched off using the Standby control pad, it remembers which mode was selected and will therefore work the same next time it is switched on. However, it is worth noteing that when the mains power to the hob is interuppted, either by an isolator switch/breaker, or a power cut, the hob defaults back to just the inner ring mode.
Oct 03, 2009 | Neff T1323 Electric Cooktop
Cant switch on hob
gud day,the ceramic hob is very sensitive to operate if u not read the manual.after u unlock the switch go to the control of the hob wat area u want to operate by touching the sensor then if u see the zero # touch again the area,positive side to increase the heat 1-9 the standard control heat.some model & brand have a different operational procedure,try to read the manual 1st or check the voltage of the unit coz the ceramic have a 4voltage standard for different country. tnx gerbee
Jan 26, 2009 | Neff 23 in. T1443 Electric Cooktop
Hob turns off
hi im gerbee my suggestion is replace the pcv control wat brand u have,always also in philipines the electric hob is so very sensitive,the pcv cotrol is not repairable.or next time u by a new one gas cooktop more ok compare to electric ceramic hob, or use electric ceramic hob w/knob control compare to sensor type,i think the part of the sensor or pcv control is so very expensive,that why i buy an another one.dont try to repair more difficult to com.tnx
Nov 24, 2008 | AEG 23 in. 6410KF-N Electric Cooktop
Neff T1722 so 02 ceramic hob
its normal for the ceramic hob to ON & OFF coz of the sensor inside the unit to protect for overheating.same here in phillipines.its normal.tnx gerbee
Jul 28, 2008 | Neff 23 in. T1443 Electric Cooktop
Electric ring stopped working on my T1250 Cooker Hob.
MY PHONES RINGER STOPPED RONGING MEYBE THERES SOMETHING WRONG WITH IT
Nov 04, 2007 | Neff 23 in. T1252 Electric Cooktop
Neff 4 ring, ceremic top hob - how do I turn on!!
You press the "on" which is on the left. Press the picture of hob you require and press the up and down for temperature. Then put your pan on the hob and it will work. If you need to adjust the temp you need to remove the pan.
Oct 15, 2007 | Neff 23 in. T1443 Electric Cooktop
Cooktops Logo
607 people viewed this question
Top Neff Cooktops Experts
Jim London
Jim London
Samyfam
Samyfam
Are you a Neff Cooktop Expert? Answer questions, earn points and help others
