Question about Kohler K-15176-PT-7 Coralais single-control kitchen sink faucet with 10" sp
Leaking kohler faucet
We have a Coralais Single Control Kitchen Sink Faucet that is leaking from the "base" where it connects to the sink. When you turn the handle up, water seems to leak out a little bit and then the water comes out of the spigot. In the past few days, we have been getting more and more water leaking out. Does a specific part need to be replaced to correct this problem or does the whole faucet need to be replaced?
  • 659 Answers
Where the spout pivots on the main body, there are a couple of washers, you can replace these washers pretty easily by removing the handle and then the "cover" from the unit. The water has to be shut off before you do this. I would take this oppurtunity to replace all the washers.
Posted on Mar 19, 2009
  • Donni Steen Mar 19, 2009
Kohler single handle sink faucet 10 years old leaking
William, you or a plumber will have to replace the cartridge and seals to stop the leaks. The parts may have life time warranty, check your manual if you still have it. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
KOHLER Canada Warranty Information Planning
Maintenance Replacement Parts KOHLER
Fort single control pullout kitchen sink faucet with color matched...
Kohler kitchen faucet repair
May 12, 2016 | Kohler Model 10433: Fort® Single-control...
How to stop sink leak
Check whether the faucet is leaking or the drainage is leaking.
If the faucet is leaking, you need tools to loosen the faucet to check whether the hoses are leaking or not. If the drainage is leaking, you can tighten the slip nut.
May 04, 2014 | Kohler Model 10430: Fort® Single-control...
Kohler Coralais
Check under the sink to be sure the weight on the hose isn't resting on something, preventing it from retracting fully into the base. Also check to see if the weight might be in the wrong spot on the hose and not pulling the faucet back into the base properly.
Aug 30, 2012 | Kohler K-15160-7 Coralais single-control...
Faucet drips andi don't know how to adjust it so the drip stops.
you will need to replace the washer, you will have to disconnect the faucet underneath and replace the washer,then tighten accordingly
Jul 18, 2011 | Kohler K-15172-FG-7 Coralais...
Kohler - Coralais Pull-Out Spray Kitchen Faucet
te leak most likely is the cartridge you need to take the handle off and there will be a lock nut under where the handle was, turn the water supply off and remove the nut the cartridge will pull staight out, cartridges can't be repaired they need to be replaced. Watch out because some cartridges cost more than what the tap is worth
Jul 12, 2010 | Kohler K-15160-7 Coralais single-control...
How can be removed the bonet of de Kohler kitchen faucet model K-r10430
try this if you need more help just ask... THX
http://www.us.kohler.com/onlinecatalog/pdf/1011154_2.pdf. The bonnet is screwed on and this should give you what you need. If you have any trouble just ask.
Jun 13, 2009 | Kohler K-15176-PT-7 Coralais...
Low flow from Kohler K15160 spray kitchen sink faucet. If I take off the spray handle I can fill a jug through the hose alone (including the filter screen) in 15 seconds while with handle on the same...
Are you sure the spray handle is allowing the valve to open enough to allow enough water through? The problem it seems like is physical or mechanical. I am assuming you get good water flow through the faucet itself.
Mar 01, 2009 | Kohler Coralais Black Single-Control...
Kohler K-15176-PT-7 Coralais single-control kitchen sink faucet with 10" sp Logo
2,563 people viewed this question
Top Kohler Home Experts
john h
Tim Whalen
Mike
Are you a Kohler Home Expert? Answer questions, earn points and help others
