Question about HP OfficeJet d145 InkJet Printer
Printer has not been used for 2 yrs. I use it to make copies.
It wouldn't copy and told me i my ink cartridges had expired. I replaced them with new cartridges (cost $60+/-). Now i'm told i need 4 new print heads. Any way to to get this to copy without breaking the bank?
  • rdj297 May 03, 2009
    How much will new printheads cost me ?
  • 24 Answers
I'm sorry. The printer needs both cartridges (which holds the ink) and printheads (which distributes the ink) as well as the scanner to copy a page for you, since even copying is a print job.
Posted on Mar 08, 2009
Just changed ink cartridges and unable to use printer. Keeps stating printhead missing or has come loose but it isn't. Before this happened, wouldn't print the black ink after I'd installed...
Your printhead is bad and you should have it replaced.This should cost you about $56 if you are in the US
Also you should reolace all the waste ink absorbers,reset the counter to zero and re-insert the ink cartridges.
To replace the ink cartridges
1. Hit the "menu": Key
2. Hit "Copy" Key
3. Hit "#" Key
4. Scroll thru the menu headings until you come to "Test Mode" - 12th heading
5. Hit the "3" button- this will bring up Eprom Clear
6. Hit "0" button
7. Hit the "Stop" button
Jun 12, 2011 | Kodak EASYSHARE 5500 All-In-One InkJet...
I have gone through $100 in ink this month alone for my Lexmark 705 Pro Prevail. It prints like 20 word doc pages (not photos) and then it says it is empty again, and the cartridges need constant...
Check the settings of your printer, either in the software that came with it or the printing preferences in the Control Panel. If your ink tone is set too dark, it could be using a lot of ink. If this is not the case, then:
1) Clean the ink cartridges
2) Replace the ink cartridges as they may have expired. 3) Replace the printer and find one which uses cartridges that can perform more copies in a single fill.
Jan 24, 2011 | Lexmark Prevail Pro705 Wireless All-In-One...
The waste ink absorber is full
I am told that this will reset your counter and eliminate the full absorber warning that you are getting.
Cleaning the pads is messy, sending the printer to Canon is expensive,
I used a simular reset code for my MP470 and haven't had any problems.
1. To clean physical pads:
Open cover (as if replacing ink cartridge).
Locate waste ink pads, they are far right under cartridge slider.
Pry up waste ink pads (inky, might want to wear gloves).
Rinse pads in sink or with alcohol, dry.
Replace pads. Make sure pads are fully seated.
2. To reset waste ink counter:
Press Menu-Scan-Copy-Scan to enter service menu.
Use arrow keys to scroll to "Service menu counter access".
Press OK.
Use arrow keys to scroll to "ABS-M DOT COUNT"
Press Copy.
Use arrow keys to reset count to zero.
Press OK.
Press Stop/Reset.
Jan 04, 2011 | Canon PIXMA iP90 Mobile Printer
Refilled ink cartridges
The reason why the printer says supply expired because the ink cartridge has its own warranty. When the warranty of the ink cartridge has expired then you will get that message. Eventhough you refill it. You need to replace the ink cartridge itself.
Aug 04, 2008 | HP OfficeJet D125xi InkJet Printer
Hp printer 7110
Try to remove the black ink cartridge. From there, you can check the expiry date of the Ink cartridge. If its already expired, then you need to use another black ink cartridge that is not yet expired.
Thank you so much.
Jun 18, 2008 | HP OfficeJet 7110 All-In-One Thermal...
Printing message problems
its not an ink problem but a mechanism problem many things can lead to this: say bad film, week rollers and etc so loos the nprinter n make sure all the mechanism are in place.
May 15, 2008 | HP Officejet 5510 All-In-One Thermal...
2175 printer
This is a typical error with the 2175 / 2100 series.
1.) Error comes up if ink in cartridge's ink level gets too low.
2.) The ink cartridge's copper contacts are dirty. Dirt you can't see. Clean contacts with alcohol & cotton swab's (not dripping).
3.) The carridge contact's need cleaning. (Same as above).
4.) The cartridge, (even though new, can be defective).
5.) You are using a "refill kit" of some kind to refill ink cartridge's.
6.) After 1-5, re-set the printer. Power off printer wait a minute & power back on.
Feb 11, 2008 | HP PSC 2175 All-In-One InkJet Printer
According to " HP Officejet R, PSC 500 and Color Copier - General Copying Issues and Solutions", under the problem heading "Black is not Black", notes that:
"The unit will perform mono (or black) copies using the color cartridge to create a composite black in Normal and Best modes. This is necessary to create the correct grayscale shades. NOTE: The HP PSC 500 all-in-one product cannot perform black copies. Scan the image in and print it out in greyscale.
The color cartridge may be out of one color of ink. Run a self-test page to verify that all the colors are there. Replace the cartridge if they are not."
In other words, the device only uses the black ink cartridge when used as a computer printer. When used as a stand-alone copier, it uses the color ink cartridge, and all three ink colors must be present and working to give a black and white copy. Perhaps you can refill the color cartridge with black ink in all chambers?
Nov 13, 2007 | HP PSC 500 All-In-One Printer
Ink cartridges
i advice you to use the compatible cartridges, else maybe can outhers cartridges make a damage to your printer.
if you want more copies find anouther printer
Nov 04, 2007 | HP DeskJet F380 All-In-One Printer
Supply expired
So many models. Does this model have printheads under the ink carts? If so, remove the print head and clean the jets with a damp Bounty paper towel. Fold the towel up a few times and blot the head into it a few times to clean out the dries ink.
Aug 09, 2007 | HP OfficeJet 6210 All-In-One InkJet...
HP OfficeJet d145 InkJet Printer Logo
257 people viewed this question
Ben Johnson
