Question about Avanti WC494D Compact Wine Cooler Beverage Cooler
No longer cools.
This unit is 1 year old and quit cooling. The motor/compressor gets verry warm. Where can I purchase a new compressor and what might the cost be?
  • 3,361 Answers
This refrigeration system may be under extended warranty.
Otherwise check the compressor start relay for loose or burned contacts.
Posted on Mar 08, 2009
I have an gss221ibma side by side. the freezer no longer freezes but the refrigerator works. Also around the doorframe of the freezer it is quite warm and sometimes hot. please help.
Hello, pull the unit out away from the wall remove the cardboard or metal cover down the bottom which will give you access to the compressor area. Assure that the compressor fan motor which is the fan that cools the compressor is running if it is not then you will have to replace the compressor fan motor. Unplug the unit until the compressor cools if you leave the unit plugged in for a long time you can cause damage to the compressor itself. . If you do not have another place to store your food until you get the new compressor fan motor leave that cardboard or metal panel off the unit if you happen to have a large box fan put it in back of the unit this will cool the compressor until your new part arrives. I have had to wait 8 days for a compressor fan motor at one time and the customer I repaired the unit for had no other place to store there food. Note this fan has to be constantly running on the compressor until you are able to replace the compressor fan motor. If you have any further questions message me back Thanks
Rick
p.s make sure you have your model number when you order your part I tryed looking that model number up but it did not come up on the look up site if you need me to locate the part number that you would use to order the compressor fan motor message me back the make and exact model number of your unit Thanks again
Sep 08, 2011 | GE Refrigerators
My central air went out and I called a tech to fix it. After a few hours he had it back on and we had cool air for about an hour or so...then it quit. I called the tech back out and now we are having to...
Compressors can fail at any time, how old is the unit? You should get at least ten years from a factory installed compressor, Be `sure to get a filter dryer installed on the new one
Jun 22, 2011 | Whirlwind FH-778 Air Conditioner
Frig and freezer has quit cooling. This unit is only 7 years old and has been cleaned of lint and dust every 3-4 months. I am not very pleased with Whirpool, I bought 5 appliances at the same time 7 years...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 19, 2010 | Refrigerators
Refrigerator seemed to run quite often and at max temp kept things cool at best. The refrigerator (refrigerator only no freezer in unit) is 2 years old and it stopped cooling all together yesterday after...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
heatman101
Oct 16, 2010 | Kenmore 60721 Refrigerator
Just purchased new kenmore refrigerator plugged in for 10 hours not even cool inside .motor or fan is running.
Is the fan running? Is the motor running? is the compressor running? Is the air cold? Is there water dripping in to the evaporator tray on top of compressor? Are the coils warm? It can take even longer sometimes I have seen 14-15 hours but not normally.
Mar 07, 2010 | Refrigerators
I have a 10+ year old Kenmore side by side that quit cooling
the starter unit of the compressor can be bad EZ fix if it is that...its the element conected to the compressor :)
Dec 29, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Window unit no longer cooling
you could pull the front cover off and see if there is a loose wire in the control box (behind where the control knobs are). it could just be a bad thermostat. you will see a copper wire with a silverish end on it coming out of the t-stat, try holding it between your fingers for a few minutes to warm it up, turn the t-stat to coldest setting possible, turn unit on, and then see if the compressor will kick on. if neither of those things help you could try replacing the thermostat, probably not expensive from samsung if the unit isn't too old. if that doesn't help either then the compressor probably bit the dust. but if not its worth fixing! hope that helps.
Jun 15, 2009 | Frigidaire FAC107P1A Wall/Window Air...
Is my warming fridg worth repairing?
you will have to get in a technician to do a proper diagnosis to get enough information to make that decision. the service call will be very small compared to the cost of a new unit if the repairs are cheap
because the compressor is working overtime , it suggests that the door seals are faulty and not sealing or the door/s need adjustment
May 18, 2017 | Refrigerators
Refrigerator stopped cooling
The most common problems for refers not cooling is a condenser fan motor (the one that cools the compressor) is out. This can be caused by either a mouse has tried to jump trough the fan and it came on or a loss of grease or oil. There is no way to oil them so they have to be replaced. That is the problem especially if you unplugged the refer and it worked for a while then quit. If the fan doesn't cool the compressor it will overheat and shut down coming on intermittently then shutting off again. As for the refer that still doesn't cool when everything else does you may have an burnt overload also. Check the compressor area for burnt or stalled components ex. fan motor, relay, overload. If your compressor is out plan on spending from $300.00 to $500.00. But check the suggested components first. And beware there are appliance shops out there that will find one of these problems and give you an estimate for a compressor. Find someone reputable.
Jun 18, 2007 | KitchenAid Superba Architect KSCS25INSS...
Avanti WC494D Compact Wine Cooler Beverage Cooler Logo
265 people viewed this question
Top Avanti Refrigerators Experts
Vernon Taylor
Are you an Avanti Refrigerator Expert? Answer questions, earn points and help others
