The new engine wont idle start and shut down immediately 3.0 turbo diesel
SOURCE: toyota hilux surf problem
hi there, i had exactly the same problem with mine. all i did was to turn up the diesel pump a little. cheers d
SOURCE: Surf 1KZ-TE Diesel wont fire
I have the same problem. it just wont start one morning. can you please help me in case you have solved your problem already.
SOURCE: Toyota Surf Diesel starting problem
Injectors could be blocked but i would go with an injector pump or fuel pump.
SOURCE: How much lb ft. of torque should i put on the
what is the valve clearance and cylinder head torque for toyota 2lt diesel engine
kasim
I found that the injector pump was bad change for a different one and all is well, thanks for you response.
