Question about Whirlpool Calypso GVW9959K Top Load Washer
How to lift top of front load maytag washer - Whirlpool Calypso GVW9959K Top Load Washer
    Sergeant:
    Champion:
  • 214 Answers
You need to remove the door hinges and screws on the opposite side removefront panel next you will need 5/16th nut driver to remove the 2 clips on the right and left top corners .After that you will need to open your soap dispensor lid and remove 4 star (philip) screws then the top should lift up:)
Posted on May 07, 2009
How do you get to the wate level pressure swith on a maytag neptune front load washer model #mah55flbww
First make sure the washer is unpluged. Remove the two screws on the back side of the top cover. Then you can slide the top cover off by pushing backwards and lift. Now you will expose the controls. One of the controls on the right side of the washer that has a clear 1/4 tube hooked up to it is your pressure switch.
Jun 07, 2014 | Maytag MAH6700AWW Neptune Front-Load...
I have a Maytag Centennial MVWC6ESWW1 and need to know how to lift off the top cover to get to the lid switch?
There are two hinges at the back, just remove two screws on top then push the top toward the front about 1'' or 1.5'' then lift it up.
Sep 30, 2013 | Maytag Centennial MTW5800TW Top Load...
Step by step for removing panel on top load maytag washer
1) Unplug machine.
2) Use a putty knife or flat blade screwdriver and compress the clips located about 4" in on the front of your machine (there is one on each side) lift the top of your machine up.
3)Use flat blade screwdriver or 5/16" nut driver and remove the 2 screws holding the front panel on. Wearing gloves because there may be sharp edges and using care lifting, sit the panel aside.
Oct 19, 2012 | Maytag Ensignia MAV4757AWW Top Load Washer
How do you get to the latch ? The back part of the top of the washer lifts up but can't get the front to lift.
The front is probably held down with some snap clips, try wedging something in the gap and bumping it.
Jan 18, 2011 | Maytag Neptune MAH5500B Front Load Washer
How do you get the front off the maytag mav8601aww?
If you have the top loader, there is 2 clips on the left and right wher the front panel joins the top section. Push a flat blade in one side while trying to lift the top at the seam, it should pop open. If you raise the top there is 2 screws top left and right of the front panel inside remove these and lift the front panel up and away.
Sep 05, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Water leaking from machine,trying to lift top of washer looks like hinges in back but cant seem to open
usualy there are hinges in the back and spring clips in the front, lift the front top usiing a bit of force( pry it with a thin piece of wood). make sure all the screws are off around the top , and pull out the lint fillter , there may be 2 more screws there
Jun 21, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
265 people viewed this question
Dan Webster
Dan Webster
Sal De
