Operating instructions for Onkyo PL-25F turntable
Have a Onkyo PL-25-F fully automatic turntable and think that they stylus is in a locked position. We do not have instruction booklet...can you help?
I have the same problem with mine! If i budge the arm by pushing it to the left a bit, it seems to catch. i think the motor on mine is worn out and cannot get started on its own, but with help, it will slowly move on its own to the edge of the vinyl and drop into playing position. If that doesnt work for you, you might need to clean the belt for the arm motor, or buy a new motor.
Posted on Sep 11, 2009
We have a kenwood p100 turntable. It starts turning automatically when the arm comes over but it misses the first bit of the song. it doesn't kick in ! Can we adjust it and if so , how??
The manual shows that it is not an automatic turntable you have to position the stylus over where you want to start. Then you press the cue button to send the stylus down.
One thing that might cause it to move down wrong is vibration or movement of the deck. Make certain any transit screws or in the correct position for play and that the surface you have it on doesn't move. IE: no floorboard movements!
Oct 29, 2016 | Kenwood Audio Players & Recorders
Changing the needle-how to!
Replace the Needle with a new one (part No. PZP1004) . Remove the old Stylus (or Needle) by pulling it downwards gently, and push the new Stylus/needle in place as shown in the below photo.
061fed0.jpg hope this works for you,
Cheers
Emmanuel
Sep 13, 2008 | Pioneer PL-990 Turntable
How do I adjust the triggering position of the automatic switch off and tone arm return on a Harksound (by CEC) HS 210 Semi Automatic turntable?
Hi, at the base of the tonearm you will find a rubber grommet. Remove the grommet and insert a flat blade screwdriver. Adjust screw to the right until arm lands in correct position. Cheers john. Stylus City.
Oct 27, 2014 | Audio Players & Recorders
Converting a turntable from automatic to manual
I suppose the only way to do it would be to stop it functioning completely. The only way would be to dissasemble the auto function. What you would need to do is work out which parts are essential for the turntable operation and which only activate the return. So you need to whatch the mechanism working. You will need to remove the base and look at from underneath, just like going underneath a car!
I can't say for certain if you can do it, only you will be able to determine it can be removed without affecting the operation of the entire turntable.
May 21, 2010 | Pioneer PL-990 Turntable
Turntable tonearm returns but starts playing record over again.
http://www.vinylengine.com/library/pioneer/pl-570.shtml
on page 8 of the above service manual for your model it shows 4 electrical switches that tell the computer what 'state' the mechanism is in at any given time. Either one or more of the switches are intermittant or the mechanism has dried up grease that is slowing down the operation and basically gumming up the works. the old grease would have to be removed and replaced when it is causing binding. The switch just to the right of where is says "microswitch ksf-023" is an 'open air' type and so would be the most likely suspect. it simply needs to be cleaned with a super fine file designed only for cleaning switch contacts. THIS SERVICE SHOULD ONLY BE PERFORMED BY QUALIFIED PERSONNEL ONLY!!!!!
Jan 21, 2009 | Audio Players & Recorders
No sound from my record turntable into my computer.
If you're certain there is no sound going out of the TT...
Setting the Pre-amp Switch
For increased flexibility of use, this turntable has an internal
stereo phono pre-amplifier. The Pre-amp Selector Switch
is located under the turntable platter, in the rear-center
(Fig. 1). If the system amplifier you are using has a PHONO
input, set the Pre-amp Selector Switch to the “OFF”
position. If your amplifier does not have a PHONO input,
set the Pre-amp Selector Switch to the “ON” position and
connect the turntable’s output cables to the AUX or other
high-level input on the amplifier (described later).
Turntable operates, but no sound at all
1. The stylus guard is still in place.
2. The tone arm Lift button is pressed in.
3. Amplifier controls set incorrectly: wrong input selected,
tape monitor on, speakers switched off, etc.
4. Check the stylus on phono cartridge for correct placement.
Refer to the instructions for replacing the stylus
on page 5.
Turntable operates, but no sound, or sound not loud
enough
1. If the turntable is connected to an AUX (high-level)
input: The Pre-amp Selector Switch may be set to the
“OFF” position (phono-input level).
2. The input gain of the amplified speaker or similar
device may be too low.
3. The stylus assembly may not be fully seated in the
cartridge body.
You could also isolate the problem to either the TT or the PC by trying the TT on some other sound device like a receiver. Make sure the PreAmp Selector switch is ON and plug the TT into any AUX, CD or TAPE input.
Sep 02, 2008 | Nakamichi AV-7 Receiver
730 people viewed this question
 Grubhead
Grubhead
