Question about Hotpoint Aquarius WD63 Front Load Washer/Dryer
Hotpoint WD63 dryer not working
Hi
Set the dial to dry and nothing happens? washing machine working fine and can set to spin but no dry mode?
anyhelp
  • Anonymous Mar 24, 2014
    dryer nor working. need a diagram oftop of machine, please
  • 20 Answers
Hi Jacky, Please make sure the power is off and unpluged.On the rear of the heater element board you will find a thermal cut out switch (it's about as big as a 5p piece with an oval outer body) what happens is the heaters overload and pops the bimetal switch, on the back of the switch you will see a small hole just big enough to fit a pin in, get a pin and gently push the bimetal disc and it should pop, if it does then you are fixed.
Posted on Mar 10, 2009
My Hotpoint Aquarius WD440 smells of hot rubber when it is on the M (drying) programme and the clothes come out smelling of rubber. Can you tell me why this is happening. Everything is working fine...
Hotp[oint Aquarius WD440 washer /dryer - Has a distinct smell from clothes when washed like stagnant water is lying somewhere in the machine, It has all benn stripped down but cannot find anything wrong. Whats the solution????
Aug 11, 2011 | Hotpoint Aquarius WD63 Front Load...
Hotpoint WD63 not spinning correctly
Two things to check.
Remove rear cover.
Remove large black hose onto drum
Remove and clean filter inside hose.
Next--remove top cover and check the brushes in the motor, if they are less than 3 or 4 mm long, then replace them.
Please rate my solution.
Thanks.
Nov 24, 2009 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Aquarius WDD440 washer and dryer
Possibly Pump blocked. or impeller broken. without taking a proper look but sounds the obvious.
Jul 26, 2009 | Hotpoint Aquarius WD63 Front Load...
Hotpoint aquarius washer dryer wd63 1100 spin - my fuse went just as i was switching the machine on - so the door locked and wont open - changed the fuse, door was still locked so thought id let the wash...
Try buttons "dry" & "spin" together for a few seconds. This is the child lock display.
Or press "end of cycle" for over 3 seconds.
Or press "options & select" till the light goes off.
Works for other machines..............And please rate me if helped
Jan 22, 2009 | Hotpoint Aquarius WD63 Front Load...
Door wont open on my hotpoint aquarius washer/dryer
Turn the dryer dial to off, making sure you can hear it click off, wait 1 min, and then try door. If it will still not open then you may have faulty door lock, or a prob with the door handle.
Plz rate my solution.
Thanks.
Dec 29, 2008 | Hotpoint Aquarius WD63 Front Load...
No fast spin
Could be blockage in pump or filter, if there is a blockage then the m/c will not spin with a lot of water in it.
Dec 13, 2008 | Hotpoint Aquarius WD63 Front Load...
Programing a wash without drying
I had the dial on the wrong setting sorry to be a pain
Julie
Dec 01, 2008 | Hotpoint Aquarius WD63 Front Load...
Dryer
FIRST - UNPLUG IT!
First check the one shot thermostat - thete are 2 stats on the top of the heater box - it's the one with the staggered connector terminals - then let me know
Mar 21, 2008 | Hotpoint Aquarius WD63 Front Load...
Dryer doesnt always work
it is your stat its the white one when you take the lid off its right down in fount of you make sure you unplug the machine take it out and take it to your local appliance shop they should order you one there really cheap £3.00 it don't mater where the weirs go theres only 2 of them they will go on the new stat the same way you took them off the old one
Dec 28, 2007 | Hotpoint Aquarius WD63 Front Load...
Problem with our washer/dryer
sump/filter is blocked instead of flushing on dry cycle is filling as not pumping well. ring hotpoint to reorder pts cheaper then anyone
Jan 06, 2007 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Aquarius WD63 Front Load Washer/Dryer Logo
89 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
