Question about Visonik VB-10PKG Car Audio Amplifier
Need wiring instructions for vbx12a
Looking for proper wiring instructions for subwoofer with amp,can you send me correct way thank you arthur
  • 61 Answers
You will need the following:
A power wire (preferably 4 or 8 gauge) with an inline fuse (typically 50amps)
A battery terminal adapter to connect the power wire
A signal wire to let the amp know when the stereo is on
RCA audio cables to connect the amplifier to your stereo
A ground wire for the amplifier (again 4 or 8 gauge preferred)
Walmart sells a Scosche kit that has all of the wiring as well as a basic diagram for about $25, but it does not include the battery terminal adapter.
If you have a factory stereo you won't have RCA ouputs, so you will need a line level converter. A basic one like the Scosche SLC4 usually runs in the $20 range. You splice into your speaker wires and run them into the unit, then plug the RCAs into it.
Posted on Mar 29, 2009
I would like to connect my Philips subwoofer to my Pioneer multi channel receiver, but the subwoofer's input has only a 15 pin serial port connection. I need an inexpensive and easy solution?
Unfortunately, most subwoofers , like the one you're describing, need a separate amplifier. I don't know the model number of what you're working with but most Phlips subwoofers with that connection need an amp. Now, if you have the rest of the system that was originally with the sub then you can scavenge it's amp. But that's tricky if you don't know what you're looking at. Craigslist has tons of "powered" subwoofers that don't require a separate amp and u can therefore use your Sub Preout from the HT receiver.
Feb 13, 2016 | Pioneer Audio Players & Recorders
I need to move the amp off of my visionik vbx12a sub to the front of my car but when u remove the amp off the sub u realize there isnt a back to the amp so the its circuits are just out there so where...
maybe you can build an amp rack some where else in the car or behind a pannel but make sure you use some kind of 12 volt fans to keep the amp cool . then extends the wire to the subbox and then you have to disconnet the subbox and move it not the amp
caraudioquestion@gmail.com
Oct 14, 2010 | Visonik V15S4 Car Subwoofer
Does not want to work
to make sure it's the subwoofer at fault and not the amp, speaker wire, rca's, radio, power, or ground wiring, you should, if possible, hook up a known good subwoofer to see if it works properly. if it doesnt, check fuses, grounds, the remote amp turn on wiring, etc. it could even be something as simple as a setting on the stereo itself. if the substitute subwoofer does work properly, double check to be sure the original sub is wired correctly. if it is, i'm afraid you've got a faulty/bad subwoofer. I hope this helps and good luck!
Feb 17, 2010 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Power going to amp and wired correctly but sub wont work
Well if your amp is connected corectly .Your sub, is not connected try open from the box and check it needs to rewired.once's the sub, is conneted properly it should sound.
Jan 05, 2010 | Fusion FEW12PK Car Subwoofer
Power in amp but no sound to speakers
you need to make sure youre getting a signal from the source, RCA's I suppose. Check for loose connections or broken wires. make sure to have 12v+ on power and remote inputs at amp...proper ground too. Lastly, check your ohm loads at speakers, maybe one is about dead. make sure crossover settings are correct.
good luck!
Sep 17, 2009 | Pyle BZDBP212 Car Subwoofer
No sound..amp has power to it
Hello eric_sodergu,
**First thing is verifying that the powerlight is lite up, this shows that it is receiving power and is grounded properly.
**Next thing you need to ensure is that the remote wire is connected properly on both the head unit and the amp.
**Third Make sure the RCA wires are all connected properly, try jiggling them around on the amps end to make sure there not just shorting out.
**Check all fuses related to the amp to make sure all the channels are working properly. (Applys to amps with multiple channels and fuses)
If all these things are fine, then the sub could very well be blown. Did you have it up loud before it stopped working ? You said it was working fine then just went all quiet, did the head unit power down as well ?
Post back with any further info or questions so that I can assist you further.
Jul 17, 2009 | Infinity BASSLINK Car Subwoofer
Bmw 525td speakers subwoofer amps instalation
tell everything that you have so that we can go step for step over everything
May 19, 2009 | Dual XINBP212 Car Subwoofer
Vbx12a blows fuses when you power it up!
Make sure your gain is turned all the way down. Unplug the RCA cables before hand. What does the subwoofer do when the amp powers on?
Feb 08, 2009 | Visonik VB-10PKG Car Audio Amplifier
HELP
hi there, do you have an amplifier to hook it upto mate? if you do its best to go into your local halfords etc and ask for a wiring kit for you car audio, or search on ebay, theyre normally around 20pounds. then it will come with instructions on where certain wires go etc, the 8 outputs are probably so you can connect two subs together. they should have a pos and neg on them somewhere. if you dont have an amp you probably need to buy one. if you have any further queries just ask mate
Nov 13, 2007 | AudioBahn AW1206T Car Subwoofer
BLUETOOTH Car Kit Type No. BTHCK 100
Connect the fuse kit's GREEN Ignition Sense wire (3 amp fuse - switched) to an ignition switched location on the fuse block. When the ignition is off the sense line is low.
Connect the ORANGE entertainment mute wire to the vehicle's entertainment system. (that is if your stereo supports it)
Connect the RED Positive primary lead to a 4-10 amp fused connection
Connect the BLACK ground wire to the vehicle chassis.
YELLOW & BLUE are not used.
Oct 22, 2007 | Motorola Mobility Bluetooth??¢ HF850 Car...
Visonik VB-10PKG Car Audio Amplifier Logo
898 people viewed this question
Top Visonik Car Audio & Video Experts
Tygh Duval
Tygh Duval
Joe Alexander
Joe Alexander
Jerry Umali
Are you a Visonik Car Audio and Video Expert? Answer questions, earn points and help others
