Question about Culligan Under Sink Water Filter
Culliagan aqua-cleer drinking water sytem: under sink install
I need to know where the all the hoses are to be installed on the system serial #AC15100560 models H-30S-R, H-30 PRV-C. The hoses were all removed and I want to put it back together if possible... I have all the hoses, there are 2 filters and a pressure tank? this is fed up to a small tap at the kitchen sink. Thank you for your asstistance.. TC, AB, Canada
  • 13 Answers
Refer to the below link for the h-30 installation manual.
http://www.freshwatersystems.com/t-manuals.aspx
FreshWaterSystems.com: The Water Super Store: 1-877-335-3339
Posted on Apr 28, 2009
How much time does culligan man need to install drinking water system under sink
Time = degree of difficulty from the lack of space
it also = the amount of pipe preparation needed to fit the system
so a reasonable amount of time would be 1 hour minimum to a max of 4 hours after which the person would be playing on your patience
always get WRITTEN quotes first from several installers and accept the average
Sep 18, 2017 | Culligan Tools & Hardware - Others
Drain line constantly drips out of my aqua cleer water drinking system
Hi!you can use any wet/dry sealant to put on your dripping line.
Sep 03, 2011 | Home
I have a Culligan AC 30 aqua-cleer drinking water system;after changing the particle filter and the carbonfilter , the storage tank does not fill.I have pumped air in it to pressure 0,7 bar.
When you put air in the tank did you make sure all the water was out of tank? In a three gallon tank there should be 7 lbs of air, 10 gallon 10 lbs of air.
There can be many reasons for no water in tank.
1. Bad bladder in holding tank. No back pressure on membrane (all water going to drain)
2. Faulty membrane (all the water going to drain)
3. Bad capillary tube (all the water going to drain)
4. Plugged check valve at top of membrane (no water)
5. Faulty water feed valve (piercing valve)
6. Fines from post carbon filter have plugged up the manifold (head) of RO unit.
7. Bad valve on RO tank
8. Plugged drain line
RJ
Jul 30, 2011 | Culligan Under Sink Water Filter
Don't understand the incomprehensible door and general installation instructions for the aqua star. Just uses pictures, anywhere available that uses WORDS?
  • 1 what you'll need
    Electric drill and hole cutting bit
    Screwdrivers
    Pliers
    Adjustable wrench
    Level
    Teflon pipe tape
    Drain pipe for dishwasher
    Dishwasher connection kit - available at your home store (should contain water supply line for dishwasher as well as necessary connectors and compression couplers).
    New dishwasher
  • 2Determine that you have access to the hot water supply line, the drainpipe and an electrical connection under the sink. Installing the dishwasher will require extending the hot water supply line to the dishwasher, connecting the dishwasher drain to the drainpipe under the sink, and plugging the dishwasher in. If your home was not plumbed in anticipation of a dishwasher, you will need to change some fittings under the sink to make these connections possible. (See below)
  • 3Read the instruction manual that comes with your new dishwasher. Installing a dishwasher is straightforward but you want to be sure you understand and are comfortable with the necessary steps.
  • 4
  • Thanks for using fixya.
  • Jul 19, 2011 | Bosch Dishwashers
    Just installed aqua/cleer reverse osmosis system and the water doesn't seem to be going into the holding tank, however there is water that is coming out from the tap.
    Make sure all the lines are hooked up correctly. It is going to take 3-8 hours to fill a 3 gallon RO storage tank. It depends on the capacity of the membrane (IE: 14, 20, 30, 50 or 75 gpd). It also depends on the TDS of the water. Water that has high TDS 500+ppm will take longer to produce product water than TDS of 100ppm. Check the pressure in the RO tank. When empty (In a 3 gallon tank) there should be 7psi pressure. A ten gallon tank takes 10psi. If it needs air you can use a bicycle pump to add appropriate air. Make sure the tank valve is turned off when adding air.
    Do not use the RO faucet for several hours to allow tank to fill up. Also you should dump the first couple tanks of RO water to make sure any carbon fines are rinsed out.
    RJ
    Nov 07, 2010 | Culligan Under Sink Water Filter
    Where can I get a manual for Culligan Aqua Cleer?
    I found the manual for an Aqua Clear AC15 at the following web site. Go to the below web site and locate the filters for your system. There will be a link to the manual in a .pdf format.
    http://www.freshwatersystems.com/s-69-culligan-water-filters.aspx
    May 15, 2010 | Culligan Under Sink Water Filter
    Lost water pressure on house
    it is normal to loose pressure from the filter it must have very small holes in it for the water to pass threw so it can trap dirt and particales from both well and city water. it is normal for it to cut back on pressure, it will cut back more and more as it catches the things that you are filtering out. what you might want to do is filter your drinking water only, under your sink .dont try shower and outside faucets. and you wont have to replace it as often. well good luck and good day to you... sawdust46
    Jul 03, 2009 | House Brand Aqua-Pure AP102T Whole House...
    Drains Technical Question
    Plumbing codes call for a gap between potable water and a drain. This usually looks like the distance between the faucet and the top of the sink or bathtub (one inch or more). Without the "gap", waste water could siphon back into the drinking supply. This "does" happen in situations where a city main is shut off causing a drain-down of the system with plumbing that has been done improperly. Sometimes it is a hose left in a mud puddle, or maybe a hose lying in bleach water. People have died this way. The plumbing code helps protect the general public from these dangers. Current improvements include antisiphon faucets for garden hoses, the air gap for the dishwasher, proper installation of water heater T&P relief drains, and backflow preventers for irrigation systems.
    Aug 27, 2008 | Elkay LK58 Drain
    How do you "undo" the aqua stop?
    create an inverted trap in ther dishwasher drain line so the water cant back feed
    Jul 09, 2008 | Bosch 24 in. SGS43C02 Classixx Built-in...
    Culligan Under Sink Water Filter Logo
    442 people viewed this question
    Top Culligan Tools & Hardware - Others Experts
    jmgerny
    Level 1 Expert
    Craig Butler
    Craig Butler
    Jim London
    Jim London
    Are you a Culligan Tool and Hardware - Other Expert? Answer questions, earn points and help others
