Question about Makita DPC6410 64cc 12" Power Cutter
What are the carb settings for makita dpc6410
3 Suggested Answers
  • 1341 Answers
SOURCE: MY MAKITA DPC6410 PETROL SAW IS RUNNING SMOKEY
It uses 2 stroke oil during combustion as it is a 2 stroke powered engine..Sometimes it may be a small deposit of oil and the bottom of the gas container which causes this smoke or else you may have added a bit more oil than needed in the fuel..I assume it is a 2 stroke engine and also note these do give out a little bit of smoke..
Posted on Dec 08, 2009
Testimonial: "THANKS FOR THE ADVICE WILL CLEAN OUT TANK AND REFUEL."
  • 885 Answers
SOURCE: regarding makita petrol disc cutter dpc6410- how
Don't add oil to the fuel tank, it doesn't mix well in there and you'll almost always use too much oil. Mix your two-cycle oil and petrol in a gas can to get a 50:1 mixture. Read the directions on the two-cycle oil bottle for how much to use and put the oil in the can first so the petrol will mix well with it as you add it to the can.
Posted on Oct 11, 2010
My makita 6410 started first pull ,cut about three bricks now wont start, it pulls fine and sounds like it wants to start but wont, i think i may have put too much oil in, will this cause this problem,...
yes to much oil with the petrol will cause problems i`m afraid the carb is now blocked with oil and will need cleaning out problem is that the carb is micro chip controlled and it will need to be cleaned out at a repair/service center
hope this helps
John
Sep 14, 2011 | Makita DPC6410 64cc 12" Power Cutter
Regarding makita petrol disc cutter dpc6410- how much oil do i need to add to a full tank?
Oct 11, 2010 | Makita DPC6410 64cc 12" Power Cutter
Dec 08, 2009 | Makita DPC6410 64cc 12" Power Cutter
Will not tick over how do i set up the carb for this and normal running.
Most carbs are the same. Close both the high and low needles. (Note: Do not overtighten, you can damage needle.) Open them up 2 full turns. Start the engine and let it warm up. May be a little tough to start if you have removed carb and rebuilt. With engine running pull throttle to full capacity. Now close the low needle slowly, listening to the engine. When it starts to get lean you will hear the rpm start to go back down. Make sure you stop at the most optimum setting. At this point open the low needle 1/4 turn so as not to have too lean a mixture. Please note that the engine must be warm in order to get the right setting. You may have to do this a couple of times to get it right. Then move on to the high needle and do the same thing. Once you set both needles it should be fine.
Sep 09, 2009 | Makita DPC6410 64cc 12" Power Cutter
No operators manual for makita dpc 6410 petrol disc cutter
Come on, it tooks me 20 seconds to find it...Web search is all about keywords. makita dpc 6410 manual leads to the answer. Adding pdf would have been even better...
Aug 01, 2009 | Makita DPC6410 64cc 12" Power Cutter
I have a makita dpc6410 disc cutter.it has a good spark and i have cleaned the carb and pressure tested the carb and the needle is holding and i have fitted a new fuel filter.it will fire up and run flat...
after servicing the carb,do u retune it?
blacking around the piston is no big deal for a small engine,as long as the piston rings are in order or in other words it still has compression.
check the fuel supply..
the tank should be airtight...
it is a diaphragmed carby...
Aug 17, 2008 | Makita Tools 18V 1/2" Lxt Lithium - Ion...
Makita DPC6410 64cc 12" Power Cutter Logo
1,193 people viewed this question
Top Makita Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Makita Measuring Tool and Sensor Expert? Answer questions, earn points and help others
