Question about Lexmark X4270 All-In-One InkJet Printer
My printer has error 1203 and it want print - Lexmark X4270 All-In-One InkJet Printer
  • mack_stephan Mar 08, 2009
    My lexmarkx printer is still saying error 1203 this did'nt happen until i got my ink cartiadges refill.what else can i do to make my printer print & i still see error 1203.the first tip did'nt work.
  • Lexmark Master
  • 19,396 Answers
Error 1203 is cartridge error, if it does not reset replacing cartridges and cleaning the cartridges contact inside the ink carriage, then you have a contact on the ink carriage connectors.
Usually you fix e 1203 by power cycling the printer, replacing cartridges or cleaning cartridge contacts.
Posted on Mar 08, 2009
  • 42 Answers
Your print catridge has a short . Press power to turn your All in one off , Unplug your All in one from the wall outlet , Plug your All in one , Reinstall the catridges . If this doesn't work reeplace ur catridges
  • 1,031 Answers
The 1203 error message is caused by either a communication failure between one of the printheads (cartridges) and the All-In-One (AIO), or by a short in one of the printheads.
Resolution
  • If the problem is occurring during the normal printer lifetime, the procedures below will help you to resolve it.
Troubleshooting a Communication Error between the Cartridge and the Printer
Power off the All-In-One (AIO) and remove the power supply from the back of the unit. Wait 30 seconds, then reinsert the power supply and power the AIO on.
Did the error message return?
Yes: Continue to Step 2.
No: Print a test page. If the test page prints, the error is resolved.
    Sergeant:
    Champion:
  • 224 Answers
Error 1203 is an issue that occurs either when a cartridge is bad or the printer cartridge Slot is bad... I would request you to try cleaning the copper contacts of the both carts and cart slot in the printer and try again..
Generally, an error 1203 is result of the cartridge not making connection properly
    Brigadier General:
  • 8,619 Answers
Hi!
Its a known issue and is related to leaking ink cartridges or the printer cartridge Slot is bad
1 - try cleaning the copper contacts of the both carts and cart slot in the printer and try again..
or
2 - when error shows up, shut the printers power off; wait one minute and turn it back on press copy
If this doesn't work you need to get your cartridges replaced.
Thanks
Rylee
  • Rylee Smith
    Rylee Smith Mar 08, 2009
    As you are using refilled cartridges, so the warranty will get void if its under warranty.
    Use orignal (new) cartridges to remove this error.
    Genius:
  • 1,550 Answers
First Try reset .
Unplug the unit from power chord for 30 minutes and plug back the power chord to the unit .
This will reset your unit .
  • SAM ANDERSON Mar 08, 2009
    Error 1203 means your cartridges overflow even from brand new cartridges after a
    several prints or right after you refilled the cartridges. Check to see
    if ink are smeared on the holder where the contact panel with the
    cartridges.
    Try this use the klennex with a few drops of water to dampen and clean off those contact on the holder .
    The
    refill ink work very well if you let it sit 24 hrs. Then before you
    print anything, you should run aligned the cartridges a couple times
    then run clean cartridges a couple times.
    Print the test page to see how it's look and way you go.
    Be sure not to leave any debris of klennex on those holder contact panel.
    Source:fixyourownprinter.com
    cartridges.
    The
SOURCE: Error #1203
Call your lawyer and suggest a class action law suite. IT"S A KNOWN ISSUE!!!
Posted on Dec 24, 2007
yooperbud
  • 8637 Answers
SOURCE: Dell 926 Printer, Error 1203,
Normal 0 Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 24, 2009
  • 514 Answers
SOURCE: Dell Printer 924 error #1203
go to page 59 of the manual ("http://support.dell.com/support/edocs/systems/924/en/om_en/om_en.pdf" if you don't have it) look for
code 1203 in the middle of the page. good luck!
Posted on Feb 28, 2009
Roop1980
  • 228 Answers
SOURCE: Error 1203
The error 1203 error message on the operator panel could indicate a problem with one of the ink cartridges. Please follow the steps given below:
1. Please make sure the All-In-One is powered on.
2. Pull the control panel towards you, and then open the cartridge access door. The print cartridge carrier moves and stops at the loading position.
3. Pull the old cartridges towards you, and then lift them out.
4. With the cartridges out of the printer, shut the access door and the control panel.
5. Power the printer OFF and then back ON.
6. Please check the operator panel to see if the same error has returned or if a new message has appeared.
7. If the message displayed is 1203, there is something wrong with the printer hardware.
If the message now displaying is Cartridge Missing, do the following:
1. Reinstall the cartridges into the printer.
2. Insert the color cartridge in the left carrier. Insert the black cartridge in the right carrier.
3. Push back firmly on the cartridges until they snap securely into place.
4. Close the cartridge access door, and then close the control panel.
5. If the 1203 message is still present on the operator panel, you need to insert one cartridge at a time to determine which cartridge is producing the failure.
6. With one cartridge in the carrier, close the access door and control panel.
7. Please check the operator panel. If the 1203 error is displayed, this cartridge is the defective item. If the Cartridge Missing message is displayed, the second cartridge is producing the failure.
8. Please replace the defective cartridge.
Posted on May 23, 2009
  • 83 Answers
SOURCE: error 1203
1. Press Power to turn your All-In-One off.
2. Unplug your All-In-One from the wall outlet.
3. Plug in your All-In-One.
4. Reinstall the cartridges.
If this does not resolve the problem, replace your cartridges to fix the problem.
Posted on Nov 26, 2009
What is error #1203?
MY PRINTER WAS PRINTING AND ERROR #1203 JUST CAME UP AND IT STOP PRINTING.
Aug 01, 2012 | Dell 946 All-In-One InkJet Printer
I want to print the letter . on the machine's screen i saw error #1203. it wrote consult user guide . could you tell me how to slove the problem
1203 error indicates a communication problem with your printer and one of your cartridges. Please refer to this article in the Lexmark website: How to Troubleshoot a 1203 Error on the Lexmark X4250/X4270/F4270 Printers. This will help you identify and resolve the 1203 error message on your printer.
Apr 21, 2011 | Lexmark X4270 All-In-One InkJet Printer
Lexmark printer problem. Printer is not printing shows error 1203
Hi
Error 1203 Dell 962
There can only try and I hope it will do the job for you.
or
press copy
you may need to Reset Factory Defaults
Mar 01, 2010 | Lexmark P4350 All-In-One InkJet Printer
I have error eading 1203 what is that and how can
I have an error reading 1203 that won't let me print. Message consult users guide.
Oct 08, 2009 | Lexmark X4270 All-In-One InkJet Printer
Error 1203, will not print only gives error 1203, no test will print
or
2 - when error shows up, shut the printers power off; wait one minute and turn it back on press copy.
Jul 20, 2009 | Dell 944 All-In-One InkJet Printer
Error 1203
Try this may do the trick
ERROR 1203 LEXMARK ERROR 1200 Error 1203 is an issue that occurs either when a cartridge is bad or the printer cartridge Slot is bad...
or
Aug 15, 2008 | Lexmark F4270 Plain Paper Inkjet Fax
Error 1203
You can try testing your Printer with another Print Cartridge and if the error message repeats, you should contact Service Center as then there would be a Hardware Problem.
Jul 15, 2008 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Dell Printer 924
I kept pressing menu, since it would not bring it up turned it off and on, it fixed itself, now it is printing.
Jul 14, 2008 | Dell 922 All-In-One InkJet Printer
Error 1203
please send me info to solve the problem on my fax
23768838.jpg Error 1203
Jan 17, 2008 | Lexmark X4250 All-In-One InkJet Printer
Error #1203
Normi, The 1203 error as you suspected deals with the ink cartridge. This is a common problem and Lexmark has a troubleshooting procedure posted on their web site. Here is the link for the web page. http://support.lexmark.com/cgi-perl/knowledgebase.cgi?ccs=229:1:0:439:0:0&emeaframe=&docid=ENUS21870 Hope this solves your problem and please don?t forget to rate this posting.
Jan 20, 2007 | Lexmark X4270 All-In-One InkJet Printer
Lexmark X4270 All-In-One InkJet Printer Logo
37 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
