Question about LG GCE 8523BB (GCE-8523BB-10PK) CD-RW Burner
Can't get the disc out...
The door seems to be jammed on my cd-rw drive. Can't eject the disc by physically pushing the eject button or by selecting "eject" from the "my computer" menu
    Brigadier General:
  • 5,158 Answers
Is the light flashing on the drive ? .... be that as it may you will note a small hole on the face of it.... put a small round object in there and push... that should open the door.
Posted on Mar 08, 2009
CD DRIVE DOOR BUTTON JAMMED ON AX5900
You should see a small 'pin hole' on the face of the CD drive, usually near the eject button itself, but not always. Straighten a paper clip (med size is best) and insert into the hole. You will feel a little resistance (this is good) continue pushing the paper clip straight in until the door pops open. Almost all CD/DVD drives have this "manual open" pin hole for just such cases. Alternately you can open My Computer, point to the CD/DVD icon, right click and choose the "eject" option, this will open the tray if the physical button has stopped working.
Jul 15, 2014 | Acer Computers & Internet
How to eject disc
To eject a CD from your disc drive, follow these steps.
1. Go to My Computer.
2. Right-click your disc drive (e.g. DVD RW Drive (D:)
3. Select "Eject."
It should automatically eject your disk. If not, there may be a hardware problem where you might have to contact your manufacturer. Hope this helped.
Dec 04, 2013 | Computers & Internet
My MSI GT660 Dvd will not open or eject
There are two ways to open the CD/DVD drive door if the button just below the drive tray does not work.
Go to My Computer and right click on the drive and click on Eject.
If this does not work then you can manually open the CD/DVD drive tray by -
Straighten a paper clip and gently insert it into a tiny hole below the drive tray next to the Eject button. Push the paper clip gently until the drive tray pops out, then pull the tray until it is fully out, then you can remove the CD disc.
If you still having problem opening with the Eject button, then the CD/DVD drive is faulty and needs replacing.
Feb 18, 2013 | MSI GT660 Series CD 8X DVD RW DL Burner...
I got this computer and the cd door isnt opening i thinks its jammed but i dont know
What you can do to get it open is there is a small hole on the cd drive. take a paperclip and straiten it ans strait as you can get it and put it strait in that hole and push then also you may need to push the eject button at the same time :)
Dec 23, 2010 | Dell DIMENSION 3000 CELERON 2.4GHZ...
Key of eject CD/RW on keyboard do not work..
hi there,
Try to find that little tiny hole on your cdrom's door and push a paperclip and hold it until it ejects. That's another way to eject the cdrom.
Hope this helps.
Thank you for using FixYa.
Aug 28, 2010 | Computers & Internet
My sony cd-rw crx320ee does not eject but it can read cds
When you say "not eject", I'm assuming you have tried ejecting from a physical button on the drive as well as selecting eject in Windows Explorer. If not, give it a try. If still a problem, note a small hole in the drive. Open a paper clip and gently place one end in the drive. The drive should open. Hope that helps.
Jul 16, 2009 | Sony CRX320EE CD-RW/DVD-ROM Combo Drive
Dell Studio 17 Stuck Disc in drive
if you look close infront of the cd-dvd playerdoor there is a little hole if you stick a paper clip in there it will eject it.
Jul 10, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
CD/DVD drive stuck CLOSED and NO pin hole
Use my computer and select the drive (eg drive E:). From pull down menu "File" select "eject". While the disk door attempts to open (hear slight movement of tray) massage the door with your fingers. This is done by smoothing out the across front door panel with your finger tips and pushing in and releasing pressure from door. Door should slide open partially and close again. Repeat. The eject button nearside the disc tray doesn't seem to work as well as selecting "File" and "Eject" from the menu. Something to do with the door cycle is less with the direct eject button.
Jan 28, 2009 | Zenith Data Systems Zenith (OP-260-74501)...
Cd stuck inside laptop
turn off the laptop and turn it on again as soon as you see the windows startup push eject button see if it open if not then the CD rom is jammed inside
Sep 16, 2008 | Computers & Internet
CW088D CD-RW drive
All you can do is the usuall checks:- try, go to my computer>properties>hardware tab>device manager and go down the list to cd/dvd drives, click on the '+' and right click on your listed drive and select uninstall. restart the pc and then the drive will be re installed with drivers automatically. if it still won't eject then there is a drive fault.
Apr 23, 2007 | CyberDrive CW088D CD-RW Burner
LG GCE 8523BB (GCE-8523BB-10PK) CD-RW Burner Logo
141 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
