Question about Microsoft Xbox 360 Console
No audio...and its not the tv
The audio/video cord is plugged directly into the tv, and i get sound on all other channels except the av one.
  • 68 Answers
Follow the steps below, Hope this helps
1. Try another Av cable ( Audio video Cable )
2. If the steps dont work, call xbox customer support to have your xbox serviced. Good Luck! hope your console still has warranty
Posted on Apr 03, 2009
    Novelist:
  • 174 Answers
This sounds like a fault with the ana chip, this can be fixed by stripping your console down and using a heatgun or reflow oven to reseat all of the solder on the 360. when the 360 warms up the mainboard bends and causes the solder to crack. this in turn causes problems similar to what your experiencing. dont pay for expensive guides, if you want to do this yourself just email me and ill try to help all i can.
www.fixmyconsole.co.uk
Posted on Mar 09, 2009
Video in not working
When you plug the AV cables into the receiver make sure that the channel that it is plugged into is selected on the front of the receiver. Also note that the receiver should have a monitor output that should be plugged into the TV and the TV input must be selected on the TV.
Jan 31, 2014 | Sony STR-DH540 5.2-Channel Home Theater...
Hooking sayyo tv to directv
Not sure if I understand what is happening here but if set on channel 4 the connection for the direct TV would have to be to the coax fitting on the rear of the set.
For the audio/video inputs on the rear or side it would have to be the same ones coming out of the direct TV box to one of the same but inputs on the rear--Audio/video are one connection and coax for channel four is a different one.
Dec 22, 2012 | Televison & Video
How to I change the video input? i.e. I got a digital TV box and need to put it to video input 1. How?
  • On the back of your TV are all your inputs/outputs.
  • On the far left is your Video 1 Input.
  • The top input is your Video (Yellow AV cord)
  • The middle input is your Left Audio (White AV Cord)
  • The bottom input port is for your right Audio (Red AV Cable)
  • After you have all the AV cord up as I have explained then push the "TV/Video" button on the remote until "Video 1" appears on the screen.
  • In the event you should want to use Video 2 sometime then hook the cords up the same way except in the Audio 2 port in the back of the TV.
  • Each time you press the "TV/Audio" button you will cycle through the Inputs until you come back around to TV.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Jul 13, 2011 | Panasonic CT-32SL13 32" TV
I need instructions for hooking my VCR to my TV set,
using a scart cable, connect the tv socket on the vcr to the scart - in socket on the tv.
good luck.
May 10, 2011 | Philips Televison & Video
I cant hook it up to the tv
Run a three color AV cord (red, white, yellow) from the output of your surround sound receiver to the "DVD" input on your TV. The yellow is for video and the red and white are for audio so make sure you plug the tips into the same color ports. Now look at where you put the 3 color cord (AV cord) into the TV, which "input" did you use? Video 1 or Video 2 more than likely. Now turn your TV on and in the menu settings select the same video input you hooked the AV cords into on the back of your TV. This will get your theater set up. The remote is slow to process after you push buttons so give the remote a few seconds to respond.
Mar 22, 2011 | Protron PDS-2315 Theater System
Need directions on how to hook system up to tv
Check the back of the system, you will find Video out, then Audio out (left and right). Connect the yellow cord to video out, and the white & red to Audio out appropriately.
Then connect the other end of the yellow cord to "Video in" at the back of the TV, then the red and white to audio in at the back of the TV.
After connecting as directed above, turn on the TV, then turn on the system. On the TV remote control, press "AV" or "Source" depending on what is written on the remote and there should be a display. If there is no display, press the "AV" or "Source" on the remote once or twice more and there should be a display of the receiver's welcome screen on the TV. You might also need to press "Source" on the system's remote if there no display.
Let me know if you don't av display even after following the above steps. The above is the correct way of connecting so it should work.
Note; The White and Red cords stands for Audio left and right, while the yellow cord stands for Video. The yellow is suppose to allow your system display on the TV screen, while the Red and White is to bring out sound.
I hope the above helps.
Good luck.
Feb 01, 2011 | Audio Players & Recorders
How do i get to the channel to watch a dvd
You will need to connect the video and audio from your DVD to the Input of the TV. So use a RCA cord to connect from the video output /audio output of the DVD player to the AV/Input/video input/audio input of the TV. Now use your remote to select the AV channel and your video and sound will come. Do this carefully . Hope you try. Good day
Aug 13, 2010 | Zenith B27A11Z 27" TV
Only VCR2 sound working, no video
if you want you can bypass the video instead of plugging it on your system feed it directly to your tv., you only need the white and red cables for your audio to work, red for right channel and white for left channel the yellow one is for video, you can directly plug it on your tv
May 05, 2010 | RCA RT2250 System
Can't play back my JVC Video Camera on TV screen
it is possible that the movie format on your camcorder is not one that is recognised by your TV
Apr 20, 2017 | RCA CC6363 Camcorder
Can hook up my wii to this tv
The AV Multi Out plug that is included with the Wii will allow you to connect the console to most televisions or video cassette recorders (VCR). First, look at the back of your television AND your VCR and see if you have colored holes label "Input". Though most TVs have them, almost all VCRs do as well.
  • Audio/Video (AV) inputs are located on the front or back of the TV or VCR.
  • They are smooth silver posts with the inside showing a color, usually red, white and yellow.
  • Look for inputs marked Audio and Video IN.
  • The image on the left features stereo audio inputs. Some televisions have only one audio input. Click here for help setting up a mono audio connection.
  • Do NOT connect your system to anything marked OUT.
Where do you have these inputs?
Additional Options:
Connecting to a Television
  1. Insert the AV Multi Out plug on the Wii AV Cable into the AV Multi Out connector on the back of the console. setuptvav.gif
  2. Insert the RCA plugs on the Wii AV Cable into the input connectors on the TV. Plug the colored connectors into the following inputs:
    Yellow = Video Input
    White = Audio Input Left (or Mono)
    Red = Audio Input Right
    Interested in playing your games in Dolby Pro Logic II (simulated surround sound)? Click here setup information.
  3. Once the cables are inserted and the Wii is powered on, you must find the Input Select for your TV to view the game (it is likely not going to be seen on Channel 3 or 4). Typically this is found by pressing the TV/Video button on the Television's front panel or remote control. If you have more than one input channel, keep pressing TV/Video until you see the display from the Wii.
    If you do not have a TV/Video button, then the input could be labeled something different. Some other common input selects to look for on the TV or remote are: Input, Input Select, EXT, AUX, or a channel such as 00 or 99.
    Still can't find it? We have compiled a list of known input selects for many popular brands. Click here to see our list.
    Go to Next Step (Set Up of the Wii Remote) >
Connecting to a VCR, DVD-R, Cable Box, etc.
    In order to connect a video game system through a device such as a VCR, DVR, cable or satelite box, it must have Video and Audio "inputs." While most VCRs and VCR/DVD combos have these inputs, other devices typically have "Outputs" which will not work for playing your Wii console. Please verify the device you are attempting to use has these holes.
    While many cable/satelite boxes and DVRs may have "inputs," accessing them can be difficult. Please consult the instruction manual for the device you are connecting to, for more information.
  1. Insert the AV Multi Out plug on the Wii AV Cable into the AV Multi Out connector on the back of the console. setupvcrav.gif
  2. Insert the RCA plugs on the Wii AV Cable into the input connectors on the VCR. Make sure you are plugging the connectors into the holes labeled"Input" or "In". Holes labeled"Output" or "Out" will not work. Plug the colored connectors into the following inputs:
  3. Once the cables are inserted and the Wii is powered on, put your TV on the channel you use to watch movies (usually channel 3 or 4). Put in a video tape and play the movie. When you see the movie playing, press stop (do not power off the VCR!) and proceed to the next step.
  4. You will now need to find the Input Select for your VCR. This is usually a button on the original remote control that is labeled Input Select, AUX, Input, EXT, Line In, or a high or low channel. For more information on locating your input select, click here.
Nov 26, 2008 | Video Game Consoles & Games
Microsoft Xbox 360 Console Logo
41 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Mike Neath
Mike Neath
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
