Question about Krups Small Appliances Espresso Machine
Krups ProAroma 305 - need instructions.
I have just purchased one of these off eBay for work but I need some instructions as it is a little more complicated than just the 'on' button. Krups UK website doesn't seem to have this model in their service section ( too old maybe?) so I wonder if anyone can point me in the right direction please?
Many thanks!!
  • 4 Answers
SOURCE: My Krups won't brew
The culprit is probably the thermal fuse. It's under the bottom cover, and you have to have Torx security bits (the ones with the holes in the middle) to remove the three screws holding it in place. Sadly, the thermal fuse is not resettable. Once it's tripped, it's dead. If you have this problem, forget about getting Krups or their lame service agent, smallappliance.com, to repair it. Both contacts I had with Krups were unsatisfactory. The factory/customer service folks say that there are no parts available and to buy a new coffee pot. Great solution. You can damn well believe it won't be a Krups. Or is it ****? An otherwise perfectly functioning unit gets sent to the landfill because the folks at Krups can't be troubled to find the part number. Idiots. For your info, there are thermal interrupters made by several manufacturers. The trip temperature on the breaker is 318 degrees, C. Something in the neighborhood of 200 degrees C would probably work, but would have to be soldered in. If you are comfortable with doing that, it's a solution.
Posted on Apr 17, 2008
SOURCE: How do i clean my krups proaroma coffee maker
I put a mixture of water and vinegar thru the coffee maker and let it sit for about one hour. Then i rinse clear water thru and its find.
Thanks.
Posted on Jun 06, 2009
  • 279 Answers
SOURCE: Krups XP5020 manual
Try Krupsusa.com and click on "instructions" they have it there.
Posted on Sep 18, 2009
sandrineFY
  • 268 Answers
SOURCE: Dear Sir!
Check on the Krups site:
http://www.krups.com/Consumer+Services/Product+Support/Manuals/Use+Intructions.htm
Posted on May 28, 2010
SOURCE: the coffeemaker tube leaks on my Krups ProAroma 452
I have the same problem. The rubber elbow seems to have shrunk with aging. Krups customer service pointed my to SmallAppliance.com for a replacement part. It appears that "Krups 0067516 Coffeemaker Tube" is the proper replacement. It is a special order part that may take 6 weeks to ship. The elbow pulled off a connection inside the coffee maker and I hope that the replacement will just slip back on. While I haven't completed the repair, I think I'm on the right path.
Posted on Jul 07, 2010
I need to replace my Krups 453 Thermo fuse (ms-0061607). Where can I find one or is there a replacement?
Many times the Thermal (not Thermo) fuse is soldered in line with silver solder and unless you have the ability to cut the old one out and replace it, the cost would be greater than a replacement coffee maker.
Jan 05, 2015 | Krups ProAroma 453-71 Coffee Maker
Our Krups heats the water but does not brew
may be its not heating properly try some descaleing
Jul 13, 2014 | Krups ProAroma 453-71 Coffee Maker
The Krups coffee maker brewed as usual, it was a little hot so I did a few other things went back to the coffee maker it had shut off by it's self and now wont come back on???
unplug the coffee maker. Let the unit cool down for say a half hour. Try another pot of coffee and see if it comes on after plugging it back in of course
Oct 31, 2010 | Krups ProAroma 453-71 Coffee Maker
The coffeemaker tube leaks on my Krups ProAroma 452. How do I replace the tube?
Jun 17, 2010 | Krups ProAroma 453-42 Coffee Maker
Looking for water pipe from pump to shower...otherwise 452 has been running fine for years!
It's probably not cost effective to pay someone to repair it.
If you can find the part and do it yourself, go for it. Otherwise, buy another one.
Most small appliances today are not worth paying for repairs.
Oct 09, 2009 | Krups ProAroma 452 Coffee Maker
I lost my user manual for a Krups ProAroma453-71 coffee maker. Where can I find one?
Contact Krups, and they should be able to send you out a new one. Their phone number (according to their website, www.krupsusa.com ) is 1-800-526-5377
Good luck! :)
Aug 26, 2009 | Krups ProAroma 453-71 Coffee Maker
Thanks.
Jun 05, 2009 | Krups ProAroma 453-71 Coffee Maker
Flashing red light
Just found the answer!
The type 453 coffee maker offers a carafe ‘pre-warm’ function.
This feature will heat the carafe for 5-10 minutes before the brewing process begins and is indicated by a flashing red light.
To toggle this feature, push the top-right button in the control panel until the display reads "off".
Aug 08, 2008 | Krups ProAroma 453-71 Coffee Maker
The display reads CALC.
I have a Krups model FME4 and it means that you should descale the machine. Here's a link to the use and care instructions for my model, I assume it would be the same for yours.
http://www.krupsusa.com/Consumer+Services/Product+Support/Results/Use+and+Care/ResultUseAndCare.htm?SelectedService=Use%20and%20Care&SelectedGuIDService={EC10140D-AA43-4DCA-8D3A-A5A4823D9E52}&SelectedProdRef=FME4
My problem is that CALC continues to display even after I've descaled several times. Good luck with yours.
Oct 30, 2007 | Krups ProAroma 453-42 Coffee Maker
Krups ProAroma Type 314
Thermal fuse gets stuck, gently take it apart and reverse the thermal button over, clean the rust under the button
Oct 07, 2007 | Krups ProAroma 453-71 Coffee Maker
Krups Small Appliances Espresso Machine Logo
189 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
Billy Mac
cyfred
Level 1 Expert
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
