Question about Office Depot Ativa D5772 Phone
HOW DO I PUT THE BASE id INTO BASE #2? wHERE DO i
HOW DO I PUT THE BASE id INTO BASE #2? wHERE DO i GET THE NUMBER OFF THE MAIN PHONE?
Below the LED display of the BASE phone, press MENU. Scroll down to DISPLAY BASE-ID and press OK. Enter that 15 digit number into the handset.
Posted on Sep 15, 2009
I have just inherated the at&t e5634b phone system. I have replaced the batteries in the hand sets. As per the manual I have de-registered each hand set. The problem is that when I register the...
This problem can be caused by the following, A bad battery, (which you say you are all new). A full base memory and a Faulty main base unit
This main base unit can only expand to four handsets and no more. If the base unit has been reset then the assigned numbers for each handset would begin with " handset 1" if they show any other number when reset then it would not have been reset..To re-set main base you will have to
De-Register All Handsets
Unplug the power supply from the base unit then Remove all handsets from the charge cradles and base then Press and hold the PAGE button on the base.
Plug in the power supply again while pressing the PAGE button, Continue pressing PAGE until the IN USE and CHARGING indicators are lit. (this could take up to 10 seconds)
Release the PAGE button All Handsets will display "enter base id".
If this does not solve your problem then you will have to replace the main base
Apr 20, 2017 | AT&T E5634B Phone System w/ Caller ID
Phone are 5.8 ghz vtech
may be the frequency problem for noise problem.
pleaSE CHECK IT OUT.
ADJUST THEM AT SOME PROPER LEVEL..
AND THEN TRY.
Oct 18, 2008 | Vtech 5.8 Ghz Handset Cordless Phone...
Can put in base id
Did you try this (from the i5801 manual) -
To register a handset to the base, follow these steps:
Step 1: If ENTER BASE ID is displayed on the handset, proceed to the next step; if not, press MENU on the handset, then press ▼ until REGISTER is highlighted; now press OK.
Step 2: Locate the 15-digit Base ID number by pressing, at the base: MENU, then press until DISPLAY BASE-ID is highlighted, then press OK.
Step 3: Carefully enter this number using the handset dialpad. If you make a mistake, press to backspace. When finished, press OK.
In a few moments, the handset will be assigned a number (1-6). This will be the lowest available number in the sequence not previously assigned to another system handset.
Step 4: Repeat the procedure for any other unregistered system handsets.
Reply back if you have success. The Base ID is not from the bottom of the base unit, but is something you get by following Step 2 above.
Feb 04, 2009 | Vtech i5807 (735078006394) Cordless...
I just got this phone VTech 5881. I plugged it in and have tried to register the handset. I can't. It has someone else's name in it. what should I do?
First, deregister all handsets:
Step 1: At the base, press MENU, scroll to BASE SETTINGS, then press OK.
Step 2: Using the base dialpad, enter * * 3 3 5 7 8 2
Step 3: Re-register each system handset:
At the base, press MENU, scroll to DISPLAY BASE-ID, then press OK. The 15-digit base ID number will be displayed.
Step 4: Using the handset dialpad, enter the base ID number. Repeat the registration procedure for each system handset. Each handset is assigned a number in the order of registration
Dec 13, 2008 | Lands Phones
No dial tone on handset
It may not be registed with the main unit. You may need to register the handset. With my uniden all i have to do is put it in the main base until it says what handset it is (it should be a number).
If you have any questions please dont hesitate to ask
Sep 25, 2008 | Uniden 2.4 GHz Cordless Phone System
ATT E580-2
On the base station display, select "Menu", and then select "Display Base-ID".
May 14, 2008 | AT&T E580-2 Cordless Expansion Handset
GE MODEL 28112 DECT 6.0 CORDLESS PHONE
I contacted GE today and they told me how to get the caller ID to work on the additional handsets. You must follow these steps in the exact order given.
#1 - unplug the base phone
#2 - unplug the telephone line from the base phone
#3 - remove the battery packs from the phones
#4 - wait 10 minutes.
reverse the order when assembling. Put battery packs in phones, put the telephone line back in the base phone and lastly plug all phones back in. It takes about another 10 minutes after that before all phones start recognizing caller ID but it now works fine.
Mar 26, 2008 | GE 28112 Trio Cordless Phone
VT ip8100 - enter base id problem
ya u need to contact v-tech vendor not vonage and gave them the serial no of ur handsets and get teh base id and try that will work
Aug 05, 2007 | Vtech INTERNET PHONE SYSTEM
Doesn't anyone have an answer or some help? Please!!!!
Uniden TRU8885-2 Cordless Phone > User Guide E X P A N D I N G Y O U R P H O N E w w w . u n i d e n . c o m Register the Handset to the Base If you purchase an extra handset, you need to register the handset to the base before use. Only one handset can be registered at a time. The handset ID for the supplied handset(s) was assigned at the factory, which has #1 or #2 in the display (#2 for models that have two handsets in packaging). When you register additional handset to the base, the handset ID will be assigned. 1) Before registering the extra handset, the battery pack must be charged for 15-20 hours. 2) Place the extra handset in the main base unit to begin registration. 3) While the handset is registering, Handset Registering will appear in the LCD. When Registration Complete is displayed, the handset has been registered to the base. If Registration Failed appears, please try these steps again. Extra Handset Extra Handset Charger Charger Main Base Extra Handset + Main Base Charge the handset for 15-20 hours. Place the extra handset in the main base to register. 1 2 3 4 ?An extra handset can be registered when the main base is in standby mode. ?Standby Mode - The handset is not in use and talk/flash has not been pressed.
Jun 26, 2006 | Uniden TRU8885-2 Cordless Phone
Office Depot Ativa D5772 Phone Logo
252 people viewed this question
Top Office Depot Lands Phones Experts
ashburton
Zelio Picanso
Tom Chichester
Are you an Office Depot Lands Phone Expert? Answer questions, earn points and help others
