check both sides on radio for wiring ways,,, mostly red & yellow to positive,,,,,,black negative,(,both green to speaker,,,both yellow to speaker,,,both orange to speaker)speaker wire colors may be diffferent
corrosion on you battery terminal will create high resistance.inspect the battery connectors and wire. if you find white/blue crystals on you terminal disconnect and clean. the battery cable must be gold/light brown.If the wire are black/blue that mean is burn from bad(lose) connection to the terminal and need replacement.Inspect all ground connection betvin battery and body for corrosion or lose
1992 Saturn SL2 Car Stereo Radio Wiring Diagram
Car Radio Constant 12V+ Wire: Orange Car Radio Ignition Switched 12V+ Wire: Yellow Car Radio Ground Wire: Black Car Stereo Illumination Wire: Gray Car Stereo Dimmer Wire: Brown Car Stereo Antenna Trigger Wire: N/A Car Stereo Amplifier Trigger Wire: N/A Front Speakers Size: 6 1/2′ Front Speakers Location: Doors Left Front Speaker Wire (+): Tan Left Front Speaker Wire (-): Gray Right Front Speaker Wire (+): Light Green Right Front Speaker Wire (-): Dark Green Rear Speakers Size: 6 1/2′ Rear Speakers Location: Rear Deck Left Rear Speaker Wire (+): Brown Left Rear Speaker Wire (-): Yellow Right Rear Speaker Wire (+): Dark Blue Right Rear Speaker Wire (-): Light Blue
