Question about Alto 302000414 Attix 8 AS/E Canister Wet/Dry Vacuum
How do i change an Alto halogen light bulb - Alto 302000414 Attix 8 AS/E Canister Wet/Dry Vacuum
I am sure you worked it out by now, but for anyone else who is looking; the fitting should have come with a suction cap to attach to the front of the bulb like a plunger to pull the bulb out... terrible design!
Jake
Posted on Jan 23, 2010
Hi I have a nilfisk alto that has not been working properly. It has not been spraying the water
Alto nilfisk vaccuum is not spraying water , a highpressure washer do you mean not a vaccuum .
But If it's an alto nilfisk blue pressure washer on the vaccuums topic it must be the bypass / autostop on the pumphouse its internally a point where a microswitch is placed and depends on the type of washer by a problem with the parbak ( a parbak is a oring/ with auxiliary kevlar ring(s)) that can hang on lime, but on an other model there are 2 springs on the bypass and one of them the great spring is broken or only hanging on lime but thats rare if it is.
I don't know if there are vaccuums with water spraying only for remove dust.
Feb 15, 2017 | Nilfisk Vacuums
Tip
How to change light bulb
make sure the light switch is powered off then (after letting it cool if hot) turn the bulb slowly untill in your hand
then take new light bulb and turn it clock wise till snug and now go flip switcha and wa la you should have light
on Feb 24, 2010 | Vacuums
Need to change the light bulb on riccar 8850 vacuum
Remove the bottom plate to be able to pull the light bulb out and replace it.
Feb 12, 2013 | Riccar 8850 Vacuum
I need a small plastic part which controls air pressure in the Nilfisk Alto attix Vacuum cleaner
Fixya does not sell replacement air pressure controllers and cannot recommend sources.
Jul 24, 2017 | Nilfisk Vacuums
I was wondering if there is a way to change the light bulb for the display numbers etc..?
hi,
yes there is. the bulb used in most display are LED's.
you can purchase the same size LED's as your unit.
you can also even change its light color. Now leds comes in many color from white, blue, lavander, red, green etc... Also it comes into many sizes.
You need some soldering experience to change the LEDs.
Hope I answered your question and don't forget to rate me.
Thank you for using FixYa!
Regards,
john
Jan 25, 2011 | Vacuums
Do alto clarke have a supplier in Australia for vacuum cleaner parts? D T V 7 Thankyou
HI there Vacuum Guru here from VacuumSpot.com.au. Most alto clarke share the same parts as a Nilfisk Alto. We are an agent for these machines. If you use the email link on our site and let us know which model you have we should be able to get you any parts you need.
Oct 14, 2010 | Alto 302000405 Attix 8 Canister Wet/Dry...
Change light bulb
ok just like you would change the belt take screws out of top the cover should come off inside there is a plastic cover take it off theres the bulb
Jun 29, 2008 | Kenmore 25512/ 25513 Progressive Canister...
I bought a ceiling fan from lowe's, got it home got ceiling fan up in the bathroom, when we put in the light one of the halogen bulbs does not work , also two of the cobalt blue glass covers are cracked...
If this is a new product and it is defective, take it back to Lowe's and insist on a replacement, talk to the manager if you have to. This site will only advise you on how to fix it.
Mar 05, 2008 | Vacuums
Alto 302000414 Attix 8 AS/E Canister Wet/Dry Vacuum Logo
187 people viewed this question
Top Alto Vacuums Experts
Are you an Alto Vacuum Expert? Answer questions, earn points and help others
