My washing machine won't drain the water and therefor also unable to open the door, with all the wet clothing inside. HELP needed desperately! :-(
Drain motor is usually located on the bottom of the machine. Hopefully you have an access panel separate from the main door panel. Should be a hose coming in and a hose going out. Put the machine in spin cycle and see if you can feel the pump spinning. If the pump is very hot, chances are something is blocking it. They will usually have an access port that can be opened up just for this reason, be ready to catch the water when you open it up, and please turn the machine off first. If you get no sign of life from your pump it may have died. Also check for any blockages in the drain lines. All of this should be easily accomplished with a couple screwdrivers and towels
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
Hello &
Welcome to FixYa
OE is a drain error and is displayed when the
washer is unable to drain water. Please check the drain hose and drain pump
filter for any clogs to clean the error. Please get back to me if you have any
other questions.
Kevin
