Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
Blowing fuse I have a Craftsman LTX1000, 42in. glade, Kohler 18 OHV, when I start it , it runs fine. I then put it in gear and get ten feet and fuse blows. Sometimes it blows right after I start it and set in neutral. Can someone help? PLEASE?
    Genius:
  • 1,055 Answers
Youve got a short in the wireing ,prob right at the clutch peddle switch
Posted on Mar 18, 2009
Craftsman lawn tractor with 18 b&s ohv motor blows dipstick out while cranking. Valve lash is good.
check to see if the flywheel key has been sheared off. if so replace it
Sep 13, 2016 | Craftsman Garden
Kohler command 18 not getting gas to carb and fuel pump is working fine
Tankairiation, tankfilter ,tapfilter pourous hose floatchamber ,nozzle , gaskets
Mar 19, 2016 | Kohler 18 Hp OHV V-Twin Command Engine
18 hp kohler engine starts but doesn't keep running!!!!
You put in a question about your ride on. What is it you need?
Aug 15, 2014 | Kohler 18 Hp OHV V-Twin Command Engine
LTX 1000 craftmans rider 18 hp ohv kohler rpm fluctuates, then dies. I let it sit for ten minutes and then start it and mow for a few minutes and then it does the same thing. is there a safety cut out
There could be some type of contaminate in your fuel/lines. Check for that!
Then check your fuel filter. and hoses.
Your carb needs to be rebuilt!
May 26, 2012 | Craftsman Garden
What all engines can i put on my craftsman dlt 2000
most engines that size bolt down the same and use the same size crank the hard part would be your skill level to charge the wiring as that part is different
Apr 13, 2012 | Craftsman Garden
I have a craftsman gt 6000 with kohler 18 hp magnum today it started fine and ran goodd for over an hour i put gas in it and ti would not stay runing it stated surging and popping and cuts off
Your carb is full of trash. you also probaly need to clean out the bottom of your fuel tank, blow out your lines and replace the fuel filter. I have 2 mowers with kohler engines and clean out the fuel tanks fuel lines and carbs 1 time a year. There is also a fuel shut solenoid on the carb this is normally problem if the engine does not run. but I am certain your problem is a simple fix, all you have to do is clean everything out in the fuel system.
Sep 13, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Engine ran and now lost spark!
Look for a fuse and see if it has blown. It will look like a fuse you use in your vehicle. If blown put in a new one. If it blows again look for a bare wire that could be shorting out.
Sep 02, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Fuse blew, replaced with new, and now electric clutch will not work
sounds like you probably need a new clutch. they short out internally and blows the fuse
May 03, 2009 | Garden
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
505 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
