Question about Nintendo DS Console
The Nintendo was dropped, now it will not turn on. I get the green light for about a second the screen flashes then nothing. Does this mean it bit the dust?? Thanks,
  • mrandmrsgoat Mar 08, 2009
    ds fell wont turn on, when u plug it in, orange lite comes on but no screen
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 117 Answers
This problem sounds similar to other battery related problems. Now I'm not certain, but it sounds like you should try just opening the battery slot in the back of the ds and make sure it is in well. If this problem is battery related this (or a new battery) should work. But if it's due to the fact that you dropped it on the ground, I don't know
Posted on Mar 08, 2009
My ds lite just switched off and it was charged
Hi, so if you try switching on the ds lite, nothing at all happens ??
Does the green light flash even if it is for like a split second.If it does then it is more likely top be a blown fuse. If 1 of your screens flicker also, this could be your problem as the ds will not start up with a broken screen. Please advise
Jul 31, 2012 | Nintendo DS Lite Console
My Wii has a red light when plugged in, and a green one while turned, on, the problem is, nothing is displayed on the tv or heard, also, the disk drive whirrs for a few second after turning on. The tv...
If the light is red, it means WiiConnect24 is turned off. Green means the system is turned on and it's normal for the Wii to whirr a bit when it's initially turned on.
Completely power down your system by pressing the power button for 10 seconds. If that doesn't work, unplug the AC Adapter from the Wii for a moment, then plug it back in.
That said, Nintendo recommends calling them if this doesn't fix your problem. Hope this helps.
Jan 06, 2011 | Nintendo Wii Console
I turn My nintendo DS lite on and after maybe 2 seconds the green light flashed and shuts off. Help!?
Do either of the screens flash just before the green led goes of?
If it does then the screen that doesn't flash is faulty... If you have a warranty then i'd suggest sending it in for repair if not and you fancy a go at a bit of DIY let me know and I will take you through the process of dismantling the DS lite, reconnecting the screen to see if its just come loose and if you need to I can tell you how to go about fitting a new screen.
Hope this helps,
Regards,
SOD69
Feb 02, 2010 | Nintendo DS Lite
Wii drum set doesn't work
if the blue light's are flashing on first,second,third,or fourth light then it means your batteries are low or your drum set is for another game
Jan 28, 2010 | Nintendo Rock Band for Wii
My son dropped his ds lite. When plugged in the light turns green. When you try to turn it on the top screen flashes then goes off
The DS lite is easily broken when it is dropped keep trying it or ask for a repair where u bought the ds
Jul 01, 2009 | Nintendo DS Lite Console
My sons nintendo ds wont turn on, when we charge it, turn power on , the green light comes on and bottom screen blinks for a split second then goes dead.. Is this fixable , if so what do i try??? thanks
yes it is fixable sounds like your fault is with the top screen are the hinges ok has it been dropped.
most green light and screen flashes point to a defective screen or connection on the mother board or sometimes fuses. id start with checking the motherboard connection if its ok check the fuses if all is ok buy a new top screen and replace it.
Jun 30, 2009 | Nintendo DS Lite Console
DS lite green light comes on, top screen flash,then switches off
Check L2 near the power switch on your DS mobo. That part usually get loosen or taken out when you drop your DS. And usually you can recover it when dismantling your DS.
Jun 16, 2009 | Nintendo DS Lite Console
Flashing bottom screen (Nintendo DS Lite)
You need to check the top screen ribbon is fully inserted into to place on the board. A green light and flash of the screen within a second means ribbon not connecting right
Jun 05, 2009 | Nintendo DS Lite
DS lite, power is on but nothing happens
Ditto... except my daughter is 10. Both screens remain black, are fully charged and green light stays on for more than 4 minutes.
Sep 14, 2008 | Nintendo DS Lite Console
Nintendo DS Console Logo
47 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Julian Wainwright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
