Question about Century Encore 5-point Harness
Harness straps off cosco car seat to wash cover, help reattaching
I took the hardware off the harness straps so i could get the car seat cover off and wash it...now i forget how they go together again, help!
I need help putting the straps back on a Cosco 5-point car seat. Took it apart to wash and can't get it back together
Posted on Sep 09, 2009
Need instuction on how to reassemble safety straps on cosco car seat. I took apart to wash seat cover and don't remember how to reassemble
1. Find the same seat at your local store and take photos with your phone.
The position of the harness (slots in the plastic shell) is dependent on the height of your child.
2. Contact the manufacturer for detailed instructions
3. Find a certified Child Passenger Safety Technician or Instructor at safercar.gov.
Jun 21, 2015 | Cosco Scenera Convertible Baby Toddler Car...
Rethread car seat straps
Here is cosco website , input your model number in the box and you will be able to download step by step illustrated instructions for your model.
Jul 11, 2008 | Cosco First Ride Deluxe
I took the cover off for washing. Need instructions to put back on
You should be able to download the instruction for this model from this site
Instruction Manuals
You will have to remove the buckle loop holding the harness at the back of the seat and release the straps. Once you insert these through the seat cover and back into the slot on the seat back you can lock the harness by re-inserting he buckle loops.
Aug 25, 2014 | Cosco Baby Gear
I purchased cosco car seat model #22491-AOL and there are no straps/ harness. Am I just suppose to use my car seat belts to restrain the car seat. It does have plastic under head piece to put I guess car...
Yes, this car seat is a booster seat rather then a harnessed car seat.
The requirements are 30-100lbs and 34" to 57".
It's generally recommended that boosters are not used until 5-6 years old when the child is able to sit in proper position in the car on both long and short trips after they have outgrown their harnessed seat.
Mar 01, 2011 | Cosco Juvenile Pronto 22491 Booster Car...
Looking for instructions for assembling a costco car seats straps
Go to this website and type in your car seat info. If they do not have the manual, I would call the manufaturer's number located on your car seat.
http://www.coscojuvenile.com/Instructions
GOOD LUCK!
PS I just took my car seat apart to wash the cloth material and found the easiest way to reassemble it was to remove the base during install of the straps and then replace the base.
Jul 03, 2010 | Cosco High Back Booster 22-200 /22-207
I need instuction on how to reassemble safety straps on cosco car seat. I took apart to wash seat cover and don't remember how to reassemble
Here are the links to download Cosco carseat instructions:
Canada:
http://www.coscojuvenile.com/can/eng/instructions
USA:
http://www.coscojuvenile.com/usa/eng/Instructions
Mar 19, 2010 | Cosco Eddie Bauer 22770
Need help with putting straps back on
I know this is months later, but here you are in case you (or anyone else) needs the info again. First, though, I feel that it wouldn't be responsible to neglect to tell you that if you got the seat in 2000, it is expired and no longer safe to use. Car seats generally expire after 6 years because the plastic degrades over time - in a 10 year old seat, it can look fine but actually be brittle enough that the entire harness can rip out of the seat if it's an accident. For the manual, visit Cosco's website and fill in the product number and date of manufacture. It will bring up a PDF file of the manual that you can download. To rethread the straps, first replace the **** strap. Slide the metal plate down through the slot in the seat, with the buckle facing out. Slide the metal clip under the tab and push it down to lock it in place. Facing the seat, start by threading the end of the harness strap down through the slot of the left side of the bottom (where the child's right hip would be). Under the pad/cover, thread it across the bottom of the seat and up through the matching slot on the right side. Pull it until you have equal lengths on both sides. Thread the buckles onto the the strap (one one each end) and buckle them. Thread the chest buckle onto both ends, making sure that the harness doesn't twist. Buckle it, too. Push the ends through the harness slots. Pull the harness through to the back, making sure that it goes OVER the metal bar, but UNDER the plastic adjuster handle. There is a loop sewn into each end of the harness. The adjuster strap has a splitter plate, kind of shaped like a Y. Slide each loop over the ends of the plate and all of the way into the slot, so that the curved ends of the splitter plate are exposed and the strap is secure in it's slot. Adjust the harness height by squeezing the metal bar on the back of the seat (the one behind the harness) forward and moving it and the plastic adjuster bar up or down to the correct position (at or below the shoulders for rear-facing, at or above the shoulders for forward facing). Do note that the very top slot is NOT for use with the harness - it's only to adjust the headrest when the seat is being used as a seat belt positioning booster and is not reinforced to support the harness in an accident! Adjust the tightness of the straps with the button/extra length on the front of the seat. Properly tightened straps should lay in a straight line without sagging and you should not be able to pinch up any slack (lengthwise going down the harness, not across the width of it) at the shoulders or hips. Adjust the chest buckle to lie in line with your child's armpits, never his neck or belly.
Oct 15, 2008 | Cosco Alpha Omega Elite 5-Point 22-155
Cosco Car Seat Model Number 22123 Instruction Manual
need instructions ASAP on how to put back together the straps, I took off the cover to wash it. It is NOT EASY to put back.
thanks,
yolanda
Sep 17, 2008 | Baby Gear
I have a 02-442-PRI 11-17-98 Cosco
If you washed the straps, they will need to be replaced. Lock the harness together, to prevent the straps from being twisted. Feed the top part of the harness through the slots that are AT or ABOVE your hangchilds shoulder if the seat is forward facing. IF the seat is for rearfacing, feed the top part of the harness straps through the shoulder slots at or BELOW the child's shoulder. Once each is through, reach down and attach them to the silver plate that hangs from the **** strap adjuster. Once you silde each of the harness straps, then slide the bottom of the through the hole in the cover, then into the base of the seat, folding the top like a triangle makes it easier to get through the tight holes. Repeat on the other side and you are ready to travel! Thanks!
Jun 16, 2008 | Cosco High Back Booster 22-200 /22-207
Cosco Alpha Omega
You can call the manufacturer, Dorel Juvenile Group, at (800) 219-0509, and they will advise you what to do. A carseat with twisted straps is not safe, especiallyif they involve the harness.
Make sure you also check www.carseat.org/recalls to see if your AOE is one of the ones recalled for harness issues; if so, the Dorel Juvenile Group will send you a free repair kit.
Apr 26, 2008 | Cosco Alpha Omega Elite 5-Point 22-155
Century Encore 5-point Harness Logo
3,794 people viewed this question
Top Century Baby Gear Experts
Dorel UK
Dorel UK
Are you a Century Baby Gear Expert? Answer questions, earn points and help others
