Creative Labs ZEN Neeon 2 MP3 Player Logo
A
Anonymous Posted on Apr 10, 2013
HOW DO i FIND NEW FIRMWARE FORA knc MD903 TABLET and how do I download it to the tablet if the tablet does not want to boot up.
How to update tablet firmware
If there is a new version available, follow these steps :
Tap "check update" in "Settings"
Then go to "about" and go to "system update" to check if the firmware is latest.
Steps to update :
1) Go to "Need Help?" page of ASUS official website http://www.asus.com/support to download ZIP file of firmware.
2) click the ZIP file after downloading is completed
3) Connect your tablet with PC via micro USB cable, and copy the ZIP file to the root dictionary of internal storage of tablet
4) Detach micro USB cable from the tablet to make the notification for firmware update popped up on status bar
5) Tap "System Update File Detected.." and follow steps to update firmware
Now your firmware is updated.
IVE TRIED ALL THE USUAL: HARD RESTORE, SOFT RESET, V+/PWR, V-/PWR. HELP PLEASE! NEXTBOOK 8P FREEZE DURING RESTORE
have you tried downloading the firmware and re flashing it ? "google "firmware for ( your model number ) download the firmware/install it on a sd card ( or some do it from your laptop depending on tablet ) but you will get instructions with the firmware on how to do it ..hope this helps
Where can i download the firmware for my tablet irulu 10.1 "
Only when a brand like irulu offers an update of the firmware, you can download firmware. But I think now you ask for firmware you even can't use new firmware. I think you have bricked your tablet. But to load firmware, your tablet needs to work correct. If during an update (or while rooting) something goes wrong, you can't put in new firmware, because the tablet does not know what to do with the USB connection or with the memory card holder. Only a workshop with the correct tools can put in some firmware.
As soon as irulu has an update of the firmware they will notify registered users they can download the firmware and they also provide a manual, how to do the update. There are always warnings, if something goes wrong during an update, you can end with a bricked tablet. But if it is a regular update, they also tell you who to contact if something goes wrong.
Try to fine a certified irulu repair centre and ask them for help. (and what it will cost)
How to reset touchmate tablet mid 780
If you don't have access to an external keyboard, download the correct firmware for your tablet here: http://www.touchmatepc.com/new/downloads.asp
You can flash your tablet with the correct firmware, and it will be the same as a factory reset. Just make sure you have a backup of your tablet's contents, and be very careful in choosing the correct firmware for your tablet.
How can I reflash the firmware for my Allwinner A13 tablet?
Try pressing and holding power and volume down until it boots up. you will need to go online from a PC to download the latest firmware ( look on Allwinner webpage) then download it to a formatted SDcard.
this works for Ainol tablets.
worth a try.
The screen on my Kocaso M9200 stays black even though I have it connected to a viable charger. I NEED this to boot!!
Kocaso M9200 User Manual FAQs states ...
"Why won't my device turn on?
Make sure your tablet has been charged for at least four hours prior to use. When plugging in the cable, make sure you are not accidentally plugging it into the headphone jack. Also, the power button is on the side (for tablets) and not the one on the front of the touchscreen. The button on the front is for navigation".
"Should I perform a Firmware Update?
Not necessarily. This is actually intended if obscure issues with the tablet occur. Unless you are having issues with the tablet which a
Factory Data Reset has not resolved, it is not advised that you perform this step. However, if you are sure you wish to attempt this procedure, please visit the following link for available firmware downloads and the instructions on how to perform the update:
http://mymidpad.com/firmware/"
Link for M9200 .. Support Firmware. Please read details and only attempt firmware upgrade as a last resort. Its always best to get it done at a Kocaso service center. Hope this helps.
4helpful
Haier hg 9041 boot up problem
Did you get it fixed or did you send the tablet back? I could not get mine fixed and I finally paid attention to another forum and I fixed it with that download. I was zipping the file then unzipping it then putting it on my sd card and it does not work that way. I saved the new firmware straight to sd card put in tablet and boom I was up and running in ten minutes. Just be patient with it cause it will act like its doing nothing but it is.
Supersonic 7" touch screen MID Tablet
You need to flash new firmware you can download LiveSuit and
then look for the correct firmware that is compatible with your tablet.
If you search for How to Flash Tablet there will be a video or instruction on how to do it.
How can I boot up my ainol novo 7 tablet?
Some illegal software,software viruses or some other reasons make android system malfunction, and it can't working. Brushing the firmware can be used, and different tablets have different methods. you can download the firmware in the internet and do it follow the instruction.
Word BOOT on screen of zehnder sat box then blank...help
Sounds like the firmware has gone from the sat box
take it to a satellite repairer or if you feel competent enough you can use a null modem cable to download the version from your box and then you can then download the firmware from the internet and then install firmware onto box! this happens alot with topfield sat boxes but some wont accept the firmware its a 50/50 chance but give it a shot you cant get any worse!
hope this helps,ben
Top Creative Labs Audio Players & Recorders Experts
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
