Question about Kenmore Refrigerators
Freezer in my kenmore refrigerator isn't cold
I recently moved my refrigerator to a new house. During the move the fridge fell on it's side. When we plugged it in at the new house the freezer won't get cold but the fridge side does. It's a kenmore side by side model #106.54536400. Please help!
  • moore_bryan Mar 08, 2009
    Could the freezer defrost heater been activated somehow? If so, how do I stop it?
    No, the icemaker doesn't feel warm. Do I need to tip the unit over to check the fan motor, or is there an access panel?
  • Kenmore Master
  • 3,361 Answers
Make sure the freezer fan motor is running. The wires may have come off when it fell.
Posted on Mar 08, 2009
  • steve
    steve Mar 08, 2009
    No it could not have.
    However, the icemaker mold heater could be stuck.
    Feel the bottom of the icemaker with your hand.
    If it is hot unplug the icemaker and buy a new one.
    Also check the compressor fan motor.
    Is it running?
  • steve
    steve Mar 08, 2009
    There is an access panel on the bottom rear of the fridge.If the fan is running, carefully feel the compressor to find out if it is hot.
Westinghouse fridge freezer Model no. WBM4000WA-R I have recently moved and upon plugging it in at the new place only the freezer is working. Do you have any idea of what I can check or do to fix the...
Hopefully you didn't have the unit on its side when you moved! That could present another problem.
The cold air for your refrigerator comes from the freezer compartment. When you say it is working, can we assume you mean it is getting cold or just making noises in the freezer compartment?
Check to see if the refrigerator temperature control is on and in about the middle of the scale on this model, e.g., 5.
Refrigerator Defrost Parts
May 06, 2014 | Refrigerators
Kenmore refrigerator side by side. EnergyStar sticker says model series 56541-56551. Freezer side cold; fridge side between 50 and 60 degrees. I unplugged for at least 2 days for ice to melt. Fan at...
If there is ice built up on back inside freezer wall, you have a defrost problem. Either defrost heater, defrost thermostat, or defrost control (timer or Board) is bad.
Sep 05, 2017 | Kenmore Refrigerators
Fridge warm, freezer has frost on back panel & is defrosting, fans work, just changed defrost thermostat, no air is moving from freezer side to fridge side, drain pan under fridge is dry
this fan needs to run when the compressor runs,check fan blade for being jammed by ice if you have this much ice on back wall as ice will stall motor,if no fan there will be no cool air to refrige compartment also the defrost drain tray will fill with water then freeze over which in turn floods the freezer floor and refrige compartments cause it cannot drain to the pan in the bottom
May 11, 2012 | Kenmore Side by Side Refrigerator
Side by side: Fridge side not cold; freezer side frosted up
can you hear the evaporator fan motor running in the freezer side? this is what moves the cold air to the fridge side to keep it cool. need make and model to further assist you please.
Oct 24, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore 106.52572202 not cold
You moved the refer from one house to another, did you clean the refer first? was there a dusty old piece of cardboard hanging off the back? that cardboard needs to be in place for proper air flow through the condenser coil.
Jul 17, 2009 | Kenmore 50522 / 50524 Side by Side...
Both firdge and freezer on level 5 and still not very cold
It may just need more freon. A service call won't cost the landlord too much, and then he will have a report from a qualified third party, if the fridge needs to be replaced.
Apr 22, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Kenmore Fridge not working
may i suggest you Purchase A premium repair Solution. @ $19.99 or £10.00 G.B.P
One of our technical assistants, will usually have the Answer to your Problem, within the hour.
Mike @ Compurepair.
Mar 02, 2008 | Kenmore 44109 / 44102 Side by Side...
Frigidaire Fridge PLHS69EESS2
Could be a jammed fan or something could have moved inside to block the opening. Some units have deflectors in the openings...did one of those cover the opening on the fridge side? Did you overpack your freezer and block the air flow from there to the fridge?
Dec 29, 2007 | Frigidaire FSC23F7DSB Stainless Steel Side...
Refrigerators Logo
135 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
