Question about Emerson Smartset Clock Radio
Daylight savings problem
The clock didn't change time & i lost theinstructions for manual
adjustments
I just figured out how to change mine. remove the battery from the bottom of the clock, keep plugged in, hold down the time zone button and press the set button either up or down which ever time zone you need, it is very simple hope this helps
Posted on Mar 08, 2009
How can I set the time zone?
The DST is only based on GMT.
When daylight saving time (summer time) begins
The following models employ the Automatic Daylight Saving Time/Summer Time adjustment. The DST indicator in the display appears in the display at the beginning of the daylight saving time (summer time), and disappears at the end of it. Automatic DST/Summer Time adjustment is based on GMT (Greenwich Mean Time).
• Summer time begins at: 1:00 AM on the final Sunday of March.
• Standard time begins at: 2:00 AM on the final Sunday of October
To cancel the Automatic DST/ Summer Time adjustment and
to set DST display manually
The Automatic DST/Summer Time adjustment can be cancelled.
Press and hold DST for more than 3 seconds while the clock is displayed.
A beep sounds, and "Aut t OFF" appears in the display to show that the Automatic DST/Summer Time adjustment is cancelled. The display returns to the clock.
Notes
• The change timing of Automatic DST/Summer Time adjustment employed by the unit (see above) is subjected to variation by circumstances and the law in each country/region. In such a case, cancel the Automatic DST/Summer Time adjustment and
set DST display manually as necessary. The customer who lives in the country/region that has not introduced the daylight saving time (summer time) must cancel Automatic DST/Summer Time adjustment before using the set.
• To activate the Automatic DST/Summer Time adjustment again, press and hold DST for more than 3 seconds. A beep sounds, and "Aut t On" appears in the display to show that the Automatic DST/
Summer Time adjustment is activated. The display returns to the clock.
• To change the display to the daylight saving time (summer time) manually, see "To change the display to the daylight saving time (summer time) indication."
Sony ICF ICF C318 Operating Instructions Operating The Radio Setting The...
Apr 21, 2016 | Sony ICF-C318 Dream Machine Alarm Clock...
How to set time
Plug in the unit.
First, the month and date appear, then the
year, and then the current Eastern Standard/
Daylight Time appears in the display.
Press
TIME ZONE
Area number "2" appears in the display.
If you live in the Eastern Time zone, you do
not need to adjust the area setting.
Area number
Time zone
Atlantic Standard/
Daylight Time
(default)
Eastern Standard/
Daylight Time
Central Standard/
Daylight Time
Mountain Standard/
Daylight Time
5
Pacific Standard/Daylight
Time
6
Yukon Standard/Daylight
Time
7
Hawaiian Standard/
Daylight Time
Press
TIME ZONE
repeatedly until the
desired number appears.
The display returns to the clock about 4
seconds after the operation is complete.
Note
During the shipment and your first use, a clock
error may occur. In this case, refer to "Setting the
clock and date" to set the correct time.
This unit employs Automatic Daylight Saving
indicator appears in the display at the beginning
Daylight saving time begins at: 2:00 AM on the
second Sunday of March.
Standard time begins at: 2:00 AM on the first
Sunday of November.
To cancel the automatic DST/summer
time adjustment and to set DST display
manually
The automatic DST/summer time adjustment can
be cancelled.
Press and hold
DST
for at least 3 seconds while
OFF" appears in the
display to show that the automatic DST/summer
time adjustment is cancelled. The display returns
to the clock.
Notes
Daylight Saving Time depends on the law in
each country/region, and your area may not use
it. In such a case, cancel the automatic DST/
summer time adjustment before using the set
and set the time manually as necessary.
To activate the automatic DST/summer time
DST
for at
least 3 seconds. A beep sounds, and "Aut
automatic DST/summer time adjustment is
time) indication."
Setting the clock and
date
To change the setting manually, follow the
procedure from step
Press
CLOCK
for at least 2 seconds.
You will hear a beep and the year will start to
flash in the display.
Press
or
until the correct year
Press
CLOCK
Repeat steps
and
to set the month,
day and time.
After setting the time, two short beeps sound
and the clock starts from 0 seconds.
Pressing and holding
or
changes the year,
month or day rapidly.
When setting the current time, time changes
rapidly by 1 minute-increments up to 10
minutes, and then by 10 minute-increments.
While setting the clock, you must perform each
step within 65 seconds, or the clock setting
mode will be cancelled.
To display the year and date
Press
SNOOZE/DATE/SLEEP OFF
once for the
date, and within about 3 seconds press it again for
the year.
The display shows the date or year for about 3
seconds and then changes back to the current
time.
If you connect the AC plug to an AC outlet while
this unit is powered from the backup power
source, the current date and time appears in the
following order (the same as when the unit is
powered on after a power interruption).
"month and date" (about 1 second)
"year"
(about 1 second)
"current time"
Change the daylight saving time (summer time)
adjustment setting according to the following
procedures if you have cancelled the automatic
DST/summer time adjustment.
Press
DST
The DST indicator appears in the display and the
time indication changes to the daylight saving
time (summer time).
To deactivate the daylight saving time (summer
time) adjustment, press
DST
again.
May 24, 2015 | Sony SY-ICF-C414 Clock Radio
HELLO MY CLOCK DID NOT DO AUTO DAYLIGHT TIME HOW DO I FIX THE TIME TO ADJUST TO ONE HOUR A HEAD THANK YOU INGER WELCH
All you need to do to advance your clock an hour for daylight savings time, is hold down your clock button without letting it go. Then press your hour button once and you should be all set.
Most clocks that are older than when they changed the date of daylight savings time will either not change it for you on the right day anymore. Or they don't have that feature in it.
If yours does have an automatic daylight savings feature...you may find it helpful to take it off "automatic" and just change it manually from now on. That's what I do with my VCR. It has an automatic daylight savings time feature, but it's useless now that they have changed the date when we set our clocks for DST.
Some manufacturers will give you instructions on how to change the feature settings so your product will again work correctly for you. But not all will or can. You can look it up at your manufacturers website to know for sure.
Good Luck...and I hope this helps you.
Mar 13, 2011 | Vacuums
Emerson Research SmartSet Clock Radio
There was a sheet of paper that came with my clock explaining how to adjust the daylight savings time settings, but I lost it.  Anyone have theirs?  All i know is it requires that you press an awkward combination of buttons simultaneously, but that's it.
Nov 06, 2007 | Zenith Z230S Clock Radio
Clock changing
No, the owner's manual does not mention daylight savings time.
If you lost yours, you can download it here:
http://www.geappliances.com/service_and_support/literature/
Nov 04, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Daylight saving time auto change over
call 18006954820 they will walk you through
Nov 02, 2007 | Timex T276B Clock Radio
Turning daylight saving time OFF
If DST is *already* set to "on" when you reset the time zone to Z-07 (Hawaii), my very recent experience is that the time *still gets adjusted back* by one hour.  Now that daylight savings time is over (at least according to the clock's pre-programmed and outdated schedule) I'm hoping that setting the time zone to Z-07 (Hawaii) will completely cancel the automatic time changes from now on.  Otherwise, I need to purchase another clock, and it won't be a Timex.
Apr 02, 2007 | Timex T311T Clock Radio
Timex T301B
Petewete,
Here is the manual.
http://www.timexaudio.com/pdf/T301IBOnline57204_83.pdf
Frank081541,
You can't adjust the Daylight Savings Time. I called Timex and they confirmed this.
Mar 06, 2007 | Timex Auto-Set Dual Alarm Digital Clock...
Emerson Smartset Clock Radio Logo
146 people viewed this question
Top Emerson Audio Players & Recorders Experts
Greg Cann
Greg Cann
Are you an Emerson Audio Player and Recorder Expert? Answer questions, earn points and help others
