Question about Hitachi 60EX38B TV
Hitachi 60EX38B shuts down after 30 min or 45 min of viewing.
Good old TV, no other problems, but shuts down 30 minutes or 45 minutes or whenever after watching. Any simple obvious replacement part I could try replacing.
  • dblavallee Mar 08, 2009
    I've given it a try with my air pig. Obvious
    1st remedy, just needed my **** kicked to do it !
  • 837 Answers
I would offer that you at least take the back off and give it a good cleaning - compressed air etc .. its gotta be dusty .. the dust could be causing some heat problems
Posted on Mar 08, 2009
Set turns off
The main power supply regulator section circuit has the fault. It shuts down, after some time. It will be best to contact any service technician.
Nov 16, 2013 | Hitachi 60EX38B TV
My hitachi 60ex38b shutsdown on it's own,is there anything I can do on my own to fix it?
Try unplugging and waiting about 2 min. Then retry. There is a self protection circuit which is what is stopping the unit from coming on, but it can be triggered by many things. [Units this old are famous for the capacitors (electrolyte dries out and then they blow), but that is just the most common problem. I would look the capacitors over and see if they give any indication of being "blown" (discoloring, etc.) and replace them if they do.
Feb 18, 2010 | Hitachi 60EX38B TV
Garage furnace (standing Pilot) pilot stops after 30 mins.
it sounds like the afc the fan control not working could be dust on the afc
Jan 10, 2010 | Dayton Gas Furnace Heater
Screen goes black after 30 mins of working.
There are a few things you need to check here.
1. It could be that your computer power management is set to turn your monitor and harddrive off after 30 to 45 min.
If the computer is however working for 30 to 45 min while you doing stuff and it shuts off, the there is an internal problem "Hardware"
I would suggest you check to see if the power management is set to turn off monitor 30 min and harddrive after 45 min. IF that is not so, then we go on to the next test.
It could possibly be your processor fan is not working so once your processor gets over heated it shuts off the computer.
Turn off the computer, remove the case "this is only if you know what you are doing" with the case off, power on the computer and see if the processor fan is working.
You can get back to me and I can walk you through it.
Hope thiss help.
Aug 23, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
I hv a colemanpowermate 5000/6250w generator- won't stay running
Hi, Please understand that this type of troubleshooting is hard without seeing it but doesn't sound like a fuel issue at all. This genset does have other sensors that will shut it down like low oil and high temperature. Most likely oil from your description. You also don't say what load it is carrying, could you be plugged into something that cycles off and on and when it cycles on the genset shuts down from the overload? If you think this might be the case, disconnect everything and power up a few at a time especially things that cycle on and off like refrigerators, heaters, stoves. Good Luck!
Jan 30, 2009 | Coleman Powermate Premium Plus 6250W...
Tv screen goes black
No, if the picture of your tv screen is clear when when you watching. the troble of your tv is looseboard, and you replace your CRT socket too.
Apr 16, 2008 | Sony KV-35V35 TV
TV Powers off after 30-45 mins
All you need to do is remove the back cover, then remove the metal cover that covered the power supply. Watch tv w/o cover, it won't shut down again. Try it and post here if it works.
Sep 24, 2007 | Philips 26MF231D 26 in. LCD Television
Televison & Video Logo
233 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
