Question about Dynex DX-LCD37 TV
DYNEX: DX-LCD37 no sound or picture
When the TV is turned on there is no sound or picture. It will not turn off unless unpluged.
    Brigadier General:
  • 8,619 Answers
Hi!
Check for any blown fuses. Check for the cables at the back from the cable box, are they connected firmly.
Try connecting a DVD palyer and check if its working with the DVD player.
If not then the power board on your tv is faulty, and needs to be checked for burnt capacitors.
Please ask for further clarifications.
Thanks
Rylee
Posted on Mar 08, 2009
    Genius:
  • 1,550 Answers
Try reset .
Unplug the unit from power chord for 30 minutes and plug back the power chord to the unit .
This will reset your unit .
How do you change a sound card on a dynex tv?
The sound PCB is not separate it is part of a larger board. I do not suggest the cost as it may not fix the problem. Just replace the TV.
Aug 30, 2016 | Dynex DX-LCD37 TV
Child hit screen with ball replace screen or junk tv
Search Results
    [PDF]DX-LCD37-09-2 - Dynex Products
    www.dynexproducts.com/.../DX-LCD37-09-2_08-1430_ENGLISH_WE...
    Jan 15, 2008 - DX-LCD37-09-2 ... Connecting an antenna, cable TV, or satellite TV box . ..... Remember that children can become excited while .... Do not drop your TV or hitthe glass screen. If the screen breaks, be careful of broken glass.Missing: ball
    [PDF]DX-32L200A12 DX-37L200A12 DX-46L262A12 - Dynex
    www.dynexproducts.com/.../DX-32L200-37L200-46L262A12_11-1082...
    DX-46L262A12. USER GUIDE. DX-32L-37L-46L_11-1082_MAN_V2_EN.book Page 0 Tuesday, November 22, 2011 1:09 PM .... Using the on-screen menus . ..... CHILDSAFETY ... TV or hit, jolt, or press hard against the LCD panel. If.Missing: lcd37 ‎ball
Feb 03, 2016 | Dynex DX-LCD37 TV
When the power is turned on, the screen stays black (nothing is displayed-totally dead). Then it won't turn back off unless I unplug it. The model is DX-LCD37. It doesn't matter if I use the pannel...
Had a very similar problem with mine - not sure if this will help or not, but it seems to be doing the trick (channels scanning as I type).
I unplugged the tv for about an hour. I unplugged the cable, and all the components. Then I turned the tv on, and was able to get to the menu screen. Previously, I couldn't change channels or even power off from the buttons on the side of the unit either...
Once there, I plugged the coaxial cable directly into the side of the set, then ran the auto-scan.
I know it's not a techincal answer, and a bit strange, but as I mentioned, it seems to be working for my issue.
Nov 26, 2010 | Dynex DX-LCD37 TV
I have a DYNEX LCD37 for 2 years, it was working great untill I plugged in a new HDMI cable to use my laptop, after a few uses I turned my tv on one day and the Contrast was lost, everything works fine...
The tv Tuner signal board have problems,might need the replacement of the Tuner signal board it self.Tries the tv unplug,replug it back in like an hour later.Let the tv resetting itself back to the factory setting.See,if that solved ur problems.Not,than the Tuner signal board have problems itself,must be replaced the Tuner signal board itself.
Oct 26, 2010 | Dynex DX-LCD37 TV
I have a Dynex DX-LCD37. It lost sound in it and can not get it back. if i turn the speakers off to on and it will have sound for a 1 sec. then it loses it again
You have a bad audio output ic. The ic in this set is very difficult to change, so most techs will change the entire digital board. If you can find a digital board for it, that would be the easiest solution, and can be done easily yourself. You can try ebay or shopjimmy.com to try and locate one.
Jul 29, 2010 | Dynex DX-LCD37 TV
Dynnex lcd37 tv display problem ?
There are two places to look for the problems, the backlight inverter board and the power supply. Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc. Look for 5vdc, 12vdc, and 24dvc.
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: http://www.shopjimmy.com/catalogsearch/result/?q=Dynex+DX-LCD37+
Please post back what you find.
Dec 23, 2009 | Dynex DX-LCD37 TV
No picture when I turn the tv on but have sound. If I turn the TV off and on again I get the picture.
It can be that the backlight inverter board is going out or the power supply that supply the power to the inverter board is going out due to bad filter capacitors.
Oct 31, 2009 | Dynex DX-LCD37 TV
37" Dynex TV won't turn on
TV IS 2 YEARS OLD SAME PROBLEM AS ABOVE
Jan 04, 2009 | Dynex DX-LCD37 TV
Dynex DX-LCD37 TV Logo
155 people viewed this question
Top Dynex Televison & Video Experts
Jaime Hernandez
Are you a Dynex Televison and Video Expert? Answer questions, earn points and help others
